How Long Can My Battery Tolerate 17v For?
b422063
PostPosted: 13:15 - 21 Nov 2014    Post subject: How Long Can My Battery Tolerate 17v For? Reply with quote
My regulator rectifier is toast and I've wired in a voltmeter to keep an eye on the voltages whilst I'm waiting for my replacement to turn up (no thanks to Electrex who didn't even answer my email Sad )
In the mean time, I've still got to get to work. With my heated grips on full power and main beam on all the time I can get the voltage down to between 16v and 17v.
This cannot be good for the battery. How long will it tolerate it for? What other issues can I expect from this?
Aff
PostPosted: 13:36 - 21 Nov 2014    Post subject: Reply with quote
The Gassing voltage for a 12V Lead Acid battery at around 10C is something like 14.8V.
Anything over that and you are boiling off it's liquids and damaging the battery.
If you could get it down to about -20C it wouldn't gas but that seems unpractical.
Basically, any amount of time you run at 17V you will be killing it. The colder you get it the slower you will kill it.
I would be finding an alternative means of transport.
Electric Bike Project
P.
PostPosted: 13:44 - 21 Nov 2014    Post subject: Reply with quote
Unplug regulator, charge battery at work, use minimal electrics.
Alternatively, grab £60 and replace it.
WD Forte
PostPosted: 13:49 - 21 Nov 2014    Post subject: Reply with quote
What bike? what rectumfrier?
throw us a frickin bone here !
I've worked on a few bikes where the RR was OK but poor connections caused
the black sense wire voltage to float
Voltage rose leading to rotten egg smell + toasted battery
Patching the sense to battery live and the ground to battery neg
got it back in range again
( my bikes RR has been wired like this for years now)
Your RR may well have failed for all I know
but the above test helps to confirm it
How long can you ride like this?
Dont know, but would say not using the bike until its fixed
is the wisest option
bikers smell of wee
Baffler186
PostPosted: 14:19 - 21 Nov 2014    Post subject: Reply with quote
In my experience, it took about 40 miles. For the sake of 60 or 70 quid I'd suffer the bus and wait for new RR
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
PostPosted: 14:47 - 21 Nov 2014    Post subject: Re: How Long Can My Battery Tolerate 17v For? Reply with quote
Short your brake light, turn on your indicators or hazards, and mash the horn constantly.
I absolutely guarantee that your battery will not be the limiting factor in your riding range if you do this.
Fizzer Thou
PostPosted: 17:12 - 21 Nov 2014    Post subject: Reply with quote
From experience of excessive charging voltage,the plates buckle and short out,permanently damaging the battery.
This also happened when a friend who worked in a bus garage borrowed a battery charger from work and put 24vdc across his car battery.It did not do any of his car electrics any good Thumbs Down Evil or Very Mad Thumbs Down
Always have a 'Plan B'
monkeybiker
PostPosted: 18:53 - 21 Nov 2014    Post subject: Reply with quote
Is there nobody at work who could give you a lift?
PostPosted: 19:10 - 21 Nov 2014    Post subject: Reply with quote
I wouldn't try riding it like that (might with one that wasn't charging - just manually charge the battery regularly).
Only time I have had a regulator / rectifier land up over charging like that the first thing that brought my attention to it was that it fried the control unit for the heated grips. So I wouldn't expect yours to last long
monkeybiker
PostPosted: 19:15 - 21 Nov 2014    Post subject: Reply with quote
I had a regulator go and ended up with a battery like a balloon.
ADSrox0r
PostPosted: 22:35 - 21 Nov 2014    Post subject: Reply with quote
A crappy connection somewhere in the ignition caused my sense wire to make the regrec go loopy and munch a battery. Chucked in a bypass direct to the battery (No thanks to Honda for picking a shitty route back to the battery in the first place!) and all is well.
How long will it last at 17V? Not long, not long at all. It's merely a matter of what goes pop first. Lay it up till the replacement arrives and get t'bus lad.
moonzoomer
PostPosted: 22:53 - 21 Nov 2014    Post subject: Reply with quote
I would be more concerned about what type of 17 volts your battery is getting since your rec/reg has expired, is it a DC voltage or and AC voltage, have you tried metering the input to the battery on both an AC and DC scalewith the battery disconnected because you might find the voltage is a lot higher than 17 volts RMS if it is AC due to the knackered rec/reg.
Nobby the Bastard
Harley Gaydar
PostPosted: 23:06 - 21 Nov 2014    Post subject: Reply with quote
Pull the connector from the genny/alternator/whatever.
Charge the battery every night.
Nothing will be more broken than it already is.
Triumph Sprint ST 1050
hmmmnz
PostPosted: 23:21 - 21 Nov 2014    Post subject: Reply with quote
as above, "constant loss" that bitch
even if its fuel injected you'll still get a fair few hours riding before the voltage drops enough to stop it running, less obviously if you are running your headlight and heated grips,
the humans are dead
I kick arse for the lord
Nobby the Bastard
Harley Gaydar
PostPosted: 23:40 - 21 Nov 2014    Post subject: Reply with quote
I got 50 miles before my FZ's battery couldn't run it any more, approx half of it with the headlight on.
moonzoomer
PostPosted: 00:00 - 22 Nov 2014    Post subject: Reply with quote
assuming the bike has DC ignition and injection.
hmmmnz
PostPosted: 10:43 - 22 Nov 2014    Post subject: Reply with quote
i managed to get about 7 hours riding on a bandit 12 (carb'd of course)
more load on the battery less time it will last,
most race bikes run constant loss and will do a 2 hour race with out even thinking about it.
unsure why your fz wasnt getting that, old fz with carbs or new injected fz?
im not sure what bike wouldn't run on DC, even old points bikes that normally run direct of the genny/alt will happily run directly off the battery.
any way reguardless, its still better to run your battery flat than fry your cdi,
batterys can be recharged, and it wont hurt the cdi
the humans are dead
PostPosted: 21:22 - 22 Nov 2014    Post subject: Reply with quote
A bit of a bodge, but I reckon you could use a cheap solar charger to sort it out while sourcing a proper unit - something like this should be able to handle 240w alternator www.ebay.co.uk/itm/311021444796 - or £15 for one that can do 360w.
Maybe something I've missed, if anyone knows a reason it's a bad idea?
PostPosted: 20:17 - 23 Nov 2014    Post subject: Reply with quote
While true, most bikes use a regulator / rectifier which is performing 2 separate functions. The regulator controls the level of voltage while the rectifier converts it from AC to DC.
It would be pretty unusual for both these to fail at the same time and still output any power.
PostPosted: 21:08 - 23 Nov 2014    Post subject: Reply with quote
You don't need an electrex reg rec just buy the handiest 3 phase 5 wire regulator rectifier you can get hold of and hard-wire it to the loom with crimps or chocolate-blocks 3 yellows to the alternator red to live black to ground. They all do the same job to just about the same voltages. Your battery will already be wrecked from over-charging so get one of those too.
b422063
PostPosted: 07:25 - 28 Nov 2014    Post subject: Reply with quote
Just for all your information, I stopped using the bike after lots of you gave me a virtual slap and said "Get real". It turned my daily commute into a 2 hour one way trip, but it saves having to do it long term if the bike wrecks itself.
New battery for the bike has arrived. The new regulator rectifier arrived in the country less than 48 hours after being posted. It's now been sat in the UK customs for a week. Rolling Eyes I phoned HMRC about it but apparently I have to speak to my courier regarding it.
I've got a spare Honda regulator rectifier, but it has no wires just a male plug. I hope I can use crimp connectors to wire it in, but I'm not sure which would be which wire.
If anyone's got a Honda regulator rectifier, can you let me know? Smile It's got three connectors one side and two the other, so I would like to guess which is which, but confirmation would be good.
WD Forte
PostPosted: 14:38 - 28 Nov 2014    Post subject: Reply with quote
There are a shit load of RRs you can patch in quite easily
but you're not helping by not saying/showing what it is you have
So.
Based on current info.
that one, that one and that one are AC in,
that one and that one are the DC out
bikers smell of wee
The last post was made 11 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 135.85 Kb
