Kawasaki GT550
Sheltieboy
PostPosted: 22:41 - 22 Nov 2014    Post subject: Kawasaki GT550 Reply with quote
I recently bought a 1988 gt 550 to play with over the winter
I've taken the sump of to check for particles and discovered that the chain thats driven off the crankshaft is pretty slack, about an inch of up and downwards play.. Is this normal??? And if not how to adjust it if its possible
Thanks
map
Mr Calendar
PostPosted: 23:29 - 22 Nov 2014    Post subject: Reply with quote
Adjuster is a weak point. Supposed to be automatic adjust. It does not always work.
Sheltieboy
PostPosted: 01:47 - 23 Nov 2014    Post subject: Reply with quote
Just to be clear, its no the cam chain, it's the drive chain on the crankshaft that drives the output shaft(i think)
Chuffin Nora
PostPosted: 16:05 - 23 Nov 2014    Post subject: Reply with quote
the tool
https://i.ebayimg.com/00/s/MTYwMFgxMTYy/z/uDYAAOxyGqZSZ54F/$T2eC16J,!)QFIbyo+IgtBSZ54EhW5!~~60_35.JPG
the absence of which
a spanner thrown
into the works
Procure.
And/or -- the clue being in the forum title:
The Workshop
Technical discussions and mechanical advice. Need help with your bike?
where you'll find a host of helping hands for tools who've not the capacity to do things by the book.
arf
Nemo
PostPosted: 01:10 - 24 Nov 2014    Post subject: Reply with quote
I don't know the engine internals so this is complete guess work/what would make sense to me.
Maybe it uses a hydraulic tensioner that requires oil pressure to keep the correct tension?
Just a thought.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Sheltieboy
PostPosted: 19:13 - 24 Nov 2014    Post subject: Reply with quote
I had a good look but see no sign of a tensioner on the primary chain
PostPosted: 21:36 - 24 Nov 2014    Post subject: Reply with quote
I presume you are taslking about the HiVo chain 92057
https://d136nqpz68vrmx.cloudfront.net/schematics/schematics/kawasaki/kaw020/KA0107011014.gif[/img]
AFAIK there is no tensioning device on this.
Triumph Trophy Launch Edition
Sheltieboy
PostPosted: 22:53 - 24 Nov 2014    Post subject: Reply with quote
Thats the one
Didn think there was a tensioner on it
Its a bit slack about 15-20 mm of play but i see the apparent tolerance quoted is 25mm max so might be ok for a few miles yet!! I hope
Sheltieboy
PostPosted: 22:55 - 24 Nov 2014    Post subject: Reply with quote
P.S. Can this chain be changed without stripping down the engine, i.e pulling the rear shaft??
PostPosted: 12:24 - 25 Nov 2014    Post subject: Reply with quote
Pretty sure its an engine strip down. I wouldn't change it if its within tolerance unless you were stripping it down for some other reason.
davebike
PostPosted: 13:47 - 25 Nov 2014    Post subject: Reply with quote
It is a total strip and the chain is not cheap £34.97 + vat and surprising still listed
Unless it unbearable I just leave it they all rattle clatter but just run on
Dave
NC750Xdct + others at work !
[email protected]
Islander
PostPosted: 14:02 - 25 Nov 2014    Post subject: Reply with quote
What Davebike said. My OH's ZR750 primary drive chain clatters like a good 'un when cold and quietens down a bit when it's warmed up. It's a crankshaft out job to replace it so it can carry on clattering as far as I'm concerned. Razz
The last post was made 11 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.53 - MySQL Queries: 13 - Page Size: 70.8 Kb
