kmx 125 breakes
yz450
PostPosted: 22:37 - 22 Jan 2005    Post subject: kmx 125 breakes Reply with quote
does any one know if the breaks on kmx 125's are crap? because i have double H pads on front and rear and braided hoses, the breaking is very poor!
thanks
yz
feel the power!!!!
stevo as b4
PostPosted: 17:57 - 23 Jan 2005    Post subject: Reply with quote
Whats your discs like e.g. worn, scored? Are your pads contaminated possibly? Ive got EBC HH front pads on my current kmx200, with a steel brake line, and even though the disc is worn to well below the min thickness, the braking was better on this bike than the 1st kmx i had, which was fitted with organic pads, and aged rubber lines. if anything the rear brake was twice as powerful as the front was. I would personally start with a full service, strip and re-build the caliper with new seals, cleaned piston and change the fluid. If your disc is worn its probably best going for an EBC disc as well as new EBC HH pads. Kmx's wear discs quickly usually less than 10'000miles on a front disc. If your kmx125 has a tip top condition braking system it should be perfectly sufficant for road use, bearing in mind that its a trail bike, so it doesnt have comparable brakes to a sports bike like an RS125. I dont think you need to do more than the above to make a kmx125 stop reasonably well considering its performance, but if ultra sharp stopping power is required you either have the wrong bike, or you need to do a supermoto conversion and fit a big disc.
yz450
PostPosted: 21:50 - 24 Jan 2005    Post subject: Reply with quote
thanks m8 will try servicing the brakes!, the rx50 i had before had very good brakes, so it made me wonder why these were so shite!
feel the power!!!!
yz450
PostPosted: 15:07 - 29 Jan 2005    Post subject: Reply with quote
just got round to servicing my brakes, new pads, disks and fluid, not one bit of difference Sad
feel the power!!!!
RascalsCustar...
PostPosted: 16:11 - 29 Jan 2005    Post subject: Reply with quote
Those rubber hoses get to be almost useless after a while. Expanding under the pressure. Get yourself a set of braided hoses...I did and it's made all the difference on my KMX.
I got mine from here if it's any help.
All the best matey.
The last post was made 21 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 44.13 Kb
