| SteveSmith |
 SteveSmith Nitrous Nuisance
| Nobby the Bastard |
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 16:43 - 08 Nov 2014 Post subject: |
It is quite important to check them regularly, so if you manage to get that dodgy bolt out, replace it with a good one and use copper grease on the threads, and don't over-tighten it.
Check again after 1,000 miles, and if no adjustment is required, check again after 2,000 miles, and so on.
Your manual probably recommends a mileage interval for checking clearances. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| SteveSmith |
| STONEY! |
 STONEY! Brolly Dolly
| Triton Thrasher |
 Triton Thrasher Could Be A Chat Bot
| Bezzer |
 Bezzer World Chat Champion
 Posted: 13:18 - 09 Nov 2014 Post subject: |
Take it that it's the Bandit again? "They all do that mate", common problem on the oil cooled motors you've been lucky to get away with just the one it's usually front and rear ones if the cover hasn't been touched for a while. There's a recent thread on OSS giving a few options
https://old-skool-suzuki.proboards.com/thread/4238/stubborn-bolt ____________________ I used to be indecisive but now I'm not quite so sure. |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:22 - 09 Nov 2014 Post subject: |
If you have a seized bolt that's stooping YOU perform a routine service inspection & adjustment... how log has it been since ANY-ONE was able to perform that routine service inspection & adjustment?
Best case, if tappet clerances are a bit wide, motor may be harder to start, will be down on power, less responsive, use a bit more fuel and probably sound like a London Taxi, as though theres a herd of ADHD dwarves in the rocker cover mining for freedom.
Worst case? Tight clerance, valve wont close; valve head gets hot n the the combustion gasses, and cant dump its heat into the seat, and melts, probably dropping the head or at least chunks of valve into the cylinder to chew piston & combustion chamber.
Often a pretty wide leeway for error on manufacturers suggested service intervals; engine thats started for times a day from cold, thrashed up ad down the gears accross town and back, will tend to suffer more 'wear' than a engine that's started once a week, warmed nicely while rider clamber into kit, then ridden for five or six hours at a stretch, at fairly constant speeds cross country or on a motorway.
BUT.. like I said if you cant get the rocker cover off to check.. how long has it been since ANYONE took the rocker cover off and checked.... and how far out of tolerance could they have gone since they were last checked? Not how far out might the go from here! That depends how far out they may be now... and you dot know
Its a piece of string question, but bolt isn't going to un-rust itself for you so you can check them next time you decide to do a service is it? And those clearances aren't going to adjust themselves to save you the hassle. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Rogerborg |
 Rogerborg nimbA
 Posted: 18:53 - 09 Nov 2014 Post subject: |
It would really help you if you told us what bike it is, the mileage, and any evidence of them being checked before.
I skipped the 12,000 mile check on my GS because:
1) Mine is an Austrian Rotax engine, not one of the Chinese Lifans, and I'm pretty lacist.
2) There are several owners' forums reports of them being fine at much higher mileages.
3) I (with good reason) don't trust the local BMW dealer to actually check them unless I'm standing over them, in which case I may as well do it myself.
4) They're a sod to get to and I can't be arsed doing it myself. Caveat emptor, next owner. ____________________ Biking is 1/20th as dangerous as horse riding.
| ADSrox0r |
 ADSrox0r World Chat Champion
| Fizzer Thou |
| SteveSmith |
The last post was made 11 years, 242 days ago. Instead of replying here, would creating a new thread be more useful? |
