Service Time!
Deathoctimus
PostPosted: 15:02 - 27 Nov 2014    Post subject: Service Time! Reply with quote
Here we go lets hope it all goes to plan!
DIY service on my bike this should be intresting. I'll probley have questions or somthings bound to go wrong Laughing so best post here!
https://imageshack.com/a/img904/6223/WB0Igd.jpg
Planned but not all today pritty crappy weather here atm.
Air filter clean
check plugs
oil change and filter.
break fluid change
Clean breaks out.
Wish me luck!
Shaun
Current Rides Fireblade 900 RRN / DL1000 past: ZX9R B1 / GSX 600F K3 / YBR125
Minty
PostPosted: 15:07 - 27 Nov 2014    Post subject: Reply with quote
Face mask? You into the kinky stuff?
My fingers smell of your mum.
c_dug
PostPosted: 15:15 - 27 Nov 2014    Post subject: Reply with quote
Tap wrench, you clearly have great confidence in how this is going to go!
Good luck. Thumbs Up
Deathoctimus
PostPosted: 15:17 - 27 Nov 2014    Post subject: Reply with quote
Well with possible asbestos in the pads I'm thinking the safer option.
Shaun
PostPosted: 15:18 - 27 Nov 2014    Post subject: Reply with quote
Asbestos hasn't been in brake pads for about 30 years...
Deathoctimus
PostPosted: 15:22 - 27 Nov 2014    Post subject: Reply with quote
Fair enough and good to no!
yeah Tap wrench i'm ready for shit to go wrong!
Shaun
RhynoCZ
PostPosted: 16:58 - 27 Nov 2014    Post subject: Reply with quote
If you want to be ''safe'' use gloves, no need for the mask, this won't be another Breaking bad episode. Smile
The dust from the pads is carcinogenic though, don't blow on them, don't lick them, wash your hands after you're done. Thumbs Up
Deathoctimus
PostPosted: 17:39 - 27 Nov 2014    Post subject: Reply with quote
I got gloves! Razz
I've sort of inspected and planned it out for now, didnt really get the time.
both breaks are binding a little bit.
The trottle cable needs lubing its sticks when I turn right. Which is not good.
Emery paper good for removing erosion correct?
Shaun
RhynoCZ
PostPosted: 17:46 - 27 Nov 2014    Post subject: Reply with quote
Is the throttle cable routed correctly? Thinking
STONEY!
PostPosted: 18:27 - 27 Nov 2014    Post subject: Reply with quote
throttle cable will be routed wrong or not have enough free play. binding brakes will be corrosion either on the back of the pads or behind the dust or piston seals, possibly even on the brake pistons
Deathoctimus
PostPosted: 13:58 - 30 Nov 2014    Post subject: Reply with quote
Right not had time to start this yet. It going to be wed and thur this week. You mite not be able to hear etc but the idle engine does sound a bit off, opinions?
Idle engine: https://youtu.be/2uWXvxIDIHw
Edit It can choppy at low speeds.
I got another video but can't upload till get to WiFi where it's warm.
Shaun
RhynoCZ
PostPosted: 14:44 - 30 Nov 2014    Post subject: Reply with quote
The idle is too low. Let's say the rev counter works alright, then you've got there less than 1000 rpm. You should have the idle between 1200 and 1400 rpm. Most of the motorcycle engines can't hold steady idle below 1000 rpm, especially when the engine is cold. Thumbs Up
Snowdonia Rider
PostPosted: 15:41 - 30 Nov 2014    Post subject: Reply with quote
Ah just noticed you've got the same bike as me Smile My idle is set at 1200 rpm and it's a bit lumpy, I've been meaning to do valve clearances which should hopefully sort it, if not then I'll balance the carbs too. I also seem to be getting excessive vibes which hopefully will get sorted by doing clearances and balancing.
I changed my oil and filter 3 weeks ago and serviced a few other bits, if you want some info on anything let me know.
Deathoctimus
PostPosted: 16:58 - 30 Nov 2014    Post subject: Reply with quote
Cheers lads I'll rase the idle.
I was thinking valve clearances.
Thanks for the offer for help I'll bear it in mind.
Shaun
Deathoctimus
PostPosted: 12:18 - 03 Dec 2014    Post subject: Reply with quote
so its going well just like opinons on my plugs
https://imageshack.com/a/img537/5961/hByLsx.jpg
Shaun
RhynoCZ
PostPosted: 12:21 - 03 Dec 2014    Post subject: Reply with quote
https://www.aa1car.com/library/reading_spark_plugs.jpg
Copycat73
PostPosted: 12:25 - 03 Dec 2014    Post subject: Reply with quote
is the bike doin short runs
caveat emptor
Deathoctimus
PostPosted: 12:27 - 03 Dec 2014    Post subject: Reply with quote
yeah it is looks like mild carbon look.
Shaun
Deathoctimus
PostPosted: 12:31 - 03 Dec 2014    Post subject: Reply with quote
https://imageshack.com/a/img538/481/lTr6Dr.jpg
i think that solves the trottle issuse Shocked
so new plugs or not?
Shaun
Copycat73
PostPosted: 12:38 - 03 Dec 2014    Post subject: Reply with quote
well you bought & paid for `em now .. may aswell put them in as you got bike stripped down.
PS... if your doin short runs try putting some redex in see if it helps sootin - up ..
I know I`m gonna get slated for suggestin that... but I use it all the time.
caveat emptor
Deathoctimus
PostPosted: 12:39 - 03 Dec 2014    Post subject: Reply with quote
yeah what I was thinking may as well do it now. cheers bud Thumbs Up
Shaun
RhynoCZ
Shocked Wow, how could you've missed that?
The plugs are alright, you just need to ride the bike more and give it hell every now and then to get rid of the carbon deposits, which I do believe would be all over the pistons and the head. Just go flat out, shift gears at the top of the rev range, and most of it will just fly away through the exhaust. You can also buy some fuel aditives, but that's just waste of money.
By the way, the plugs can also be cleaned with a file or iron brush, but be careful not to bend the ''contacts''. I'm not sure what word you use for those pieces of metal.
Deathoctimus
PostPosted: 12:56 - 03 Dec 2014    Post subject: Reply with quote
i think who ever fitted the heated grips before me messed up....
Shaun
Deathoctimus
PostPosted: 16:24 - 03 Dec 2014    Post subject: Reply with quote
well....
did oil filter, air filter, plugs. came to do cable AND.....
https://imageshack.com/a/img537/5015/K8bl8i.jpg
how the hell it was even working I dont no, rusted to bits.
Shaun
Deathoctimus
PostPosted: 12:05 - 04 Dec 2014    Post subject: Reply with quote
Okay can't get pin out on rear caliper to clean it. Help!! Tried knocking it cleaning round etc etc anything else I could try?
Edit
Going to a garage fuck it lol time is running out!
Shaun
The last post was made 11 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 134.89 Kb
