| james098 |
 james098 L Plate Warrior
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:02 - 28 Nov 2014 Post subject: |
Hi, we have a Workshop section where you'll get better assistance.
Sounds like a classic case of sucking crud from the bottom of the tank and clogging the idle jet. CBRs seem to be quite prone to it, I've seen one do it and heard about several others. Bear in mind that this is a remote diagnosis based on an ass-u-me-umption, comes with no warranty.
First thing you should do is buy and fit a cheap inline fuel filter to help prevent it happening again.
If it's a clogged jet then the carb will have to come out (or at least the float bowl off), jets out and clean them, ideally with compressed air. The idle jet is tiny, you don't want to be poking any bits of wire or similar down there unless you've got no other choice.
You can pay someone to do it but the plastics need to come off and workshop time doesn't come cheaper because you've got a 125. It's not that complicated an operation, I've done it at the roadside (on a naked bike). ____________________ Biking is 1/20th as dangerous as horse riding.
| james098 |
| james098 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 18:28 - 28 Nov 2014 Post subject: |
I'd drop by and help, but it'd be a bit of a day trip.
Any bike mechanic or garage will be able to clean the carb. If you can find a mobile one who will come to you then so much the better.
The battery might just be flat but while you're fettling have a look at it. If it's a "wet cell" battery that looks something like this...
https://www.scorpionbattery.com/images/products/681-large-339y_YB16AL-A2_Scorpion_Wet_Cell_Acid_pack_Motorcycle_Battery_lg.jpg
... then check the levels in each cell and top up with distilled water (available for pennies in most supermarkets). It's a commonly neglected item.
Oh, and now would be a good time to start putting penetrating fluid on the fairing fasteners. Plusgas or similar by choice, WD-40 if you don't have anything better to hand. ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 11 years, 296 days ago. Instead of replying here, would creating a new thread be more useful? |
