Bleed nipple seized and snapped off
rk8479
PostPosted: 22:52 - 08 Nov 2014    Post subject: Bleed nipple seized and snapped off Reply with quote
Bleed nipple on rear brake snapped off and rest is seized in the caliper, i have got a banjo with bleed nipple inside that and after bleeding the brakes a few times the brake works but only if the pedal is pushed all the way down and it only gives a slight brake effort, im guessing the air up in the little hole to go into the old bleed nipple has air inside, what should be used to plug it? i was thinking of epoxy resin but im unsure
PostPosted: 23:05 - 08 Nov 2014    Post subject: Reply with quote
Hold your caliper so that the bleed nipple is highest and push the pistons back in. Any air should be expelled with the oil.
cresad
PostPosted: 23:07 - 08 Nov 2014    Post subject: Reply with quote
Hi , I take it your on about using the epoxy on the outside of the caliper - I hope - in the bleed screw opening ?
There's no need , it's the bottom of the screw that shuts the air/fluid off , any air trapped will be inside the caliper. There is a way of bleeding it using the banjo but it would either have to be at the top of the caliper or turn the caliper so it is making sure that the pads stay with the disc between them.
The best and only proper way forward is to drill the rest of the bleed screw out yourself / get it done or a new caliper.
Adam
rk8479
PostPosted: 23:14 - 08 Nov 2014    Post subject: Reply with quote
Yeah, and i ment use the epoxy or something similar inside the caliper to cover the hole towards the bleed nipple so no air can get up there to be trapped before bleeding
cresad
PostPosted: 23:39 - 08 Nov 2014    Post subject: Reply with quote
No , No , No don't put anything like that inside the caliper , you could loose all braking. It's either repair or replace .
Adam
Nash GT
PostPosted: 00:17 - 09 Nov 2014    Post subject: Reply with quote
Adam
That !
Replace fella even if it's with a second hand item.
It is NOT worth the risk
Suzuki GSF600N
Llama-Farmer
PostPosted: 00:42 - 09 Nov 2014    Post subject: Reply with quote
Get a spare caliper and refurb it, or get a refurbed one. See if they'll take yours as an exchange, but be sure to explain the situation, they won't return your deposit if they're expecting a sound caliper.
If they won't, get a spare caliper outright and then see about drilling the bleed nipple out of yours and refurbing it. Always handy to have a spare that you can refurb off the bike in your own time without making the bike unusable.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
monkeybiker
PostPosted: 01:09 - 09 Nov 2014    Post subject: Reply with quote
Another vote for replace caliper. Does piss about with brakes, do it properly.
andys675
PostPosted: 12:31 - 09 Nov 2014    Post subject: Reply with quote
if the bleed nipple broke off without moving then a banjo bolt bleed nipple will be fine, if you've had the fluid system open then you must push the pistons behind the pads all the way into the caliper before you start bleeding the brakes or it will take forever or just won't work
PostPosted: 12:41 - 09 Nov 2014    Post subject: Reply with quote
Precisely. All that's necessary is that the air comes out. You could drill and tap a hole anywhere and seal it with a bolt just to get the air out. Brake fluid pressure is negligible when working on a bolt end.
There's no need to worry about air trapped in the blocked port.
Islander
PostPosted: 17:55 - 09 Nov 2014    Post subject: Reply with quote
Yup, both of Pete's replies are spot on as usual. No need to do anything as drastic as replace the caliper - you only need to bleed the air out. Thumbs Up
MaybeGuy
PostPosted: 22:46 - 09 Nov 2014    Post subject: Reply with quote
Why don't you just drill it out? As far as snapped bolts are concerned it's probably one of the easiest to do provided you don't go too deep. It's even got a pre drilled pilot hole.
Fizzer Thou
PostPosted: 11:20 - 10 Nov 2014    Post subject: Reply with quote
Surely it is better to hold the caliper at the lowest point so that any trapped air rises,so that when the piston is pushed back into the caliper body the air will escape via the master cylinder reservoir Thumbs Up
Always have a 'Plan B'
PostPosted: 21:48 - 10 Nov 2014    Post subject: Reply with quote
Yes if he didn't say he had a banjo bleed nipple fitted. Holding the caliper with the bleed nipple highest and pushing out the pistons will expel air from the caliper out of the bleed nipple. Similarly pumping the lever with the bleed open will expel air from the line out of the nipple.
The last post was made 11 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 3.05 - MySQL Queries: 13 - Page Size: 83.98 Kb
