Bleeding brakes fail
PostPosted: 12:58 - 17 Nov 2014    Post subject: Bleeding brakes fail Reply with quote
2008 Royal Enfield, joke brand calliper, no brand master cylinder.
Went a bit floppy, wouldn't stiffen up no matter how much I pumped. I have:
Drained down the system.
Cleaned around the pistons.
Replaced the crush washers on both banjos.
Pushed the cylinders fully in (they move smoothly).
Replaced the fluid with fresh, unopened DOT 4, injecting from the bleed nipple, alternating with gentle pumping at the lever.
Plenty of bubbles came out during filling. There are no more bubbles at either end now while pushing fluid in either direction.
Tried:
Tapping the calliper and line, flexing the line.
Removing the calliper and rotating it in various directions while tapping.
Tilting the master cylinder in various directions (so that the banjo is lower than the cylinder).
Leaving for several hours.
Leaving for several hours with the lever clamped to the bars.
There is enough pressure to push fluid out of the nipple, but the lever comes back to the bars without much effort.
Next? Test the master cylinder? Stick a bolt in the outlet? Thinking
wr6133
PostPosted: 13:17 - 17 Nov 2014    Post subject: Reply with quote
My crappy super cheap Chinese master cylinder I fitted to my ZZR last week had those symptoms. TLDR version I tied the lever back and put a load of kitchen towel on the infill under the m/c, 24 hours later there was some brake fluid on the kitchen towel, so the m/c was leaking a bit.
Managed to bodge old bits from 3 knackered OEM m/c's together now to make one (hopefully) working one just need it to stop raining so I can fit.
In your shoes I'd fork out for new seals I'm sure it won't bankrupt the Exchequer of Borg.
edit - seals at both ends no point rebuilding the M/C and leaving the calliper with old ones
Islander
PostPosted: 13:55 - 17 Nov 2014    Post subject: Reply with quote
I'd be looking at the master cylinder at this point. You could try blanking the outlet off (or just clamp the hose at a suitable point) to check whether you're loosing pressure there or not.
arry
PostPosted: 14:17 - 17 Nov 2014    Post subject: Reply with quote
I'd be looking at the master cylinder too.
Years ago I had one rebuilt at a specialist engineering place (rare car, rare cylinder) and the guy was explaining why they tend to go just after bleeding - in effect pushing the rod through past the point of its usual operation, where it's a bit rougher / dirtier. Not sure how much truth there was in it, but having had 2 go like that on cars over the years after replacing brake fluid I'm inclined to think he did know what he was talking about.
map
Mr Calendar
PostPosted: 16:18 - 17 Nov 2014    Post subject: Reply with quote
Isn't there a trick to crack open the master cylinder banjo bolt as might be some air trapped there?
...also found this...
Dan's Motorcycle Pages wrote:
...On at least one China clone bike I had to take the master and slave cylinders off the bike and turn them every which way while pumping the master. I left the caliper loose on the rotor so the piston didn't pop out. It took forever but it finally pumped up. ...
...now I know it's Indian, not Chinese, but...Thinking
PostPosted: 20:08 - 17 Nov 2014    Post subject: Reply with quote
Thanks all, that's the kick up the arse that I needed. I'm not convinced by the pressure at the master cylinder, so a repair kit is on order along with a braided hose for good measure. Stop looking so smug, GS. Tut Tut
Wull
PostPosted: 00:20 - 18 Nov 2014    Post subject: Reply with quote
Did you actually try bleeding at the m/c?
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
Wull
PostPosted: 00:21 - 18 Nov 2014    Post subject: Reply with quote
Yeah this,this works a treat for me every time especially with bleeding the hard to bleed 6 pots.
PostPosted: 08:38 - 18 Nov 2014    Post subject: Reply with quote
Yup, I cracked the banjos at both ends, then had another go at tilting and tapping.
Oh, I also tried sucking from the nipple (steady) with a vacuum pump.
There are no air bubbles coming out at either end. It could still be an air lock somewhere, but I'm stuffed if I can figure out where. It's a very simple system, no splits, two pistons.
With the M/C plugged, I wasn't convinced by the pressure. I got some plunger/lever movement with no leaks, when I wouldn't expect any. Sadly I couldn't find my circlip pliers to disassemble it, so I just went ahead and ordered a repair kit (and new pliers), which means that it'll probably resolve itself now. Wink
weasley
PostPosted: 13:44 - 18 Nov 2014    Post subject: Reply with quote
One last thing - have you pushed-back the pistons with the system all connected up and flushed? Can be a way of forcing any airlocks back towards the m/c or into a bleedable location.
Wull
PostPosted: 14:29 - 18 Nov 2014    Post subject: Reply with quote
Hhhmmmmm,well after all that lets hope its a fucked m/c.
PostPosted: 15:17 - 18 Nov 2014    Post subject: Reply with quote
£10.19 for a complete kit including new cover, I won't be too upset if it's just a very stubborn air lock. I'd rather have it back on the road.
Actually, no. I filled it with the pistons clamped all the way in to try and avoid getting air behind them in the first place. Thinking
I've been tilting and tapping the caliper at all angles to try and get any air to the bleed nipple or up the line, but another good clamping might be in order.
https://www.reactiongifs.us/wp-content/uploads/2013/08/clamps_futurama.gif
PostPosted: 20:20 - 18 Nov 2014    Post subject: Reply with quote
...nope. Awaiting M/C kit by donkey post from Mumbai.
Bru
PostPosted: 20:49 - 18 Nov 2014    Post subject: Reply with quote
I tend to have old, shit bikes, and prefer to fix what exists, before coughing up for new parts. I found that often, a neglected master cylinder will have some hard deposits in the bore, which will of course do no good to the cup seal.
I have successfully polished these out, using the green side of a generic green/yellow scouring pad (held over a small pair of needle-nose pliers). The green fibre is hard enough to break down the brittle (aluminium oxide?) deposit, but does no harm to the bore. In this way, I have successfully restored manky old dogly master cylinders to full pressure.
It will be worth you squinting down the bore of the m/c before installing your new kit. Sorry if I'm teaching grandma to suck eggs, etc.
PostPosted: 21:28 - 18 Nov 2014    Post subject: Reply with quote
Nope, great info. I haven't done a M/C before. I have to get a new set of circlip pliers anyway, then I'll get it apart and see what's up.
Worst case, the next owner gets another bit in the big box o' bits.
Bru
PostPosted: 21:40 - 18 Nov 2014    Post subject: Reply with quote
Marvellous. Don't be shy when flushing the offending master cylinder out with brake cleaner, either. Be sure to give that pressure relief (pinhole) vent, usually situated quite obviously at the base of the reservoir, a good blast too.
Note: whittle the end of the tube, hopefully-supplied with the brake cleaner aerosol, to a point; this helps wedge it into the vent.
map
Mr Calendar
PostPosted: 22:03 - 18 Nov 2014    Post subject: Reply with quote
Rogerborg wrote:
...air to the bleed nipple or up the line, but another good clamping might be in order....
Mrs Borg must be pleased you're working on your foreplay techniques Wink
PostPosted: 22:23 - 18 Nov 2014    Post subject: Reply with quote
Choke, kick and twist is good enough for my rides.
PostPosted: 19:46 - 27 Nov 2014    Post subject: Reply with quote
So, this is going to be one of those tasks. I've got a new piston in the master cylinder, nice and snug, and a braided line ready to go on because pimp, and what does India know about rubber anyway?
Let's just check the caliper again before connecting everything up. Pads are good, pistons are sliding freely.. oh... shouldn't the body be sliding on the bracket pins?
Nope. One pin is locked solid in the body, and I mean solid. Penetrating fluid, tapping the bracket with a little hammer, a rubber mallet, the big mallet, smacking it with the big mallet, nothing. In the vice, grips on the pin, nope, can't budge it 4/1000" in any direction.
It's now sitting on the radiator because, you know, maybe it's just sulking because it's cold. Worth a try.
331X2
PostPosted: 22:13 - 27 Nov 2014    Post subject: Reply with quote
Try soaking it with plus gas overnight then get the body held steady in a vice, lots of heat from a blowlamp and it should free up with a twisting motion Thumbs Up
PostPosted: 23:54 - 27 Nov 2014    Post subject: Reply with quote
How do you imagine the rubber boots will hold up to a torch? Thinking
Acetone+ATF is in there now, I'll go in with the clamps again tomorrow.
331X2
PostPosted: 08:03 - 28 Nov 2014    Post subject: Reply with quote
If you need it out, you need it out. Strip everything that will come off and everything else will have to be replaced, can't make an omelette without breaking eggs...
Skudd
PostPosted: 08:15 - 28 Nov 2014    Post subject: Reply with quote
Tell me about it. New bracket should be here today after going at things gently then getting a bit more forceful, then getting down right bullish ended up drilling through bracket.
Heat + metal corrosion + heat + time + heat = The strongest welded thing known to man.
PostPosted: 08:55 - 28 Nov 2014    Post subject: Reply with quote
Mmm, I can see myself drilling the pin out. Chances of not messing up the caliper, slim to anorexic.
The last post was made 11 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 133.69 Kb
