gilera dna 50 wont start ?
rosswell
PostPosted: 20:52 - 28 Nov 2014    Post subject: gilera dna 50 wont start ? Reply with quote
Hi i have a gilera dna 50 , i bought it a while ago and striped it down so i could respray it well after i sprayed the panels and put all of it back on and tried to start it and it wouldnt start , it was sitting for about a year , i put a new NGK spark plug and ht lead and still nothing .. it has had a performance exhaust and a polini high speed variater on it . So i put into a garage to see weather they could get it going but they couldnt find anything eventually they said that the piston and cylinder head was knackerd so they put a new one on and still it wouldnt work so they carried on surching and then they said it was the CDI so they replaced it with a new one and it starts and then cuts out they have also tried different carbs but still it wont work i was woundering if someone could help me out ...manythanks[/b]
Taught2BCauti...
PostPosted: 10:26 - 29 Nov 2014    Post subject: Reply with quote
For any Internal Combustion Engine to work, you need 4 things:
1. The correct Fuel/Air mixture.
2. Decent cylinder compression.
3. A decent spark at the spark plug.
4. Everything to happen at the right time.
If the first 3 items are OK, you need to make sure the spark happens at the right time - i.e. when the cylinder is near to the top of the compression stroke.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
rosswell
PostPosted: 21:59 - 04 Jan 2015    Post subject: Reply with quote
Hi it has got fuel and air going in I have tested the compression and it's fine there is also a strong spark and it has now had a new cdi/coil pack... And it runs better after it had the cdi/coil but still not 100%
Taught2BCauti...
PostPosted: 09:08 - 05 Jan 2015    Post subject: Reply with quote
I hope the garage didn't charge you for work they did that didn't fix the problem!
Still a few things you could check though - system voltage, dirty fuel, timing adjustment, wiring fault, carb settings, etc. but surely the garage would have checked all that?
andyscooter
PostPosted: 09:46 - 05 Jan 2015    Post subject: Reply with quote
have you rejetted it since putting the performance pipe on
if not this will cause problems
The last post was made 11 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 43.92 Kb
