Honda CB1 NC27 5,000RPM misfire
garth
PostPosted: 12:22 - 19 Nov 2014    Post subject: Honda CB1 NC27 5,000RPM misfire Reply with quote
I have acquired a cb1 that won't play ball.
It runs well in any gear up to 5,000rpm and then misses.
It will still miss in neutral.
It previously ran well.
I've read about the 112mph restriction and the cdi going into limp mode etc - does anyone know which wires would cause these symptoms and which I should test?
Thanks
PostPosted: 12:45 - 19 Nov 2014    Post subject: Reply with quote
Speedo the original? On the CB400SF the restriction was in there, fitting a 2k resistor would bypass it, however I cannot recall the wire which controls this. Sad
wr6133
PostPosted: 12:52 - 19 Nov 2014    Post subject: Reply with quote
If it's kicking in to the failsafe then somebody has probably already tried to remove it and fucked up, Look at the clock wiring and CDI wiring for badly bodged/cut wires. If that all looks normal then you need to get inside the clocks and see if some clown has tried altering the bit in the speedo.
Once you locate prior owners fuck up here is how to do it properly
https://hondacb400.myfreeforum.org/sutra122.php
Scootaloo
PostPosted: 13:51 - 19 Nov 2014    Post subject: Reply with quote
My first CB-1 started having trouble revving correctly when my electrics was about to die... shortly afterwards my battery exploded... I would charge the battery fully first and see if it makes a difference.
(CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87)
Scootaloo
PostPosted: 14:02 - 19 Nov 2014    Post subject: Reply with quote
Good post above, following that link I found:
Just remove the fuse for (its 1 fuse mine is a 10Amp);
"meter, tail light, horn, turn, stop light, neutral light, hazard".
Then ride the bike, carefully!
remembering you have no indicators, no rear lights, no neutral light, no horn.
It should misfire at 5500 RPM, and believe me its noticeable.
If it doesn't misfire your bike has been derestricted already.
Sounds similar!
garth
PostPosted: 14:05 - 19 Nov 2014    Post subject: Reply with quote
Not bothered by the restriction. Couldn't care if it is!
The clocks are original. Look untampered with.
How do I remove the trip knob to get the speedo face out?
I've found the 'restriction' wiring, as the above guide, but surely there must be a fault elsewhere if it ran ok previously?
garth
PostPosted: 14:09 - 19 Nov 2014    Post subject: Reply with quote
oh, battery is new and lights work.
Scootaloo
PostPosted: 14:10 - 19 Nov 2014    Post subject: Reply with quote
In that case then I would probably start considering the possibility your electrics are about to go bang.. its very common on these bikes...
I would charge the battery fully, check of any change at all to the revving issue. Then start the electrical fault finding process with a voltmeter thingy.
As I say, electrical issues are the word with these bikes.
garth
PostPosted: 14:15 - 19 Nov 2014    Post subject: Reply with quote
Electrics don't just go bang by themselves Laughing
It's charging and everything else works, aside cutting out above 5k.
PostPosted: 14:17 - 19 Nov 2014    Post subject: Reply with quote
I'd still be looking towards the restriction.
5k is nowhere near it coming into its "power" if you can call it that, its rather fishy being close to that rpm killer restrictor of death.
garth
PostPosted: 14:27 - 19 Nov 2014    Post subject: Reply with quote
Will it shit itself if I join the wires without a resistor?
Scootaloo
Ok... I'm just saying that's exactly what happened to mine... everything working fine just wouldn't rev about that RPM, let me what you discover.
PostPosted: 14:28 - 19 Nov 2014    Post subject: Reply with quote
The resistor should just "resist" so it never gets to its limiter, so I assume no. But then again I know nothing Thumbs Up
garth
PostPosted: 15:16 - 19 Nov 2014    Post subject: Reply with quote
From reading more, it looks like if there is any disruption of those two wires it will cause the 5k issue.
Before i mess about with resistors i'll check for breaks in the wires.
garth
PostPosted: 15:32 - 19 Nov 2014    Post subject: Reply with quote
Right then. There's continuity between the orange and blue wire at the clocks to the cdi - so no breaks there.
I'll try a resistor next.
map
Mr Calendar
PostPosted: 15:47 - 19 Nov 2014    Post subject: Reply with quote
From left field I did come across this about power loss at 5k. Diagnosed as rotted exhaust.
RhynoCZ
PostPosted: 16:05 - 19 Nov 2014    Post subject: Reply with quote
Can you rev it up to the top at neutral? Thinking
garth
PostPosted: 16:19 - 19 Nov 2014    Post subject: Reply with quote
not on 4cyl.
Exhaust is good, 4-1 titanium job.
RhynoCZ
PostPosted: 16:34 - 19 Nov 2014    Post subject: Reply with quote
garth wrote:
not on 4cyl.
Try it again and add the throttle very, very gently and slowly. If that will let you rev it up to the top, then you Sir, have got water in the 4th carburetor. Water and fuel additives create a ball of slime that's sucked into the jet at load. Thumbs Up
EDIT: Like it was yesterday, when I got home on my CB-1 on 3rd gear going 20mph for about 15 miles, because once I pushed it a bit, it died immediately. Laughing
PostPosted: 16:44 - 19 Nov 2014    Post subject: Reply with quote
The restriction kills 2 cylinders and fucks up just after 5k, that is likely what the problem is. Not water in the carb.
garth
PostPosted: 18:56 - 19 Nov 2014    Post subject: Reply with quote
Picking up the resistor in the morning, forgot to check the 12v feed for the restriction circuit though. Could be that.
RhynoCZ
PostPosted: 23:09 - 19 Nov 2014    Post subject: Reply with quote
I've never heard of such a thing actually. Well, yes I know the TCS works this way, but a ''speed-restrictor'' that cripples the ignition of a motorcycle? Thinking
PostPosted: 23:13 - 19 Nov 2014    Post subject: Reply with quote
Yup, its also what was on my Supra, killed 4/6 cylinder feeds when you hit 112mph.
Makes for epic flames though.
garth
PostPosted: 13:33 - 20 Nov 2014    Post subject: Reply with quote
I've done the resistor mod at the wires that go to the speedo.
Didn't fix it.
Bang on 5k every time, but runs so sweet other than that. Just about to get a strobe on the HT leads.
garth
PostPosted: 13:59 - 20 Nov 2014    Post subject: Reply with quote
It would appear that cylinders 3 and 4 have an intermittent spark (on a closed throttle it dissapears?!)
WTF is that about.
The last post was made 11 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 127.09 Kb
