Am thinking micra
WULFSTAN
PostPosted: 17:39 - 12 Nov 2014    Post subject: Am thinking micra Reply with quote
So to cut a long story short because of illness am thinking of not riding this winter will be the first in about 7 or 8 years that I haven't. So I was thinking of getting a little one litre micra. Anyone have one are they crap or ? Mpg cost of parts etc any help would be great thanks.
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
CaNsA
PostPosted: 17:42 - 12 Nov 2014    Post subject: Reply with quote
Am thinking micra
That makes zero sense.
temeluchus
PostPosted: 17:44 - 12 Nov 2014    Post subject: Reply with quote
I self aware (presumably nissan) micra that thinks only in or of the morning?
alt tab
PostPosted: 17:46 - 12 Nov 2014    Post subject: Reply with quote
Do you mean you're thinking about buying a Nissan Micra, the highly popular (?) supermini "middle aged woman about town" car to drive during the winter?
lihp
PostPosted: 17:48 - 12 Nov 2014    Post subject: Reply with quote
What year are you looking at?
K10 - Don't waste your time
K11 - Watch for rusty sills and crossmember, not many none-rotten left. Also are prone to have issues with the air flow sensor needing to be resoldered on the throttle body every few months.
K12 - Avoid early ones as they had shitty cam chains, probably too pricey for what you're suggesting?
K13 - Probably too new for what you're looking at?
WULFSTAN
PostPosted: 17:49 - 12 Nov 2014    Post subject: Reply with quote
Yes
WULFSTAN
PostPosted: 17:50 - 12 Nov 2014    Post subject: Reply with quote
Yer k11 whats mpg like.
lihp
PostPosted: 17:52 - 12 Nov 2014    Post subject: Reply with quote
Realistically around 40mpg, economical at the time, but remember technology has moved on.
There are better cheap cars about these days. And with the rust issues that were quite wide spread when I had a few 6 years ago, will be a major hassle now.
Nissan ran drain tubes into the rear quarters with no hole in the panel, so most have sills that are rusted from inside out, and massive holes in the front crossmember.
WULFSTAN
PostPosted: 17:56 - 12 Nov 2014    Post subject: Reply with quote
What cars for instance.
Wonko The Sane
PostPosted: 19:15 - 12 Nov 2014    Post subject: Reply with quote
I presume he's referring to the Micra,
The engines in them have a very good reputation for being very robust but they are getting on a bit, most older ones have been bought up cheap by takeaway drivers (round my way anyways)
As already said, while a fairly rot free one would not be a bad choice there are other cars such as Skoda Fabia, Kia Picanto, Kia Rio etc that are a bit newer and equally viable for what you want.
mogstar
PostPosted: 19:19 - 12 Nov 2014    Post subject: Reply with quote
Prone to rear wheel bearings going and they need pressing out. Listen for noise under load.
Don't bother with the home made press in the Haynes manual - did that and it just bent. Took the hub to an engineering shop and it took 6 tons in their press to get it out.
Might be just unlucky but the local parts shop say they sells lots of rear bearings, ours was an 04.
mogstar
PostPosted: 19:21 - 12 Nov 2014    Post subject: Reply with quote
Also ours had a Renault gearbox fitted, I know this because it jammed in 3rd gear and the gearbox repair shop told us!
dransy
PostPosted: 19:53 - 12 Nov 2014    Post subject: Reply with quote
What about a skoda fabia , picked the misses one up for 200 quid 1.9 sdi .
Ducking love it 69 mpg on a motorway run to Blackpool from Leeds at 55 mpg to work and back Very Happy
Diggs
PostPosted: 20:30 - 12 Nov 2014    Post subject: Reply with quote
Must be good cars because the local curry/pizza delivery boys love them round our way....
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
dodsi
Dirty Carny
PostPosted: 20:45 - 12 Nov 2014    Post subject: Reply with quote
How many miles do you expect to do? Just this may mean you don't have to have a little pap car but a fuel guzzling beast that people don't want because you get 25mpg and not 40. But waft around in luxury.
WULFSTAN
PostPosted: 20:51 - 12 Nov 2014    Post subject: Reply with quote
Not many id say 35 a day at the moment.
dodsi
Dirty Carny
PostPosted: 20:57 - 12 Nov 2014    Post subject: Reply with quote
Can you afford for that trip to cost you £10 per time?
angryjonny
PostPosted: 21:31 - 12 Nov 2014    Post subject: Reply with quote
I had a K11 Micra as my first car. Having never driven another car apart from my instructor's diesel mk2 Fiesta it seemed fine. Once I'd trundled around a bit in a Renault Trafic, it seemed boring by comparison.
I loved it because it was a car when I had hitherto had no car. But it's probably about the most joyless car... ie the furthest you'll ever get from a bike.
Clutches are weak. I bought one for 35 quid and had an independent garage fit it for 70. This was a *long* time ago.
grr666
PostPosted: 21:36 - 12 Nov 2014    Post subject: Reply with quote
Do you remember the commercials when they brought out the bubble
shaped micra. They combined two words to make a new one....
https://www.sniffpetrol.com/MicraAd.jpg
https://honeybug.com/gallery/albums/userpics/10001/normal_New_Micra.jpg
Don't do it.... Laughing
TOtally uncoOL
lihp
PostPosted: 22:00 - 12 Nov 2014    Post subject: Reply with quote
This, the facelifted K11 with coil packs rather than a distributer was after the Nissan-Renault merge, and had Renault electronics and gearbox. AVOID!
mogstar
PostPosted: 22:21 - 12 Nov 2014    Post subject: Reply with quote
And if the keyless ignition fails it costs more than the car is worth to fix.
bikertomm
PostPosted: 22:53 - 12 Nov 2014    Post subject: Reply with quote
Standard bikertomm advice: Get a standard Saxo VTR and re-live your youth.
Can pick them up for peanuts. Real world 52+MPG.
Mine's done almost 70,000 miles trouble free. Just clicked on 125k.
And if does go wrong, it cost's peanuts to fix. And if it goes majorly wrong, it cost nothing in the first place. Chances are, it might not even go wrong.
lihp
PostPosted: 00:30 - 13 Nov 2014    Post subject: Reply with quote
Immobiliser can be removed for air £50
stonesie
PostPosted: 05:51 - 13 Nov 2014    Post subject: Reply with quote
Don't get a saxo if you have wide feet, I nearly bought one but on the test drive I kept hitting throttle and brake at the same time, also had to twist my ankle to get more than half throttle. Probably Citroens most rugged car ever though.
I ended up with a corsa, if 'meh' was a car it would be a corsa...
WULFSTAN
PostPosted: 07:11 - 13 Nov 2014    Post subject: Reply with quote
If I was going to get a citroen mate id get a other zx use to get it sideways every roundabout. The joys of youth.
The last post was made 11 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 130.98 Kb
