my 1993 fzr wont start HELP!!!!
trist2014
PostPosted: 00:08 - 22 Nov 2014    Post subject: my 1993 fzr wont start HELP!!!! Reply with quote
hi there
I recently got a 1993 fzr 600 from a mate of mine (was running fine when he had it) he striped it to streetfighter it but never finished it so I got it for cheap iv put the engine back in and all other bits it turns over has spark and fuel getting to the engine but it just wont start can someone please help me
thanks in advance
t.dolman
Nobby the Bastard
Harley Gaydar
PostPosted: 00:15 - 22 Nov 2014    Post subject: Re: my 1993 fzr wont start HELP!!!! Reply with quote
trist2014 wrote:
hi there
thanks in advance
Check my sig. the FZ proboards link will give you access to people who know loads about them.
Triumph Sprint ST 1050
CG Sam
PostPosted: 10:30 - 22 Nov 2014    Post subject: Reply with quote
Did you check the engine over? Could be the timing completely out or any number of things. How was it stored?
CG125, SV650S, CBR600F, GSXR600 SRAD
trist2014
PostPosted: 10:48 - 22 Nov 2014    Post subject: Reply with quote
thanks nobby and cg sam was storded in a garage and I can see the timing being out as nothing on the engine got touched it was just the lump got took out the frame
t.dolman
Fizzer Thou
PostPosted: 11:08 - 22 Nov 2014    Post subject: Reply with quote
Has the sidestand switch been disconnected?
When I bought my FZR1000R this was one of the first parts into the bin and the wires were connected together.
Always have a 'Plan B'
CG Sam
PostPosted: 11:41 - 22 Nov 2014    Post subject: Reply with quote
Were there blanking plates or cloth stuck in the inlets or outlets to stop any moisture getting in?
If it isn't the sidestand wires/switch as Fizzer Thou suggested I'd check the timing and valve clearances.
trist2014
PostPosted: 19:46 - 22 Nov 2014    Post subject: Reply with quote
the side stand was unplug but all pluged in now . all im getting is backfireing how can I check if the timeing is out (without striping the engine to much)and there where clothes in each hole and stored in a garage
t.dolman
Nobby the Bastard
Harley Gaydar
PostPosted: 19:50 - 22 Nov 2014    Post subject: Reply with quote
If it's like most of the FZ(R) range, you cannot adjust the timing of the ignition.
jjdugen
PostPosted: 20:04 - 22 Nov 2014    Post subject: Reply with quote
Try new plugs. Many of my clunker renovations that had been stood for a while were pigs to start, new plugs seem to cure them 90% of the time.
sickpup
Old Timer
PostPosted: 07:17 - 23 Nov 2014    Post subject: Reply with quote
How do you have the coils connected up? One should go to 1-4 and the other to 2-3 I believe.
A100man
PostPosted: 10:46 - 23 Nov 2014    Post subject: Reply with quote
Good call. IIRC left side coil is 1 & 4 right side 2 & 3 manual shouldhelp here.
It's not sidestand or TCI/ignitor related since you have a spark but is it in the right place ? Swapped leads would give the symptoms you describe I think.
Once you have it running check the valve clearances too - it should run better with these in spec.
The last post was made 11 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 67.13 Kb
