GSXR1000 cutting out
el_oso
PostPosted: 20:57 - 19 Nov 2014    Post subject: GSXR1000 cutting out Reply with quote
Having a few issues with the GSXR. It randomly cuts out in only in first gear, or so I've noticed. It's never happened in neutral. I noticed it a week or so ago when pulling up to a set of lights. Apply brakes pull the clutch in and the engine stops. It's starts intermediately on the button with no hesitation. Any ideas?
https://youtube.com/watch?feature=youtu.be&v=J3vqe3jIMo0
Duke 390
Car: Jeep Wrangler 4.0L
Fisty
PostPosted: 21:02 - 19 Nov 2014    Post subject: Reply with quote
Is the fuel low when this happens?
Fatter and faster than Fret
el_oso
PostPosted: 21:38 - 19 Nov 2014    Post subject: Reply with quote
Not particularly. Probably ranging from 3/4 to fuel light on
Duke 390
PostPosted: 22:08 - 19 Nov 2014    Post subject: Reply with quote
Checked the tip-over sensor isn't loose?
Side stand cut out?
el_oso
PostPosted: 22:18 - 19 Nov 2014    Post subject: Reply with quote
Not checked the tip sensor. Seems to make most sense. Guessing would only have an effect in gear?
Side stand switch removed for being broken. New one on the way.
Duke 390
UrbanRacer
PostPosted: 01:39 - 20 Nov 2014    Post subject: Reply with quote
Tip sensor will trigger regardless of being in gear or not.
If it was me i would get under the tank and check all the pipe work, make sure its all attached properly and none are damaged or worn.
c_dug
PostPosted: 11:34 - 22 Nov 2014    Post subject: Reply with quote
Presumably if it was the tip sensor it would act up even when moving?
If you just leave it ticking over in neutral, without touching the bike at all, is it all fine?
How about in neutral but blipping the throttle as you were in the video?
And then in first with the clutch in but without touching the throttle?
Just trying to narrow down possible causes.
evilzed
PostPosted: 13:35 - 22 Nov 2014    Post subject: Reply with quote
Hmm this looks similar to my issue here I was in first when the bike stalled too but I don't think it's gear related my bike wasn't stalling in neutral and was fine at lights.
el_oso
PostPosted: 20:39 - 22 Nov 2014    Post subject: Reply with quote
idles fine. Sounds stable with no wobble in the needle, both in gear and out of gear with clutch in and out.
Only when snapping the throttle shut as per video does it stall. Tend to notice it quite a bit on my journey through London to work as you have to do a lot of sudden stops. If I'm smooth off the throttle then it seems fine. Problem seems identical to the hornet video above.
Duke 390
The last post was made 11 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 60.15 Kb
