kmx 125 crankshaft play
dannywwww
PostPosted: 01:18 - 10 Nov 2014    Post subject: kmx 125 crankshaft play Reply with quote
Hi I've had my kmx 125 for a few months now. Decided to do a piston change, thought I'd check my bottom end bearings etc however noticed alot of play in the crankshaft left and right
Is it normal or are my bottom end bearings gone?
Here's a video https://youtu.be/BVxxC93eugU
Any advice is appreciated!
Busa1340R
PostPosted: 09:23 - 10 Nov 2014    Post subject: Reply with quote
Could it be worn thrust bearings?
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
dannywwww
PostPosted: 13:32 - 10 Nov 2014    Post subject: Reply with quote
Is this located behind the clutch basket? Or inside the engine? I will spilt the engine if needed, but rather not if it's not nessacery Sick
hmmmnz
PostPosted: 17:33 - 10 Nov 2014    Post subject: Reply with quote
ooo thats not right,
https://images.cmsnl.com/img/partslists/kawasaki-1998-b9-kmx125-crankshaftpistons_bigkae0181e1320_2fe2.gif
im guessing either the primary spur gear nut on the clutch side, or the flywheel/generator nut or both are loose,
by thrust washer im assuming Busa1340R is meaning the 92926 spacer washers on the crank pin, but there doesnt seem to be excessive movement there
the humans are dead
I kick arse for the lord
The last post was made 11 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 44.44 Kb
