Starter Problem
Arnas
PostPosted: 11:48 - 10 Nov 2014    Post subject: Starter Problem Reply with quote
Ok so I have a Derbi Senda with an 80cc bore on it and for some reason which I cannot figure out is my starter is not getting enough power to start the bike, I'm not sure if its the battery or something more internal but when I connect battery charger using jump leads to the battery bike starts first time.
Also with the starter I get a very weak looking spark from the spark plug.
Should I just try get a new battery first?
monkeybiker
PostPosted: 12:01 - 10 Nov 2014    Post subject: Reply with quote
How long have you had the bike? Has it been used everyday or left to sit for a while?
I would say get a new battery. If your having flat battery problems then with a new battery it rules one thing out.
In the past I used to try charging battery over night but would end up later having to push start the bike to get back home. For the sake of about £30 it's not worth pissing about.
Make sure the new battery is fully charged and then start bike.With bike running give it some revs and voltage should jump to 14-15 volts.
Arnas
PostPosted: 12:26 - 10 Nov 2014    Post subject: Reply with quote
Thanks for the advice Smile I'v had the bike for about 6 months now back when it was 50cc it would never start with starter as the cylinder was gone so I was used to bump starting as it only took a little push.
The last post was made 11 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 40.07 Kb
