brake fluid as coolant? (car question)
Stalk
PostPosted: 09:47 - 23 Nov 2014    Post subject: brake fluid as coolant? (car question) Reply with quote
Young Stalk had his brake fluid run low due to lax maintenance and explained to me that he had put 600 ml of fluid in and the light was still on. Pulled all the wheels of for him and found no leaks. Asked him where he put the fluid and he points at the coolant expansion bottle. He feels suitably stupid.
Question is, can I expect any adverse reaction from that amount of brake fluid in the coolant?
Cheers,
Stalk
Fisty
PostPosted: 10:21 - 23 Nov 2014    Post subject: Reply with quote
To be safe I would drain and flush the coolant, then refill.
Fatter and faster than Fret
CaNsA
PostPosted: 10:22 - 23 Nov 2014    Post subject: Re: brake fluid as coolant? (car question) Reply with quote
Unless you have a leak, the amount of brake fluid will remain the same.
When it gets "low" it is time for new pads.
stonesie
PostPosted: 11:23 - 23 Nov 2014    Post subject: Reply with quote
n refill.
This, brake fluid is nasty and I don't know what it will do to the rubber parts of the cooling system so draining and flushing it is what I would do.
Aff
PostPosted: 11:58 - 23 Nov 2014    Post subject: Reply with quote
Wont do any good for the seals. I would get it out and give it a good flush.
Has it gone all milky? 600ml is quite a lot.
Electric Bike Project
PostPosted: 12:09 - 23 Nov 2014    Post subject: Re: brake fluid as coolant? (car question) Reply with quote
Has it actually been run since?
If not, it should be limited to the expansion bottle. At this time of year, depending on the engine and use, quite possible the expansion bottle won't be used anyway.
Llama-Farmer
PostPosted: 12:37 - 23 Nov 2014    Post subject: Re: brake fluid as coolant? (car question) Reply with quote
It should be designed that with new pads/shoes all round the level is at the max, and doesn't drop below min before the pads and shoes are at their minimum thickness.
stonesie wrote:
n refill.
Yeah brake fluid is very nasty, assuming it is DOT 4?
I'd turkey-baste it all out the expansion tank first, then drain the rest of the coolant and flush with water before replacing the coolant.
Coolant should ideally be replaced every few years anyway. Long life OAT coolant should last around 5 years. Assuming the engine isn't consuming it.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
SQL
PostPosted: 13:00 - 23 Nov 2014    Post subject: Reply with quote
Are brake seals not rubber Thinking drain it and replace it with de-ionized water/coolant/antifreeze
PostPosted: 13:42 - 23 Nov 2014    Post subject: Re: brake fluid as coolant? (car question) Reply with quote
Have you considered getting a job in bike R&D?
CaNsA
Is it not designed like that already...?
stevo as b4
PostPosted: 14:17 - 23 Nov 2014    Post subject: Reply with quote
Feck the brakes, and worry about your cooling system. You need to be warm in winter, and few people these days take care of their car's cooling system or do the specified interval coolant changes etc.
This is why there's a lot of people in winter, sat in car's cold with blocked heater matrix's air locks in the system, blocked rads, and corroded coolant pipework, leaks, and knackered water pumps.
I've seen some extreme pics of where engine waterways in head's and blocks have corroded away and crumbled/collapsed in extreme cases. You don't want the insides of your car's coolant system to look like an outboard motor that's been run in saltwater for 10years!
Llama-Farmer
PostPosted: 16:30 - 23 Nov 2014    Post subject: Re: brake fluid as coolant? (car question) Reply with quote
In most cases yes.
I have had to top fluid up on a couple of cars with half their pads left which had been at the max mark on new pads. They were both french cars.
Robby
Dirty Old Man
PostPosted: 08:55 - 24 Nov 2014    Post subject: Reply with quote
Inside a cooling system you will find aluminium alloy, steel, and rubber operating over a wide range of temperatures.
Inside a braking system you will find aluminium alloy, steel, and rubber operating over a wide range of temperatures.
Brake fluid is not going to eat your engine. It may react with the coolant and turn into jelly.
Drain the coolant, refill with water, run up to temp. Drain again, refill with coolant, job done.
Llama-Farmer
PostPosted: 11:44 - 24 Nov 2014    Post subject: Reply with quote
Ah but the rubber seals in a braking system are brake-fluid-resistant.
Are the rubber seals and hoses in the cooling system brake-fluid-resistant?
Antifreeze/coolant isn't as nasty as brake fluid, yet the rubber hoses do turn to cack eventually, this may accelerate its cackiness.
Tamsin
PostPosted: 16:09 - 24 Nov 2014    Post subject: Reply with quote
I definately agree with LLama
its not even a particularly difficult job in most cars so why take the risk
The last post was made 11 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 93.39 Kb
