| stranger12 |
 stranger12 World Chat Champion
| G |
 G The Voice of Reason
| stranger12 |
| _Iain_ |
 _Iain_ Banned
| G |
 Posted: 15:50 - 01 Dec 2014 Post subject: |
So instead of taking a monetary loss on that, you're going to spend more more money creating a bike that will likely be worth even less and won't be as suitable as one you could buy already set up?
<shrugs>, it's your money!
If there was water in there, that would explain why you had 'dampness' issues .
However, I think you may have a different issue, I've seen similar symptoms in cases where people, after checking, have found there bike is actually a (road) SV650! It's a remarkably common problem, as it goes and very closely matches your symptoms.
Note that damping controls how FAST the bike goes down (compression) and come back up (rebound).
It does control how FAR, excepting compression for small bumps, of course.
The spring controls the 'far'.
The obvious example here is a long braking zone.
Thicker oil (or adjustable damping turned up) might stop the bike bottoming out in the first half second of braking, but it'll still bottom out after three seconds, say. A stiffer spring will stop it bottoming out. |
| stranger12 |
| _Iain_ |
 _Iain_ Banned
 Posted: 09:52 - 02 Dec 2014 Post subject: |
| stranger12 wrote: | dude , all i need is £200 on suspension and that is it. |
How much do you think suspension costs?
Keep in mind you plan on changing the springs, fitting fancy internals and replacing a knackered rear shock.
Emulators £150
https://www.stevejordanmotorcycles.co.uk/product-detail.asp?P=SUZUKI-SV650-2003-2012-RACETECH-GOLD-VALVE-FORK-EMULATORS&productid=44
Fork oil £20
https://www.ebay.co.uk/itm/2x-1L-2-LITRES-LTRS-MOTUL-MOTORCYCLE-FORK-OIL-EXPERT-MEDIUM-10W-RACE-TRACK-DAY-/361114158285?pt=UK_Motorcycle_Parts_13&hash=item541414c4cd
Fork seals £20
https://www.ebay.co.uk/itm/like/270996423405?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&chn=ps&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108
Replacement springs £120
https://www.intobikes.co.uk/products/000008/003719/Ohlins-Fork-Springs-suitable-for-Suzuki-SV650-S-2006?src=fro&highlight=18076&gclid=CKjXoaqHp8ICFSX3wgodF24Acg
Aftermarket rear shock £400
https://www.msrmotorcyclespares.co.uk/suzuki-sv650-nitron-rear-sport-shock-2003-2008.html?___store=msr_uk&gclid=CISIuruHp8ICFYLnwgodo7EA2A
I make that £710 on suspension before you put tyres on it (Assuming the bushes are all in good nick, as you've not budgeted for changing those), or you'll fit GSXR forks which will likely cost the same after you've mucked about getting brakes/wheels/tyres/headrace bearings etc & then having to rebuild, respring and set them up for your weight anyway
And then you'll leave the fairing that's worth money on the bike knowing it's going to get smashed to bits rather than the cheap, lightweight race fairings, and then finally you want to lower it which will only mess the geometry up & reduce ground clearance & the whole point of high level exhausts & rearsets on race bikes is to improve the ground clearance!
This, this is why you are potato: Buying a bike for £2.5k, spending £700 to make it worth £1000 & building a track bike that sacrifices handling & ground clearance for comfort. ____________________ Please be aware that the above post may be full of complete nonsense.
| stranger12 |
| lihp |
 lihp World Chat Champion
 Posted: 12:30 - 04 Dec 2014 Post subject: |
| stranger12 wrote: |
two questions, why would you change the rear shock , for rebound and damping control ?
More adjustments, better quality damping, No need to get anything too fancy if it's your first track bike.
| Quote: |
also re ground clearence, if you lower the bike, I guess you can't lean as much right ? |
Why are you even considering lowering a track bike?
If you lower it, it will limit maximum lean angle, therefore limit maximum corner speed, it will also affect the weight transfer on braking, it will also make the bike less responsive to steering inputs. ____________________ covent.gardens: lihp is my most favourite member ever |
| Wull |
 Wull Crazy Courier
| stranger12 |
| lihp |
| stranger12 |
| mentalboy |
 mentalboy World Chat Champion
| stranger12 |
| lihp |
| stranger12 |
| stranger12 |
 Posted: 22:06 - 19 Jan 2015 Post subject: |
something like this
https://www.ebay.co.uk/itm/yamaha-R1-2003-track-bike-/331428689931?pt=UK_Motorcycles&hash=item4d2ab0780b
it says frame is slightly swelling in the front . is that an issue ?
I am thinking of buying it
full description
"2003 R1 track bike. Not too pretty but mechanically solid, rides spot on and pulls very well! Scruffy but functional track fairing, bendix pads and can. Has scuffs to tank after lowside at rockingham and slight swelling to frame in front of crash bung. No v5 hence price. May be able to deliver but please ask first. Any questions feel free to call on 07796 883 515" ____________________ SV650 Red
R6 Red |
| lihp |
| stranger12 |
| garth |
 garth World Chat Champion
| stranger12 |
| sickpup |
 sickpup Old Timer
| wr6133 |
 wr6133 World Chat Champion
| P.addy |
 P.addy Red Rocket
The last post was made 11 years, 298 days ago. Instead of replying here, would creating a new thread be more useful? |
