CG 125 Engine replacment/Upgrade
Jardine
PostPosted: 23:09 - 08 Nov 2014    Post subject: CG 125 Engine replacment/Upgrade Reply with quote
So recently i managed to rip a chunk out of my crankshaft and instead of replacing the crankshaft and everything else while im there im thinking about just putting a new engine in my CG
She is a 1991, she was running fine till this happened and this is now messing up the timing on her completely.
For an easy life as an amateur i was thinking about putting in a 2005 cg engine with a start motor, this would make my life easier as you can imagine.
But my question is how hard is the wiring, everybody will probably just say to me fix the engine you have but i have decided on this and its what i want to do.
Thanks for any replies and advice (i wont be doing this till after Christmas)
ws4936
PostPosted: 21:19 - 09 Nov 2014    Post subject: Reply with quote
You want to take a '91 engine out, and put a '05 engine in, converting it from kick to electric start - to make life easier?
I could be wrong but it sounds like your opening a can of worms....and would definitely complicate things. Re looming and modifying the bars to take a push start, assuming you'd replace the RH switch....and don't get me started on the frankenpaperwork, you will be replacing the engine number on the logbook?
For an easier life, I'd be looking at repairing the crankshaft on one of the easiest engines ever built.
If everything seems under control, you're just not going fast enough.
BMWilliams
PostPosted: 17:23 - 08 Jan 2015    Post subject: Reply with quote
yeaaa..... I had this idea too.... buy a replacement engine as a back up incase mine dies... 157fmi Chinese replica engine with EStart fully rebuilt with new gaskets, CDI and starter on my bedroom side
the stator wirings completely different, youll need a CDI because the newer engine doesnt have points timing like the old lump then youll need to run a switch from the ignition live for the starter...
all in all which im sure you know all about... A lot of hard work so im hoping my 92 CG engine doesn't blow up or die on me
A good long ride can clear your mind, restore your faith, and use up a lot of fuel.
Never ride faster than your guardian angel can fly.
Ride, eat, sleep...repeat.
pdg
PostPosted: 18:13 - 08 Jan 2015    Post subject: Reply with quote
How hard is it to put a string of numbers in a box on the v5 and post it?
I suppose you have to get someone to write the address on the envelope, and stamps can be a bit tricky sometimes.............
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Jardine
PostPosted: 21:30 - 08 Jan 2015    Post subject: Reply with quote
Rob Fzs wrote:
Problem with putting an 05 engine in a 91' cg is that all the electrics is all wrong
you need an 05 loom, 05 tail light, 05 carb, 05 airbox . which won't fit the 91 cg frame for some reason, 05 switch gears
probably cheaper to get another 91' engine , i've done an 05 in to a 91' and its a bodge fest
Thanks everyone ive put in a 92 engine and it seems fine Smile thanks for all your feedback
CG125 1991[Sold] YBR 125 2009[SOLD] SV650s 1999-CBR600F-H 87
[Mod1 Passed 23/05/2016] [Mod2 Passed 09/06/2016] Update: I like cake
BCF BBQ 2017 I was the one who dropped the SV haha Smile
The last post was made 11 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 50.17 Kb
