Car related: Focus mk1 alternator woes
Slacker24seve...
PostPosted: 13:41 - 25 Nov 2014    Post subject: Car related: Focus mk1 alternator woes Reply with quote
For the second time this year, the alternator on my focus has a whiny bearing.
The first time round I replaced it with a reconditioned one. It has lasted about 7k and is now whining again.
Is this indicative of another problem? The belt and tensioners seem fine. Should I have replaced them too?
Before I go and spunk £80 on a new one, is there anything else I should look at first?
Banger rallies are ace
Islander
PostPosted: 14:05 - 25 Nov 2014    Post subject: Reply with quote
Have you tried gagging your OH to eliminate extraneous noise? Razz
More seriously, can't you just replace the bearing?
Taught2BCauti...
PostPosted: 15:15 - 25 Nov 2014    Post subject: Reply with quote
As mentioned - Aux Belt too tight can cause bearing noise and rapid wear.
Also, overheating (possibly due to a battery fault) can cause bearing grease to cook-off.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Slacker24seve...
PostPosted: 20:28 - 25 Nov 2014    Post subject: Reply with quote
Hmmm. You may have a point there re: battery fault. Whilst I never have trouble starting, the lights are too flickery for my liking at idle. I'll investigate with the multimeter.
Re: replacing the bearing, I'm going to try that first as I still have the old alternator.
Bikeless
PostPosted: 22:55 - 25 Nov 2014    Post subject: Reply with quote
Aux belt can't be overtightened in theory,i uses an automatic tensioner.
MattEMulsion
PostPosted: 08:11 - 26 Nov 2014    Post subject: Reply with quote
Firstly, with a recon alternator you are not buying a 'new' product so it could quite easily have shat the (old) bearings in it within 7000 miles. That's the luck of the draw.
Secondly, unrelated but on a Focus make sure that you are using a calcium battery. Fords of this era have smart charge alternators which see the battery peak charging hit 17v. Hence why a normal lead acid battery will die quite quick and it will also cause strange electrical issues too.
Yamaha YZF-R6
Bikeless
PostPosted: 10:38 - 26 Nov 2014    Post subject: Reply with quote
https://www.yuasa.co.uk/info/technical/silver-calcium-batteries/
Llama-Farmer
PostPosted: 11:40 - 26 Nov 2014    Post subject: Reply with quote
How long was the replacement alternator off the original car before being fitted to yours?
Could be that it started to seize ever so slightly hence the noise.
Otherwise I'd say its probably belt tension.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
Aff
PostPosted: 17:46 - 26 Nov 2014    Post subject: Reply with quote
Vincent wrote:
If it's not the belts, maybe the recon people are using shite bearings - 'wouldn't be surprised. Replace with a decent one.
This seems most likely to me.
Can you see what bearing they used?
Electric Bike Project
Slacker24seve...
PostPosted: 22:08 - 26 Nov 2014    Post subject: Reply with quote
No idea. It was an unfitted spare bought by someone else on eBay, it was £40. It's provenance is unknown, but it was immaculate when I bought it. It was too cheap at the time to not give it a go.
I can't find anything in the service history to suggest when the battery was replaced. It's dark and rainy outside so I'll find out some more tomorrow eg, if it's Calcium. That's not the first time I've heard that Matt.
As for the belt itself, as No Blade says, it's an auto tensioner.
BCF delivers, again!
Bikeless
PostPosted: 22:20 - 26 Nov 2014    Post subject: Reply with quote
I wouldn't worry too much about using calcium batteries,I've always had Fords and never used one,batteries last in excess of 6 years,last one about 10 years,just a normal exide 3 year one.
The last post was made 11 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 82.49 Kb
