Dyno graphs
chickenstrip
PostPosted: 10:37 - 27 Nov 2014    Post subject: Dyno graphs Reply with quote
Do they tell you all you need to know about how a bike will deliver it's power? Can you look at one and say, right, there'll be a noticeable "kick" at such-and-such revs that you'd feel when riding?
Or to put it another way, can you look at a dyno chart of a bike you've never ridden before and say, "this is how it will feel to ride?"
I'm dubious that you can, and what I've seen so far, going by the bike I'm most familiar with, bears me out. If I'm wrong, I'd like to understand why.
talkToTheHat
PostPosted: 11:46 - 27 Nov 2014    Post subject: Reply with quote
Not with the one graph, they'll typically show what happens at WOT. Won't tell you anything about what happens as you roll on in terms of smoothness and controllability, or anything about part throttle or engine braking behaviour. For most usages, part and varied throttle performance and engine braking behaviour defines how the bike feels to ride, along with chassis characteristics that govern how the bike stops and goes. The same engine that causes a short high bike to rear up and punch you in the chest/face might feel much tamer in a longer and lower bike.
One can programmatically study a set of transitional behaviours on a decent research dyno where the test equipment receives engine rpm and can sent throttle inputs, but you will get much more data than a simple torque/power graph. This is done extensively durning modern engine development, usually in conjunction with data from the air intake, exhaust gas analysis and noise analysis.
Specific example: pumper carbs give you instant enrichment during a wind on, CV carbs briefly lean out, at constraint full throttle there will be little difference yet the feel of the engine will be totally different.
Bandit. does. everything.
PostPosted: 12:26 - 27 Nov 2014    Post subject: Reply with quote
Interesting stuff.
talkToTheHat wrote:
XV535 on 33 horses
Wut?
Bikeless
PostPosted: 13:30 - 27 Nov 2014    Post subject: Reply with quote
To a degree yes but when I had the Fireblade,a change of 122 jets down to 116 jets gave it 5 more horsepower and a better curve but it felt less powerful when riding it,putting the 122s back in made it feel more powerful even though the dyno said otherwise.
PostPosted: 14:32 - 27 Nov 2014    Post subject: Reply with quote
What other throttle position is of relevance Confused.
I would agree that it might not show things like abrupt fuelling response from a less than perfect FI system, or the carb example.
As suggested in a thread recently, I would suggest it shows closer to 'the truth' than most people will analyse themselves with their backside.
If power is making a short bike come up, it's going to make a longer and lower bike accelerate even faster.
PostPosted: 14:46 - 27 Nov 2014    Post subject: Reply with quote
Dy/Dx Thumbs Up
chickenstrip
PostPosted: 19:09 - 27 Nov 2014    Post subject: Reply with quote
Ok G, here's what the dyno graph doesn't tell you: how quickly the power increases with the revs*, in other words, over time. All it tells you is what power it is making at any given revs, not how quickly the motor spins up at any point when the throttle is opened. ??
*not well worded. More, how quickly the revs rise over time. So a better graph might be revs/time on opening the throttle, to give an idea of how it will feel to ride.
PostPosted: 20:11 - 27 Nov 2014    Post subject: Reply with quote
Yes, it does.
At least, if you know other factors such as gearing, weight, wind resistance and so on, or are willing to assume they are similar enough between two compared models to not be of worry.
Gearing is one that people often bring up; explaining how an SV650, say, has loads of low down power compared to an R6.
But then we see that's it's actually geared 50% lower; it feels like it's got more power low down in the rev range actually because it's lower geared - the R6 would quite likely have more if you geared it to be the same as the SV.
This is basically the exact information a power graph DOES give!
stevo as b4
PostPosted: 21:07 - 27 Nov 2014    Post subject: Reply with quote
Chickenstrip, I kind of understand what you mean and also what G is referring to.
The backside in the seat dyno is very innacurate and the potential for the sunny day placebo effect is massive too. 5bhp +/- would on a big bike be impossible for your arse to measure.
The dyno does show very well how a bike makes it's power over the rev range, (have a look at a tuned RG500 dyno chart if you want to see how dramatically it can show the rate of power increase) Wink
100% throttle pulls in a fixed gear give an overall indication of the engine's delivery and how it pulls over the rev range.
50% throttle runs also show stuff like how long it's making over a set bhp across the rev range etc (area under the curve)
An all gears run can show the thrust and torque developed at the rear wheel through the gears, and also how the gearing affects the thrust available etc. I think this is what G is often referring to when he pulls out his big twins vs IL4 litre charts! Laughing
PostPosted: 21:18 - 27 Nov 2014    Post subject: Reply with quote
What is better for knowing how the bike feels is to look at the torque curve rather than the power curve. Power can be increasing while torque is dropping away (will happen with pretty much any bike), and it is the change in torque that you feel.
chickenstrip
PostPosted: 21:33 - 27 Nov 2014    Post subject: Reply with quote
I'm actually not saying G is wrong, but I think he has missed my point.
https://i1291.photobucket.com/albums/b550/nicknicklxs/FZS1000withIvansFullMontyBMCfilterslip-oncanG-Forceportedcarbrubbers_zps55522230.jpg
This is the dyno curve for an FZS1000 in a pretty much identical state of tune to mine. You can see that it's very linear, maybe just a very slight step just over 7k rpm. But this belies what you feel when pinning it through that rev range on the road. Then, the step at 7k feels very marked, not something you'd be thinking "am I imagining this?" It gives your arms a very noticeable yank, and especially as you're sat pretty upright, you have to hang on tight. The rear end squats and the thing takes off. And I know plenty of people with the same bike tuned thus who would agree with this. And once given this dyno graph, the fact that the bike is not stock is immaterial for illustrating my point.
I'm not trying to compare it to any other bike, and I fully agree that if you know the gearing, the weight, what kind of traction the rear tyre gets and the aerodynamics of the bike, you are probably quite well placed to predict how it will feel on the road. All I'm saying is that the dyno curve alone does not tell you to expect this. This is my point. You would be better served with a graph of revs/time to show what actually is happening as far as the measured acceleration of the bike is concerned..........
Very Happy
I think..... Thinking Laughing
PostPosted: 22:59 - 27 Nov 2014    Post subject: Reply with quote
I would, respectfully*, question whether you understand the concept of 'power'. I might also suggest that maybe you need to work out if you ARE 'imagining' this! Wink
Is this with a most definitely wide open throttle?
A lot of people don't hold throttle wide open when they think are - I know I've been guilty of this in the past.
Could it be something to do with a TRE style device that only works in certain gears?
In the end power torque/power pretty directly relates to the acceleration possible by the engine - this is why people make the graphs with these figures.
*Some may ask if this is actually the case.
PostPosted: 23:19 - 27 Nov 2014    Post subject: Reply with quote
Very smooth power curve. If it is still running like that then there shouldn't be any real kick in the delivery, but plenty of things could change that would cause a kick (such as the EXUP valve sticking - or pegged open).
This is a bit more fun:-
https://www.bikegraph.co.uk/TorqueGraph.php?Id=19&x_max=800&y_max=500
PostPosted: 23:21 - 27 Nov 2014    Post subject: Reply with quote
It's not hard to envisage the distinction between power and torque. Torque is 'effort made', it's the actual levering force turning the wheel (via gears).
Power is 'work done' or 'effort made over time'
chickenstrip
PostPosted: 23:26 - 27 Nov 2014    Post subject: Reply with quote
Hey, I don't claim to be a world authority on this, I could well be wrong Laughing
You've now got me wondering...
Unfortunately, I still can't bend my knee enough to ride for the moment, so this is something I'm going to have to revisit when I can Smile
Keith, that looks mad! But no, EXUP is working fine - the dyno print isn't of my actual bike, just one in near identical state of tune, and the curves from such bikes are pretty consistent.
Anyway, power characteristics aren't the only thing that decide whether a bike is fun to ride or not Razz
PostPosted: 23:33 - 27 Nov 2014    Post subject: Reply with quote
Riding the bike the power came in at 9500rpm. Red line at 10000rpm. Power finished at 11000rpm. When you are in the mood it was great fun.
As to using full throttle, quite easy to not use full throttle without noticing. Can't remember the exact figures, but seen a few articles where data logging has shown how little of a lap top class racers are actually using full throttle for.
PostPosted: 23:41 - 27 Nov 2014    Post subject: Reply with quote
Depends on the bike and track, I would expect.
Put them on the above 140hp road Fazer at Lydden sure; stick them on a Honda RS125 at the old Snetterton circuit and it's rather a different matter.
On the pit bike at Lydd I was finding I really neded to be on full throttle more - from the apex of a lot of corners until just before the entry of the next corner generally!
chickenstrip
Not the best thing for a Monday morning commute after a heavy Sunday night huh? Laughing
I imagine something like maybe 3/4 of any long-ish straight or thereabouts? Straights is what I'm thinking about with how power delivery feels I guess. Not like you want to hit a big step in mid corner Shocked
PostPosted: 00:03 - 28 Nov 2014    Post subject: Reply with quote
Over a lap from memory the figures were around 5% of the time
talkToTheHat
PostPosted: 17:56 - 01 Dec 2014    Post subject: Reply with quote
Rogerborg wrote:
talkToTheHat wrote:
Much competent engine babble
Interesting stuff.
talkToTheHat wrote:
XV535 on 33 horses
Wut?
Get over it.
Family has a Motorsport background. Learnt to fabricate 2 stroke kart exhausts and operate sufficient machine tools to build replacement parts for RC cars. Some success racing them. Did undergrad Automotive Engineering. This included a chunk of time fiddling with simple dynos and far more time contemplating test programs and the resultant data from more sophisticated dynos. Ever played with a research engine with a continuously variable compression ratio? I have. Was pretty infuriating really as I couldn't get the damned thing to knock infront of the freshmeat I was demonstrating it to. Did minor bits with formula student. Found some brief part time work with local automotive firms. Enjoyed programming the programmables more than bolt counting, endless cad-wrangling and worse, dealing with people who couldn't grasp the maths. Went to the other end of the faculty and hid in a basement for a bit doing stuff most of my department didn't understand with functional meshes. Got proper ill for a long time. Partially recovered. Decided to get road licence whilst it was still financially viable and before I regretted never doing it. Picked some bikes that I liked that don't particularly urge me to ride like i'm on a racetrack. Wheezy little cruiser does most of my shopping and gets me to where I need to be. No points on my licence. No stories that feature not seeing a sudden curve until it was way too late. I'm sorry if it doesn't conform to your idea of low power motorcycling on 27 horsepower Enfield, but that doesn't stop me from knowing just a little about how engines perform.
chickenstrip
PostPosted: 18:00 - 01 Dec 2014    Post subject: Reply with quote
Ouch!! Laughing
Hey, I wasn't the one to question you on what bike you ride! Sad
Northern Monkey
PostPosted: 18:04 - 01 Dec 2014    Post subject: Reply with quote
chris-red wrote:
Dy/Dx Thumbs Up
This. The rate of change of power with revs will determine the rate of feeling you've been kicked.
Marlin
PostPosted: 18:44 - 01 Dec 2014    Post subject: Re: Dyno graphs Reply with quote
I like the per-gear WOT acceleration against speed plots available at motorcycleperformanceanalyzer.com
e.g. https://motorcycleperformanceanalyzer.com/triumph/street-triple-2009/
I'd assumed they told me something useful about how a bike feels. I am enlightened by talkToTheHat's initial comments that make me realise what a small part of the picture they show.
talkToTheHat
PostPosted: 19:01 - 01 Dec 2014    Post subject: Reply with quote
That wan't pointed at anyone on here, it was a meatloaf reference that means a little to me that my not quite father in law has wrecked more bikes through his own stupidity than I would like to count, and a clan elder from a generation previous nearly died when he throw a black shadow around a corner, forgot about the plank bridge and landed in a drainage ditch.
EDIT: chris-red beat me to this but I missed it, but it was little explained
Back to engineering
Work = Force x Distance travelled
Power = Rate of Work = Force x Distance / time
Torque = Force x displaceent vector
so
Power = Torque x 2pi x rotational speed
Some unit conversion required if not working in Watts, Newtons, Metres and Rev/second
EDIT: remembered unit conversions
Power (BHP) = Torque (lbs.ft) x Shaft Speed (revs/min) / 5252
Power (W) = Torque (Nm) x Shaft Speed (revs/min) x 2 x pi / 60
Or on a chart of power and torque against RPM, the power is the area under the torque curve, and the torque is the gradient of the power curve. Thus a horizontal torque will give perfectly linear increasing power. Make of that what you will.
I think the FZR chart is a little misleading as the torque has been scaled to appear extra flat. That scale should top out at 80 or so Nm not 150. Looking carefully that chart suggests torque reduces not long after 7k, as does the power increase. That said it looks like a whole heap of fun as a road bike and reasonably well mannered.
Factor in a constant (ish) rolling drag and aero drag that's thereabout proportional to the square of the speed, but note aero drag can suddenly decrease as airflow over a high drag part stalls.
Given sufficient traction, yes. However the bike that punches you in the chest might feel more wild and raucous. Conversely the shorter bike might make the best traction and be quicker accelerating in the hands of a skilled operator or when tamed with much electronics.
Consider perhaps another metric of vehicle performance, 30-60 roll on (or similar with different numbers, perhaps 50-80 is also useful) which can be simulated on a dyno. A vehicle with more rotational inertia (heavier moving parts in the engine and transmission) will do this more slowly than a vehicle with a similar power output and less rotational inertia, so lighter pistons, crankshaft, flywheel, gears and wheels, all useful racing mods will be apparent here, but not on a standard dyno charts.
Consider also the following scenario, two vehicles of similar weight, with engines that produce similar dyno charts (yeah unrealistic but this is a thought experiment), one is turbocharged, one is naturally aspirated, on a standing start drag race it follows that they would perform thereabouts equally, but what would happen if they were both cruising at 30mph at part throttle and then simultaneously floored it.
EDIT: Said motorcycle performance analyser charts are quite informative, but this is data derived from dyno figures, and few constants, they wont tell you more than you can know dyno charts and a few calculations. Nicely presented though. Feeding the gearing and tuning of a 535 into the XVS650, it suggests crazy things like 2k beyond what my TCI will allow.
Bubblin77
PostPosted: 09:23 - 02 Dec 2014    Post subject: Re: Dyno graphs Reply with quote
In simple terms for us bikers
Torque give you that thump away from the lights
Power is how long it goes for.
I hate the bhp race that's gone on for years, manufacturers scrambling for that extra 1-2bhp each 6 months, all this at the expense or real world torque.
Just think the new h2 pushes 200hp, it produces this up at nearly 10k, 10k in first gear equates to about 60mph, so unless your in first gear all the time your not really using the power to its best.
Until we all realise that bhp isn't the figure to go for manufacturers will keep giving us this unused figure from thecdepths if their research facilities.
Kawasaki Z800 (SOLD)
The last post was made 11 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 155.81 Kb
