Bandit 600 ~ Bridgestone recommended tyre pressures.
SQL
PostPosted: 11:25 - 23 Nov 2014    Post subject: Bandit 600 ~ Bridgestone recommended tyre pressures. Reply with quote
Got sent this from Bridgestones tech department, could prove useful for others so I have decided to chuck it up for all to view.
orac
PostPosted: 15:31 - 23 Nov 2014    Post subject: Reply with quote
don't bridgestone recommend the same tire pressures across the entire board, like for everything.
I would go of the bikes hand manual if I were you
SQL
PostPosted: 18:31 - 23 Nov 2014    Post subject: Reply with quote
The bikes hand manual pressures are based solely on the oem tyre unless stated.
PostPosted: 18:36 - 23 Nov 2014    Post subject: Reply with quote
Problem is, I've never found tyre manufacturers psi specs that nice to ride on.
I tend to use 36/42 on most things, but sometimes that is just deadly, things like the Varadero had 30/34 regardless of tyre fitted and it was superb.
orac
PostPosted: 18:39 - 23 Nov 2014    Post subject: Reply with quote
so you would ride a GS5 on the same tyre pressure as a R1? I wouldn't. I ran the GS on 38 for solo and 42 for pillion on the rear, don't recall the front off hand.
The 400 I actually run 2 PSI high on the front and Suzuki specs on the rear
SQL
PostPosted: 18:48 - 23 Nov 2014    Post subject: Reply with quote
fyi my tyres aren't recommended on my bike by Bridgestone bt090pro but they work very well, I figured that info would be useful for some, I run 37.5 rear and 34 front.
orac
PostPosted: 18:57 - 23 Nov 2014    Post subject: Reply with quote
OK, just OK, I am not sure I can say much more than that
The last post was made 11 years, 364 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.61 - MySQL Queries: 15 - Page Size: 52.05 Kb
