| FlightRisk |
 FlightRisk Spanner Monkey
 Posted: 22:44 - 02 Dec 2014 Post subject: Valve shim selection? |
Been having a look at the oily innards of the little beast.
Shims appear to need a little shimming. The ones in there are in increments of 0.02mm but the ones I can get are in increments of 0.05mm which makes choosing a little tricky.
I can choose between a valve ending up (in theory) at the lower end of spec, or 0.01 over spec.
If I put a full set of shims in I can have everything consistent at the high end of the range or 0.01 over and they won't need doing again for a very long time.
Or I can have them all in spec but a mish-mash of high and low values and the low ones will need doing again soon.
Advices?
 ____________________ Honda CB500S |
| Nemo |
 Nemo Could Be A Chat Bot
| LongJohn22 |
 LongJohn22 Trackday Trickster
| FlightRisk |
| Pete. |
 Pete. Super Spammer
 Posted: 06:29 - 03 Dec 2014 Post subject: |
The quoted clearance is what you want to achieve at time of adjustment. If you're on the bottom limit that's acceptable but it's preferable to aim for the upper limit given a choice. Achieveing 0.28 where the upper limit is 0.27 is perfectly fine IMO. ____________________ a.k.a 'Geri'
The last post was made 11 years, 347 days ago. Instead of replying here, would creating a new thread be more useful? |
