need help with my SUZUKI GRS600 2007
Bike Chat Forums Index -> Forum Feedback & Help
xr_blackskins
PostPosted: 02:37 - 01 Dec 2014    Post subject: need help with my SUZUKI GRS600 2007 Reply with quote
Dear everybody,
My name is Nguyen, I have just bought a secondhand GSR600 2007.
As of last week, the engine stalls often (Side stand is not down, gear in neutral, kill switch is off, pulled clutch lever in. there is a slight electrical noise when key is first turned in the ignition. All lights come on and there is the needle sweep when the starter button is pressed, the engine is not starting. Messanes displayed on ODDO are:
- messange displayed at the space for speed is (-);
- messange displayed at the space for odd is "CHEC"
After minutes of trying with kill switch and ignition key I could get the engine fire again. However, its is very annoying because this situation occurs a few times a day.
Could you please give me your advice on what happen to my bike and how to fix this problem.
Thank you very much for your assistance and look forward to hearing from you.
Best regards,
Nguyen
PostPosted: 06:51 - 01 Dec 2014    Post subject: Reply with quote
When you say the engine is not starting, do you mean that it's not cranking or that it's cranking but won't fire?
CHEC means that the engine is not ready to run. Usually means the stand is down, or the bike thinks it's down because of a faulty switch. Another reason could be the red engine run switch, prone to faults on Suzukis. With the ignition on, turn the run switch off then on again, you should hear the pump prime. If it doesn't either the switch is faulty or it's feed is interrupted by the alarm/immobiliser. If the bike has an alarm fitted, most likely that's the reason.
xr_blackskins
PostPosted: 08:08 - 01 Dec 2014    Post subject: Reply with quote
Thanks a lot,
will check and clean the switches this evening
Best regards,
Nguyen
Nexus Icon
PostPosted: 14:37 - 01 Dec 2014    Post subject: Reply with quote
My Suzuki shows CHEC when the ignition is on and the killswitch is engaged.
Check that one very carefully for water ingress or dirty contacts.
Greetings from Shitsville!
The last post was made 11 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Forum Feedback & Help All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 39.72 Kb
