Tidying up my tail (Kind of)
alt tab
PostPosted: 20:14 - 15 Nov 2014    Post subject: Tidying up my tail (Kind of) Reply with quote
Decided to see what I could do to tidy up my number plate situation, as it's all rather bloated and excessively heavy. With some top advice from Marmalade earlier in the day, I decided to make a start when I got home. Here's what I've done so far (Will update once I do more)
https://s28.postimg.org/tisxvgcr1/2014_11_15_18_01_37.jpg
The aim is to remove a section from the bottom of the rear light, so it emits white light directly below, meaning I can remove the big unit, and shift the number plate up.
https://s28.postimg.org/cjjzg71jh/2014_11_15_18_01_43.jpg
From crafting knife, to pocket knife, to drilling and then hack sawing, I slowly got to the point where I removed the section needed.
https://s28.postimg.org/gddfpcivh/2014_11_15_18_21_45.jpg
This is the result after filing down with metal files. I then keyed the surface with some 60 grit sandpaper.
https://s28.postimg.org/s17hjw80d/2014_11_15_18_27_07.jpg
After applying a generous bead of adhesive, I placed a piece of clear plastic over the hole.
https://s28.postimg.org/9wzvliky5/2014_11_15_18_27_22.jpg
This is where I sourced the plastic from, an empty craft knife packet!
https://s28.postimg.org/psopotbil/2014_11_15_18_27_41.jpg
This is the size of the piece I managed to get out before filing.
https://s28.postimg.org/dzvhyc4gd/2014_11_15_18_53_31.jpg
Here you can see the light that's being emitted downward by the window I made.
https://s28.postimg.org/myq5p3yq5/2014_11_15_18_53_38.jpg
Another shot of the same.
https://s28.postimg.org/47o8ey45p/2014_11_15_18_53_47.jpg
And an upward shot of the window. I may well play with the reflector unit so the black shadow isn't there, unsure yet Smile
The last post was made 11 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 29.99 Kb
