Changing Starter relay.
JackDanger
PostPosted: 12:01 - 29 Nov 2014    Post subject: Changing Starter relay. Reply with quote
Hey guys,
I'm changing my starter relay and the new part that has arrived has a female connector instead of a male part like the previous one. Have I done goofed and need to totally re-order the part or can I just cut the wires and attach the correct plug?
Edit. I should also add that the colours on the wires are different. They both have a green/yellow wire but then one has a red/yellow and the other has a black/white. I'm assuming the Green/yellow is the earth wire and the other is the wire that runs to the ignition?
Nemo
PostPosted: 20:44 - 29 Nov 2014    Post subject: Reply with quote
Where did you order from? (i.e online/dealer)
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
WD Forte
PostPosted: 23:03 - 29 Nov 2014    Post subject: Re: Changing Starter relay. Reply with quote
Kinda, but not exactly
The red/yellow is the positive supply from the starter button
and the other goes to the clutch switch/neutral switch and eventually ground when certain conditons are met
ie In neutral or when clutch pulled
Just connect it up securely and try and keep the weather out
bikers smell of wee
JackDanger
PostPosted: 00:01 - 30 Nov 2014    Post subject: Re: Changing Starter relay. Reply with quote
Thanks I've changed the ends over and it's starting up first time now. Yet another problem with my cheap shitty Chinese bike solved. Bring on my test so I can get a real bike.
The last post was made 11 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 39.75 Kb
