CB125 Question from Embarrassed!
richjp
PostPosted: 21:40 - 09 Nov 2014    Post subject: CB125 Question from Embarrassed! Reply with quote
Hi all
I am on the rebuild of my CB125 TDC, having dismantled it a few weeks ago and I am generally very careful at labelling items as I take them off the bike. However, not this time as I have come across the attached thin plate and for the life of me can't remember where it came from - can anyone help?
Embarassed
Many thanks
Richard
mudcow007
PostPosted: 22:00 - 09 Nov 2014    Post subject: Reply with quote
does it hold the powa-band on?
Sorry, i didnt have anything to add.....
Casper
PostPosted: 22:31 - 09 Nov 2014    Post subject: Reply with quote
Needle in a haystack. Here is your haystack, look yourself Laughing
That is the 88 bike. You may need to change it.
https://www.cmsnl.com/honda-cb125td-superdream-1988-england_model1408/partslist/?model_q=cb125td
MaybeGuy
PostPosted: 22:35 - 09 Nov 2014    Post subject: Reply with quote
It's a seat catch.
richjp
PostPosted: 22:59 - 09 Nov 2014    Post subject: Reply with quote
Thanks GPz750 - had looked before, but couldn't see it in there.
Thanks too mattsprattuk - I can't see that part in the schematics for the seat, but I will check the actual bike - I believe you have it - some stirring at the back of my mind that that is it.
Thanks too mudcow007 - however not quite sure what a powa-band is ?
davebike
PostPosted: 12:40 - 10 Nov 2014    Post subject: Reply with quote
It the steel shim that prevents the front pads damaging the alloy calliper
Easy to lose and then destroy the calliper
Dave
NC750Xdct + others at work !
[email protected]
Teflon-Mike
tl;dr
PostPosted: 14:51 - 10 Nov 2014    Post subject: Reply with quote
Does not look at all familiar to me at all.
It's not the seat-lock catch though; that's a sub-assembly bolts under the seat rails, and has a round receptor for the catch pin on the seat and a sort of lever inside the socket to catch it.
First thought was it looked a 'bit' like the brake pad pin retaining plate... but it isn't.
It has no round holes; two square ones with tangs hanging out of them, and a couple of half holes at the top; so it isn't a retaining plate that bolts down over something else, it looks more like a shim or spacer. Tangs don't even look right to locate or end-stop springs.
So not seat hinge or seat lock; not front brake; Air filter boxes are all moulded, and filter clips in on a tag on the filter cassette, so nothing from that region; battery & electrical? Again, all the bits that bolt to the frame have round holes in them, and or are plastic/rubber.
I'm wondering if it's a "dufuque bracket"; Snowie had one of them when she did her Super-Dream. Wonderfully cleaned it, superbly painted it, then spent two days scratching her head trying to work out where it bolted to the frame... till recognised it as a bit of old ironmongery from a old wardrobe she'd probably dropped out the old nails tin when she was hanging bits to paint on nails and string!
It honestly doesn't look 'Super-Dreamie' to me. So something used in an improvised repair not in the original Honda ingredients, from another bike maybe?.. or bit of a car seat left in the tool-box or something? That would be by best bet.
Put the rest of the bike together, like a jig-saw and see if you find a hole it fits as you go!
hmmmnz
PostPosted: 15:29 - 10 Nov 2014    Post subject: Reply with quote
may be some thing to do with the tail light? numberplate light, or the tail reflector?
the humans are dead
I kick arse for the lord
The last post was made 11 years, 241 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.28 - MySQL Queries: 13 - Page Size: 58.53 Kb
