| Itchy |
 Itchy Super Spammer
 Posted: 21:32 - 03 Dec 2014 Post subject: Bike FI like car FI? |
The other thread about economic riding.
Anyway my last car before the current one was carb.
Therefore coasting down hills saved petrol. As the revs were lower and there were less sucking from the cylinders on from the carb.
I did this with my newer FI car. I was told no need to do that! modern FI cars stop injecting petrol into the cylinders if they are being spun around by the car say going down a hill as such you can leave the clutch out and it will be more economical.
Does motorbike FI do that? ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| stevo as b4 |
| Nemo |
 Nemo Could Be A Chat Bot
| Andy9934 |
 Andy9934 Nova Slayer
| TallPaul_S |
 TallPaul_S Trackday Trickster
| EazyDuz |
 EazyDuz World Chat Champion
| G |
 G The Voice of Reason
| Kickstart |
 Kickstart The Oracle
 Posted: 00:43 - 04 Dec 2014 Post subject: |
Suspect it is quite variable. Also suspect it is one thing that changes as soon as someone puts on a power commander to try and smooth the throttle out.
My old Alfa 33 would cut the fueling when slowing, above certain rpm. Seemed to be done quite crudely and gave quite a jerky throttle response in normal use (not a problem when thrashed, and it tended to encourage that behaviour anyway).
It will save a bit of fuel, although it is increasing engine braking at the same time. Also possibly saves on emissions a bit.
| Nemo |
| MarJay |
 MarJay But it's British!
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 13:36 - 04 Dec 2014 Post subject: |
If your engine has a 'TPS' (Throttle Position Sensor) hooked-up to the ECU, it will almost certainly cut fuel delivery at the closed position. If the ECU has to rely on the 'MAF' (Mass Air Flow) sensor alone, it probably won't.
I have found this to be a problem when converting cars to run on gas, where the LPG ECU can't make sense of the data from the TPS, and have had to add a micro-switch to detect when the throttle is closed. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| lihp |
 lihp World Chat Champion
| stevo as b4 |
| Kickstart |
The last post was made 11 years, 322 days ago. Instead of replying here, would creating a new thread be more useful? |
