Torque
Ame
PostPosted: 23:13 - 01 Dec 2014    Post subject: Torque Reply with quote
Good evening BCF
what would you consider 1.5 Nm of torque to 'feel' like? just over 'finger-tight' ?
If you made a scale from 1 to 6 Nm's,what would you say these 6 feel like?
Very Happy
PostPosted: 23:19 - 01 Dec 2014    Post subject: Reply with quote
No idea, do stuff up till stuff doesn't fall off.
Bikeless
PostPosted: 23:21 - 01 Dec 2014    Post subject: Reply with quote
https://www.chainreactioncycles.com/x-tools-torque-wrench-2-24n-m/rp-prod11142
WD Forte
PostPosted: 23:50 - 01 Dec 2014    Post subject: Reply with quote
1 Nm is .737 Lb/ft 6Nm is 4.42 lb/ft
what is it you're doing that requires such a light touch?
The smallest bolt thread on most bikes is often 6mm which as rule of thumb
takes no more than 10 lb/ft ( 13.5 Nm)
Below this is what we call screws round here and from 6mm down
I use a driver rather than a socket and bar, possibly a small spanner.
I usually screw them in easily until they stop then 'nip' them up a bit.
My 'nip' and your 'nip' may vary, often its around 45 perhaps 90 degrees
at a guess but it depends
(Material, amount of thread, if loctite is being used etc)
Torque wrench?
we don' need no stinkin torque wrench.
bikers smell of wee
PostPosted: 23:57 - 01 Dec 2014    Post subject: Re: Torque Reply with quote
1nm ≈ 1m x 100g.
So a similar force on a 30cm ratchet handle to that required to hold a half kilo bag of sugar.
Ame
PostPosted: 00:44 - 02 Dec 2014    Post subject: Reply with quote
[quote="WD Forte"]1 Nm is .737 Lb/ft 6Nm is 4.42 lb/ft
Torque wrench?
we don' need no stinkin torque wrench.[/quote]
just looking for the highest to lowest torque settings:
Rear axle nut 93 (9.5, 69) NOTE 4
Driven sprocket nut 32 (3.3, 24) NOTE 4
Swingarm pivot nut 88 (9.0, 65)
Carburetor drain screw 1.5 (0.15, 1.1)
Float chamber screw 2.1 (0.21, 1.5)
Slow jet 1.8 (0.18, 1.3)
Needle jet holder 2.5 (0.25, 1.8)
Main jet 2.1 (0.21, 1.5)dl=0
Front master cylinder reservoir cap screw 1.5 (0.2, 1.1)
Front brake light switch screw 1.2 (0.1, 0.9)
and wondering what these tiny increases can 'feel' like,taking into account different peoples 'nip'
is it generally accepted that 1.7 to 2.3 is 'fingertight'.so the NJH at 2.5 Nm [0.25,1.8] is about 45 degrees over this?
sorry it sounds garbled, Thumbs Up
Chuffin Nora
PostPosted: 02:16 - 02 Dec 2014    Post subject: Reply with quote
Very simple way to gauge micro torque:
Position one nut between one thumb and two or three fingers and very gently but progressively squeeze.
When the pain becomes unbearable, that's roughly in the region of 1/10th of a N·m.
Warning
Do not wait for a 'click' before stopping procedure.
Note:
Newton metres and family jewels are not "dimensionally equivalent" in the sense that they don't have the same expression in SI base units.
Rather:
https://upload.wikimedia.org/math/0/0/c/00c018f67a550233c4427bb9b8f9e20f.png
Hope this helps.
The last post was made 11 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 52.23 Kb
