rear wheel removal (burgman400)
andyscooter
PostPosted: 14:30 - 24 Nov 2014    Post subject: rear wheel removal (burgman400) Reply with quote
Got all the exhaust off
Brake caliper loose ready
I went to undo the wheel with my impact wrench but its not budged it
Any ideas how to undo this but
I'm now thinking half inch breaker bar with the 27mm socket on it
Any other ideas
PostPosted: 15:19 - 24 Nov 2014    Post subject: Reply with quote
Penetrating oil, heat?
I'd say impact but presumably your spinny gun has been doing that.
Might just not have enough torques though, so sure, go with the bar, that's how I got mine off.
One factor in sodding off my Burgman was the hassle involved in doing all of this stuff. Exhaust (snapped a stud) and wheel off just to change the bleedin' pads. Brick Wall
merquis00
PostPosted: 10:51 - 25 Nov 2014    Post subject: Reply with quote
Been there Crying or Very sad on the x9 and DNA - and a side grumble: side cover bolts snapping off and forcing you to drill + re-tap x2 as big Sick
not sure if its the same (or close to it) , but i always used a standard breaker bar/wrench + chunk of scaff tube for the X9's various wheel bolts.
tried a (dodgy) rattle gun once, ended up just spinning me and not the nuts Laughing
Current: 2010 WR125X, Carrera crossfire-E.
Project's: '88 GL1500 Trike, Chinese 170cc Monkey
Previous: X9-500, XT125, DNA125, CBF125, YZF-R125, '98 K1200RS, '99 St1100, fantic245
andyscooter
PostPosted: 11:53 - 25 Nov 2014    Post subject: Reply with quote
Just tried with me on bike with brake on and mate with a wratchet
No go so bar coming later
(Side note wouldn't be a reverse thread would it)
PostPosted: 13:18 - 25 Nov 2014    Post subject: Reply with quote
Don't think so, but it's apparently 87 foot-torques to remove it (and the rest).
map
Mr Calendar
PostPosted: 13:27 - 25 Nov 2014    Post subject: Reply with quote
andyscooter wrote:
...No go so bar coming later...
To misquote (ish) Archimedes...Give me a lever long enough and I will move the world.
Funnily enough daughter's Vespa rear wheel as always been a sod to remove. Usually achieved with a group effort of much swearing, someone applying brake and sitting on it and a metre long breaker bar from Halfords. I must really get something to extend that bar.
andyscooter
PostPosted: 08:46 - 26 Nov 2014    Post subject: Reply with quote
as mate didnt turn up with his bar ive had to order one
will be usful to have one anyway
ive ordered a 750 mm sealey one should be here tomorrow
mudcow007
PostPosted: 09:06 - 26 Nov 2014    Post subject: Reply with quote
scaffolding tube on the end of your rachet, bit ghetto, but works a treat
merquis00
PostPosted: 11:23 - 26 Nov 2014    Post subject: Reply with quote
A ratchet strap on the rear brake lever+handlebar (scooter) works for those of us with no friends Mr. Green
PostPosted: 11:34 - 26 Nov 2014    Post subject: Reply with quote
Personally I'd have left the brake caliper on, then got a mate to hold the brake on while I try to crack the bolts off with a breaker bar. But that's just me. I'd have then probably hit the breaker bar with a rubber mallet maybe.
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Jefr0
PostPosted: 12:49 - 26 Nov 2014    Post subject: Reply with quote
What I sometimes do is get the socket on there with a normal sized bar and pull it down to tension it as much force as I can. Then a friend hits the end of the bar with a hammer, much like the impact wrench would do.
But I favour a breaker bar over this, makes a meal of it and wouldn't recommend hitting a ratchet with a hammer!
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
temeluchus
PostPosted: 15:34 - 26 Nov 2014    Post subject: Reply with quote
You do not need to take off the brake caliper on a burgman. The disc is on a separate carrier and not fixed to the wheel.
bungie the brake lever down and get a breaker bar on the nut.
andyscooter
PostPosted: 12:30 - 29 Nov 2014    Post subject: Reply with quote
Thanks all
Got the fucker
Brake on (burger has a handbrake)
Tried to start with no use
Lost me temper and pulled rather then pushed and it cracked off
Wheel is in hall ready to go for changing
The last post was made 11 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 78.94 Kb
