BikeSafe on a CBT or Lessons
LustyLew
PostPosted: 11:27 - 26 Nov 2014    Post subject: BikeSafe on a CBT or Lessons Reply with quote
So,
the o/h has now had two offs on his 125. He's has a CBT for about 8/9 months. I'm unsure on the circumstances as I was not there either time, but the front tyre does look a little shonky.
He's stated he wants more training as 'something must be going wrong'... My own suspicion is that it's just a combination of being tired, roads are wet and it's dark.
I've checked and BikeSafe run by the Met do allow CBT riders.
What do you guys think? Save the £45 to put towards lessons and a full license? Or get BikeSafe first?
He does want to get his full license before Summer 2015.
map
Mr Calendar
PostPosted: 11:52 - 26 Nov 2014    Post subject: Reply with quote
With BikeSafe if they're not many 125s he may have problem keeping up and with the overtakes. Depends on the route(s) used and how they do the groups.
Also BikeSafe is more for tuning your riding rather than outright training. So not sure if appropriate if already too many rough edges. Although it's only a quick ride out, not really IAM or RoSPA training stuff. I'd say something is better than nothing though so may be worth it.
I'd probably opt for some training though first. Maybe consider a trial observed ride with the likes of local IAM bike group (they're usually free or just contribute fuel cost of observer). Check if they do them though over the winter shutdown period. That could identify riding points that need some work. Then go from there.
HTH Thumbs Up
esullivan
PostPosted: 12:35 - 26 Nov 2014    Post subject: Reply with quote
Remember that BikeSafe isn't training. It's an assessment that's supposed to be used in subsequent training. They start with the assumption that you've passed your test and aren't dead yet, so the pointers are pretty basic and tame, and they will only mention really dangerous stuff.
I did the Met one, starting at the police station on the north side (M1). You go out on the roads with one police and two riders. The guy I was partnered with had a very weird riding style where he splayed both his legs out like an albatross coming in for a landing, at anything under 30mph. He never, ever used the back brake. For anything. He also had a tendency to ride in the right lane of a dual carriageway at well under the speed limit.
From the perspective of a traffic copper, who might have to scrape his carcass off the road at some point, none of this was a problem. He never mentioned either issue. He focused on positioning around bends and lifesavers. They were good points -- it wasn't a waste of a day -- but it also wasn't training.
Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
PostPosted: 12:43 - 26 Nov 2014    Post subject: Reply with quote
Buy better tyres or a brighter bulb.
Minty
PostPosted: 12:49 - 26 Nov 2014    Post subject: Reply with quote
Gor for a ride (steady on Hand ) one evening, in the wet and offer what guidance you deem necessary. It could be glaringly obvious he is doing a few things wrong.
My fingers smell of your mum.
map
Mr Calendar
PostPosted: 12:52 - 26 Nov 2014    Post subject: Reply with quote
Rogerborg wrote:
Buy better tyres or and a brighter bulb.
Perhaps that would be a better solution.
fatjames
PostPosted: 13:00 - 26 Nov 2014    Post subject: Reply with quote
I tend to agree with what's been said already. I'd also suggest checking his tyre pressures.
Following him I think is a good place to start, you'll be able to see when he's coming on the brakes and you might be able to offer some advice. If not, training then full test and then roadsafe.
I'd recomment roadsafe for you too (or anyone), it's good fun, helpful and very good value for money. In fact, the first aid training was worth my £25 alone.
LustyLew
PostPosted: 13:59 - 26 Nov 2014    Post subject: Reply with quote
Thanks for the advice!
I've seen the pics, nothing major was damaged, headlight bracket is a bit wonky (two days prior to the MOT). The tyre is made by Chen Shing... So doesn't ooze confidence. When I first saw the front, I thought it was from the 70's. Luckily I have a day off Friday so will sort out his front end (fnar!) and get the tyre replaced.
Any recommendations for Riding Schools in SE London? O/H is a school teacher, so kind of limited. If I could buy vouchers to put towards training then he can book it when it suits...
Thanks again!
ScaredyCat
Bikesafe is pointless in this instance. It's not for people on their CBT, without a full license.
More training, better tyres, better bulb (although 125 lights are dire anyway) much less grabby-graby-breaky-breaky and much more looky-looky-many-anticipation.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
map
Mr Calendar
PostPosted: 14:05 - 26 Nov 2014    Post subject: Reply with quote
ScaredyCat wrote:
...better bulb (although 125 lights are dire anyway)...
Could add some extra to a 125 for unlit road sections. Really need to fit via relay and extra switch but battery should handle it, especially if go LED route (there's been recent threads on here iirc). If bike has crash bars (leg protectors) then a useful mounting point (low(ish) so illuminate road rather than blind any oncoming traffic).
ScaredyCay wrote:
...much less grabby-graby-breaky-breaky and much more looky-looky-many-anticipation.
Which is why I think an IAM evaluation would be useful.
talkToTheHat
PostPosted: 15:13 - 26 Nov 2014    Post subject: Reply with quote
If he's going for full licence training, bikesafe will be counterproductive as they will encourage advanced techniques that may be test fails, particularly as far as road positioning goes. Train for test, pass test, get bike with some go, do bikesafe and/or join IAM.
Oh and get the front tyre checked. It is the most important part of a bike.
Bandit. does. everything.
Minty
PostPosted: 15:42 - 26 Nov 2014    Post subject: Reply with quote
More important than the engine? Brakes? Chain?
Dave70
PostPosted: 15:43 - 26 Nov 2014    Post subject: Reply with quote
After I'd been riding around for about a year or so, I paid an instructor to follow me riding around on the road for an hour, just to assess my riding. I found it quite useful and thankfully there wasn't anything major worth mentioning, just a few little pointers here and there.
Your OH would probably find it pretty helpful too.
davebike
PostPosted: 17:00 - 26 Nov 2014    Post subject: Reply with quote
It not really what BIkesafe is for
I say talk to one of the local schools about getting a lesson or two
Most are not that busy at this time of year and can do odd bits
Where did he do his CBT??
Dave
NC750Xdct + others at work !
[email protected]
civvy
PostPosted: 17:28 - 26 Nov 2014    Post subject: Reply with quote
HTH Thumbs Up
Some groups (or even local councils) are even offering the entire "Skills For Life" package for free to younger riders.
Better to go get the lessons/full licence first though, as some of the road positioning etc that they'll encourage may not be seen in the same way by the DSA examiner.
Former: CG125, SV650S, YZF600 Thundercat, Sprint ST 1050
Written off by a van driver more interested in sat nav than the road: VFR800
Current: Honda VFR 750 / Yamaha XJ600 Diversion
davebike
PostPosted: 17:40 - 26 Nov 2014    Post subject: Reply with quote
I don't think any IAM group will take a rider on L plates
Not least as the Advanced methods are not test acceptable (go figure that )
And yes I know what I am talking about only quit observing pearler this year after 15 years
The OP needs lessons from instructor who is used to working pre test
Friends can help with a conference ride but be careful not to learn their bad habits
Dave
[email protected]
wr6133
PostPosted: 17:52 - 26 Nov 2014    Post subject: Reply with quote
Pfft.... everyone knows the most important part is rim tape
map
Mr Calendar
PostPosted: 17:54 - 26 Nov 2014    Post subject: Reply with quote
You're wrong. It depends on the colour. Ask any woman.
talkToTheHat
PostPosted: 13:06 - 27 Nov 2014    Post subject: Reply with quote
Yep, pretty much every failure mode of front tyre has a high risk of injury and given the it looks shonky stage has been reached, further fail is likely catastrophic. Engine fail is more often that not a won't go fail or gives some kind of warning. Seizing out of the blue is rare. A bike can be ridden with only one brake but is suboptimal and if failure happens during critical braking then its probably bad. Chain failures can be high energy so that's fairly important. But I'm going to say that the most inevitable pain is from a font tyre giving up traction whilst it is being relied on.
Minty
PostPosted: 14:01 - 27 Nov 2014    Post subject: Reply with quote
Lowside < Highside.
Would much rather lowside my bike than highside it. Each to their own I guess.
FriendlyEllis
PostPosted: 06:39 - 28 Nov 2014    Post subject: Reply with quote
You mention his front tyre.
Unless it's cracked plastic or he's hooning along its more likely it's grabbing the front brake thats causing loss of grip.
Dark..... under estimates corner..... Lack of confidence....grabs brakes.
You know.... that ol' chestnut!
Pass test, then further training.
Not directed at this post at all but..... It amazes me that some bikers try their abosulute best to not have any additional training somehow believing that they can self train to a high level.
Honda CB600F Hornet 2013 -> Kawasaki Z1000SX ABS Tourer 2015
talkToTheHat
PostPosted: 13:53 - 01 Dec 2014    Post subject: Reply with quote
Minty wrote:
Lowside < Highside.
Ok, I'll concede that.
iooi
PostPosted: 16:01 - 01 Dec 2014    Post subject: Reply with quote
Really should not be the case...... Shocked
davebike
PostPosted: 12:58 - 02 Dec 2014    Post subject: Reply with quote
Been that way for years !
Remember DSA not whatever are Civil servants few if any of the senior guys will be experienced driver and even fewer motorcycle riders
And the same applies to the politicians that are supposed to run team
Common sense is not part of the UK Civil service job description Let alown and specialist skills !
Dave
[email protected]
The last post was made 11 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 129.67 Kb
