Photography people: advice on shooting products
Jayy
Mr. Ponzi
PostPosted: 17:42 - 23 Nov 2014    Post subject: Photography people: advice on shooting products Reply with quote
I have a business that we sell products, no bigger than about 10cm high by 10cm wide.
I need photos on a white background but the main issue is, I don't have a good camera! Got phones with 8 - 11mp camera but not the best.
Are these any good?
https://www.ebay.co.uk/itm/50cm-Camera-Photo-Studio-Softbox-Box-Light-Lighting-Cube-Tent-Kit-with-Tripod-/130697628635?pt=UK_Photography_StudioEquipment_RL&hash=item1e6e2f8bdb
https://www.ebay.co.uk/itm/Photo-Studio-Softbox-Lighting-Boom-Arm-Soft-Box-Light-Tent-Cube-Backdrop-Kit-/201078979484?pt=UK_Photography_StudioEquipment_RL&hash=item2ed13dbb9c
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
hedgehugger
PostPosted: 18:53 - 23 Nov 2014    Post subject: Reply with quote
We used to use a white shower curtain and a box or 2.
£2 at Asda!
https://groceries.asda.com/asda-webstore/landing/home.shtml?cmpid=ahc-_-ghs-d1-_-asdacom-dsk-_-hp#/product/5525618
Bedside lamp, bendable neck for a bit of extra light.
orac
PostPosted: 18:54 - 23 Nov 2014    Post subject: Reply with quote
paper is you friend in this case I reckon, never used light box myself but have used normal printer paper in several layer raped around card to make small reflectors. you should be able to use normal paper and a bright light to make a soft light source too. providing there are no reflections from the material chosen to construct it.
MP count doesn't matter much either, most phones have only a third of the quoted pixels with a special algorithm that allow each to be used three times. then add in compression and even more compression when it is uploaded to the net.
it is possible to take good pictures with a bad camera, get the environment right and the rest should fall into place with any issue of using your phone
WD Forte
PostPosted: 19:00 - 23 Nov 2014    Post subject: Reply with quote
There's more to it than megapixels
I gave a 14mp camera away to my lad
cos I never grew to like it and it irritated me
and use an old Fuji S600Z I got from freecycle
as my everday camera.
https://fujifilm.digital-cameras-review.org/images/S602Z.jpg
Its a mere 3MP which can be interpolated to 6mp but the thing is
despite this it takes great pics and I love it.
Using it for large sized HD pics would soon show its limitations
of course,
but when you consider most pics are scaled down for web use,
even pics on this camera, I haven't felt any need to upgrade it.
For the OPs purposes, I'd say get a modest camera and tripod!
(keep the camera steady)
and keep the aforementioned background far enough away from the subject so its out of the depth of field.
Side lighting is good if you want to capture as much detail of the
subject as possible (ie all the nooks and crannies without shadow)
bikers smell of wee
moonzoomer
PostPosted: 19:15 - 23 Nov 2014    Post subject: Reply with quote
If your product is reasonably flat you could use a scanner instead of a camera which gives great results on a white background.
PostPosted: 21:04 - 23 Nov 2014    Post subject: Reply with quote
Another vote for paper (or cloth - curtain lining material is probably available locally to you in white and cheap).
For cameras, mp is pretty irrelevant. The oldest dSLR with a half decent lens is probably only 2mp~3mp and likely will give a far better image than your phone. I have seen pictures printed at ~A2 size taken with a <3mp camera.
Get something you can control and get a good controlled lighting source. And a tripod (so you don't have to care too much about shutter speed).
Wonko The Sane
PostPosted: 22:10 - 23 Nov 2014    Post subject: Reply with quote
key thing is lighting,
piece of paper curved as other people have said
some lights on the background to kill off the shadows coming in at about 45deg from each side and then some lighting of the product from the front.
key to good photography is lighting + technique + lighting + set up + lighting Smile
Northern Monkey
PostPosted: 11:49 - 24 Nov 2014    Post subject: Reply with quote
Good lighting is difficult. If you're after cheap, create softboxes out of old boxes, white tissue paper, and desk lamps. At least 2, possibly 3.
bikertomm
PostPosted: 12:41 - 24 Nov 2014    Post subject: Reply with quote
My old Samsung Galaxy S3 (8MP) was brilliant at taking close up images on macro mode. Try that? Thumbs Up
map
Mr Calendar
PostPosted: 12:58 - 24 Nov 2014    Post subject: Reply with quote
FWIW why not have a read of a tutorial online (more here)?
You can make use of the bendy type tripods if you don't hand/need the big stuff (or rest camera on suitable pile of books).
mudcow007
PostPosted: 13:20 - 24 Nov 2014    Post subject: Reply with quote
Voila!
PostPosted: 13:54 - 24 Nov 2014    Post subject: Reply with quote
Any camera can do the job, just make sure you have lots of light, 90% of shit photos(composition aside) taken by everyday people are shit because there isn't enough light.
_Will_
PostPosted: 14:03 - 24 Nov 2014    Post subject: Reply with quote
mudcow007 wrote:
Basically this, desk lamps are fine - the only point I would make to these diy on cheap type deals is that if you are using a phone or naff camera without manual white balance adjustment then use daylight led bulbs.
Suffering Bike Withdrawal.
Jayy
Mr. Ponzi
PostPosted: 23:25 - 24 Nov 2014    Post subject: Reply with quote
Cheers for all the replies!
I know it's not all about MP, was just illustrating that all I have is a couple phones with various MP cameras.
Some of the products could be scanned but I don't really want to do that and a lot of them are cylindrical, so couldn't be scanned anyway.
I already experimented with taping a load of A4 paper together and trying to take photos of them on the paper inside and outside, for different lighting... not to great effect.
Also tried lining a clear plastic box with A4 paper and using lamps either side of it but they were shit because of the lamps.
I'm not trying to do it on the cheap as possible mark, I don't mind spending money on this stuff as it's going to need to be a pretty regular thing taking product shots.
Seen that video of the guy making a light box too, after all the dicking about, I might as well buy one for £17 off ebay Very Happy
I literally know nothing about photography but know the way forward is DSLR if I were to buy a camera.
What's the damage these days on an entry level camera that would be up to this job?
PostPosted: 23:41 - 24 Nov 2014    Post subject: Reply with quote
Basic early dSLR will do the job. For example pretty much any of these:-
https://www.mifsuds.com/acatalog/Used-Canon-Digital-SLR-s.html
While newer cameras are better, the main improvements have been in high ISO (which with a tripod and longer exposure times shouldn't be an issue), faster auto focus (again a non issue for this) and higher pixel count.
Note you will need a lens to go with any of those, and that will probably cost more than the body (lenses hold their value far better than bodies). Strictly speaking you do not need a macro lens, but plenty misuse the description macro for just a lens capable of a vaguely close up shot.
Jayy
Mr. Ponzi
PostPosted: 23:42 - 24 Nov 2014    Post subject: Reply with quote
£50! Where from?
I was just looking at these:
https://www.ebay.co.uk/itm/NIKON-D3200-BODY-REFURBISHED-UK-DEALER-STOCK-1-YEAR-GTEE/191412104501?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D28111%26meid%3D18eb5503d2984fb2834009b54dd82f33%26pid%3D100005%26prg%3D11472%26rk%3D4%26rkt%3D6%26sd%3D311179226055&rt=nc
Jayy
Mr. Ponzi
PostPosted: 23:44 - 24 Nov 2014    Post subject: Reply with quote
So I would need a lens even with the one I just posted? They don't work without them?
Jayy
Mr. Ponzi
PostPosted: 00:18 - 25 Nov 2014    Post subject: Reply with quote
Just bought this: https://www.ebay.co.uk/itm/Nikon-D3200-24-2-MP-Digital-SLR-Camera-Black-Kit-w-AF-S-DX-VR-18-55mm-Lens-/281506827957
That will do! Comes with a lens too and it's un-used. Now I just need a lighting box Cool
PostPosted: 00:32 - 25 Nov 2014    Post subject: Reply with quote
Yes, and although a bit late now to affect your choice you need to make sure you get a suitable lens.
That Nikon lens you are getting has a min focusing distance of 28cm. Depending on exactly what you are shooting it might struggle. Max F number is F22 which should be fine, but the min F number is only 3.5 which might struggle if you want arty shots with the background out of focus. The VR probably won't help much (as you will probably be using a tripod).
Overall it does look like a pretty good lens.
https://www.kenrockwell.com/nikon/18-55mm-vr.htm
Jayy
Mr. Ponzi
PostPosted: 00:47 - 25 Nov 2014    Post subject: Reply with quote
I'm a little "buy it now" happy, should have done more research but it will do the trick in the meantime. I could always sell it if it was impossible to work with but I don't think it will be an issue.
I did scope out the lens and the prices of them new, so seemed like a pretty good deal.
The products are mostly supplements in white flat/cylindrical bottles which need to be on a white background for Amazon.
It doesn't come with a tripod though... this I can actually wait for a recommendation on, I just needed a decent camera fairly quickly.
Another bonus is, I'm a web designer / developer, so I've always toyed with the idea of getting a decent camera and being able to take photos of things in high quality comes in handy sometimes.
PostPosted: 00:51 - 25 Nov 2014    Post subject: Reply with quote
Get a remote shutter release and a half decent tripod (or use the timer on the camera with a tripod). That way you can set the shot up and not worry about the shutter speed being far longer than you can hand hold for.
For example yesterday I was at a model railway show. Spied a journalist taking pictures of a layout using ~8 second shutter speed (and waving a lamp around while taking the image to get reasonable lighting). Not chance you could hand hold it for anything like that long.
The last post was made 11 years, 228 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.24 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 139.21 Kb
