confused on why my bike cuts out in the rain
barnesy213
PostPosted: 15:34 - 25 Nov 2014    Post subject: confused on why my bike cuts out in the rain Reply with quote
hello people, well as the topic suggest's i have a problem with my bike cutting out ,, its a honda cbr 125r 2009 version (fuel injection)
quite recently it has been cutting out in the rain (not that i ride much in the rain) but its quite a pain as it won't start for ages after its cut out
its had a new spark plug and spark plug cap , and still to no a-vale , it also has a non standard danmoto exhuast on it
if any one has any suggestions as to why this could be happening please post below thanks guys and gals
c_dug
PostPosted: 15:40 - 25 Nov 2014    Post subject: Reply with quote
There's probably water getting somewhere that shouldn't get wet.
barnesy213
PostPosted: 15:54 - 25 Nov 2014    Post subject: Reply with quote
yeah thats what i'm thinking but dont know where lol i was thinking of changing the exhaust gasket but carnt really see that being the cause of it
andyscooter
PostPosted: 15:57 - 25 Nov 2014    Post subject: Reply with quote
what sort of air filter is on it
i had a bike do that with a pod filter as the water went into the carb
c_dug
PostPosted: 15:58 - 25 Nov 2014    Post subject: Reply with quote
I really very much doubt it is the exhaust gasket. You would need to get a serious amount of water in the exhaust to make it cut out.
More detail needed really. How does it cut out, dead stop, misfire for a while first? Does it do it while you're moving or stopped? How soon can you get it started again (ages isn't very specific)?
barnesy213
PostPosted: 16:04 - 25 Nov 2014    Post subject: Reply with quote
is the standard airfilter that comes on the bike
barnesy213
PostPosted: 16:08 - 25 Nov 2014    Post subject: Reply with quote
basically you will be going along and it will start popping and banging ,and then the engine will die , the bike will turn over but wont start for like 20 mins, (this was on the way to where i work ) parked it in the carpark and after a 10hr shift went back to the bike and started as if nothing had happend
c_dug
PostPosted: 16:17 - 25 Nov 2014    Post subject: Reply with quote
I think you were probably along the right lines with the new sparkplug cap (though I wouldn't have jumped on it as a first reaction). I'd suggest a liberal coating of WD40 around the general area for starters.
I presume the new cap came with the rubber seal that prevents too much water getting to the area? Is it in good condition?
Also I presume your front mud guard is present and unbroken?
map
Mr Calendar
PostPosted: 16:19 - 25 Nov 2014    Post subject: Reply with quote
Popping and banging is reminiscent of reg/rec failing on my old CG.
So coupled with added water maybe that's an area to investigate?
Also I'm reminded of the thread about cbr500 flasher failing due to water damage (here). Maybe new Hondas aren't as waterproof as old ones? Confused Thinking
barnesy213
PostPosted: 16:46 - 25 Nov 2014    Post subject: Reply with quote
going to get a local honda garage to look at it as ive not go no experience with electrics so i'd rather pay for someone who knows what they are doing
and yes the cap came with a new rubber boot and its all in good condition and the front mudguard barely has a scratch on it lol so id presure its not broken in any way
and i did try spray everything with wd40 but that was no good as it still did the cutting out issue
bypass2
PostPosted: 17:48 - 25 Nov 2014    Post subject: Reply with quote
What about the rain getting in to the kill switch or the side stand switch.
barnesy213
PostPosted: 18:15 - 25 Nov 2014    Post subject: Reply with quote
the bike does not have a kill switch and as for the side stand switch, i dont know if water is getting in there or not , but i suppose its a possibility
cheeseman
PostPosted: 20:04 - 25 Nov 2014    Post subject: Reply with quote
Sounds almost certainly like a fault with the HT side of the ignition to me. As suggested, you could try drowning the lead, caps and coil in WD40 to see if it helps. You could have a crack in the casing of the coil, or a failed HT lead that is shorting out when damp.
Only way to really sort out a problem like this is replace each component at a time, or to save time, replace everything on the HT side.
You could also try working out which parts are getting most damp when it is raining.
G.
smegballs
PostPosted: 21:06 - 25 Nov 2014    Post subject: Reply with quote
Most of the electrical connectors, especially ignition circuitry, on my GN has been cleaned up and reassembled with silicon grease since I got it. All I know is that it put up with 4+ hours of torrential (as in, rain cutting down visibility to about 100m) rain and never skipped a beat.
Of course I can't say how the bike would have done if I hadn't siliconified the connectors, but in my eyes it defo helped.
ZebraDriver
PostPosted: 22:07 - 25 Nov 2014    Post subject: Reply with quote
My sons Honda CLR used to cut out and missfire in the rain. I tried all kinds of stuff to correct the problem. One day when I had the tank off (for another reason) I found that the spray coming off the back of the front wheel was aimed directly at the coil (the coil was covered in dirt and mud). A wee mudflap on the back of the mudguard cured the problem.
Mark65
PostPosted: 11:50 - 26 Nov 2014    Post subject: Reply with quote
Without intending any insults, has your plug cap got both rubber pieces on it and are the good and tight?, I had this when I got my CG and it spluttered and died in heavy rain, put a new NGK plug cap on and its been fine ever since, I think they will degrade over time and use. It cost about £3.
Mark
talkToTheHat
PostPosted: 13:24 - 26 Nov 2014    Post subject: Reply with quote
I used to have a similar problem on my yamaha whereby the 12v side of my ignition coils and the connecting wires would get soaked in the rain and stop working. Locate and spray with wd40. Look for any exposed connectors, spray with wd40, see if this helps. once you have found the parts of the system that are vulnerable, protect with "damp start" or appropritate grease, or replace connectors with waterproof connnectors.
I found the ugly but practical addition of a pyrimad plastics fenda extenda works really well. Apparently this also helps with the front plug on an sv650. might work for you, but find the problem first.
Try not to kill yourself by experimenting in heavy traffic. Losing a cylinder on a twin in heavy traffic on a dual carriageway with no hard shoulder is scary enough, losing a cylinder on a single is probably worse.
Bandit. does. everything.
c_dug
PostPosted: 13:30 - 26 Nov 2014    Post subject: Reply with quote
On a related note to this, I have seen two CBF's at the side of the road in heavy rain in the last month or so. Both on the A13 so possibly the same person both times.
Still, IMO there's more nails than wood in the CBF's coffin these days!
barnesy213
PostPosted: 14:49 - 26 Nov 2014    Post subject: Reply with quote
yes all the boots on that spark plug cover are the same on mine , its the same brand infact and no offence taken, i know how easy it would be to perhaps put a little tear in it
WULFSTAN
PostPosted: 19:39 - 26 Nov 2014    Post subject: Reply with quote
barnesy213 everyone is saying spray all wires with wd40 have you done this?
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
barnesy213
PostPosted: 05:34 - 27 Nov 2014    Post subject: Reply with quote
[quote="WULFSTAN"]barnesy213 everyone is saying spray all wires with wd40 have you done this?[/quote]
yes i have done this and still the bike cuts out
The last post was made 11 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 114.46 Kb
