2003 Suzuki RV125 "Van Van" voltage regulator help
timothygstoke...
PostPosted: 16:09 - 24 Nov 2014    Post subject: 2003 Suzuki RV125 "Van Van" voltage regulator help Reply with quote
Hi all,
my brother is having some trouble with his headlight on the aforementioned motorbike. The wiring loom to the headlight keeps frying, with no obvious electrical short. Now, me and my dad both suspect that the voltage regulator is faulty. Is this an accurate diagnosis, or could something else be at fault? Any help is appreciated.
Cheers,
Tim
Riding a Honda CG125
timothygstoke...
PostPosted: 17:21 - 25 Nov 2014    Post subject: Reply with quote
unitynotsocrippledatmo wrote:
It may be a mixture of things. Check the switchgear is original and the alternator wires have not been bodged. Water in the headlamp shell won't help. You could test it to see if it blows when the lights are used.
If there's a regulator problem then check the battery voltage ...running and then not running, and disconnect the battery and check again.
If your bike uses a ballast resistor I'd check this first.
Also check engine earth and look inside indicators for water/ corrosion on the bulb pins......headlights as well. And......check there's no wiring frayed or trapped under the seat/ panels.
Cheers, I'll pass on this info to my brother
Cheers,
Tim
The last post was made 11 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.79 - MySQL Queries: 14 - Page Size: 37.44 Kb
