Kwaka GPz 500s 2001 charging problems
Wannabee
PostPosted: 14:49 - 02 Dec 2014    Post subject: Kwaka GPz 500s 2001 charging problems Reply with quote
Hi,
Trying to sort out the charging problem on my bike, stripped her down, cleaned all the connectors etc but problem when putting front end back on, both front indicators light at the same time and are a lot dimmer than they should be, back ones work fine. Any one have any idea how to resolve it???
A bad day is just a good day waiting to happen!
ws4936
PostPosted: 20:42 - 02 Dec 2014    Post subject: Reply with quote
Try disconnecting the indies by the push connectors and swapping them for the other Indy push connector.
If everything seems under control, you're just not going fast enough.
Wannabee
PostPosted: 13:29 - 03 Dec 2014    Post subject: Reply with quote
Cheers for the info, much appreciated. The indie connectors on my bike are just 4 "bullets"
Wiring from both left and Right Indies: 1 Bk n Yellow and 1 Green.
The only connector has 4 wires; 1 Bk n yellow, 1 Green, 1 Blue and 1 Grey. Checked wire continuity and all test good, so might be a relay problem, will need advice on how to check it.
Swapped them one way both front indies are on and flashing simultaneously, the other way front indicators both off.
bikenut
PostPosted: 10:54 - 04 Dec 2014    Post subject: Reply with quote
bad earth??!
nuts about bikes
PostPosted: 11:37 - 04 Dec 2014    Post subject: Reply with quote
bikenut wrote:
bad earth??!
This. Sounds like classic symptoms of a poor earth connection.
Make sure there is good continuity between the white on black wires and the battery negative.
The last post was made 11 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.03 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 43.03 Kb
