rs 125 temperature problem
ezio88
PostPosted: 00:30 - 05 Dec 2014    Post subject: rs 125 temperature problem Reply with quote
This is my first post so hi and thanks in advance for any help...
My bike has a digital display that usually says cold until it gets to 36 degrees then its displays the temp 37 38 39 ect up to 100.
How ever i recently drained coolant to do a leakdown test and since refilling its saying cold even when its red hot.
Early it went from cold to 50 although meant to start displaying temp at 36 then when it hit 58 it started saying cold again.
Any ideas what i could check ? the temperature sensor wire is connected to sensor
john24ssj
PostPosted: 08:22 - 05 Dec 2014    Post subject: Reply with quote
You could try to:
boil a cuppa, remove the sensor, turn the ignition on and submerge your sensor in the hot cup of water Smile
Bikes: Honda CBR600Fi, Kawasaki ER5
ezio88
PostPosted: 08:57 - 05 Dec 2014    Post subject: Reply with quote
john24ssj wrote:
You could try to:
That aint a bad idea ill give it a go and if it still says cold then i need a new sensor i take it lol.
Ill be sure not to drink the cuppa after Laughing
Not sure how tea and antifreeze would taste
PostPosted: 10:55 - 05 Dec 2014    Post subject: Reply with quote
The thermostat opens after the temp says its fairly high, like 50-60ish I can't recall. When it gets that warm and it opens a rush of water gets pumped round which might explain the cooler reading.
ezio88
PostPosted: 11:28 - 05 Dec 2014    Post subject: Reply with quote
That was my original thought to be honest.
But usually the temperature starts displaying from 36 and now it says cold until 50 ??
PostPosted: 11:36 - 05 Dec 2014    Post subject: Reply with quote
Unsure as to why that would happen, I'm not an electrical guy at all so could be anyyyything Laughing
ezio88
PostPosted: 11:45 - 05 Dec 2014    Post subject: Reply with quote
Same here no good with electrics thats what brought me here lol thx anyway
john24ssj
PostPosted: 12:36 - 05 Dec 2014    Post subject: Reply with quote
So I assume you don't own a multimeter? you could check the resistance values of the sensor when submerged in hot water that would tell you if the sensor is going bad.
ezio88
PostPosted: 12:48 - 05 Dec 2014    Post subject: Reply with quote
So I assume you don't own a multimeter? you could check the resistance values of the sensor when submerged in hot water that would tell you if the sensor is going bad.[/quote]
Ok so my step dad has all electrical stuff i could pop round and lend his multimetre or even better purchase my own if ill most likely need it again some time but could you tell me how exactly i use it or is it to technical to type up i hope not ive seen a multimetre lots of settings on dial ect...
ezio88
PostPosted: 12:50 - 05 Dec 2014    Post subject: Reply with quote
Dont know what i did wrong in above post sorry didnt show your previous post i a box looks like i wrote it all ?
john24ssj
PostPosted: 15:33 - 05 Dec 2014    Post subject: Reply with quote
No worries. Multimeter is a life saver trust me, if you want to check anything from a battery to a sensor having one is really useful.
You can get a good one for £10
ezio88
PostPosted: 15:42 - 05 Dec 2014    Post subject: Reply with quote
Ok ill go get one and then have to work out how to use it. Many thx
iooi
PostPosted: 16:51 - 05 Dec 2014    Post subject: Reply with quote
It could also be that you have air locked the system.
Take the rad cap and expansion cap off. start the bike and squeeze the rubber pipes to make sure all the air is out and that the fluid gets warm.
lukamon
PostPosted: 19:55 - 05 Dec 2014    Post subject: Reply with quote
Have you undone the air bleed screw by the spark plug? Take it out and wait till coolant starts to come out, then nip it up
killa wrote: Im an ass man myself
ezio88
PostPosted: 20:00 - 05 Dec 2014    Post subject: Reply with quote
Im pretty sure theres no air in there the way i fill it is i keep pouring in the coolant with the screw out of the rad once it starts pouring out i put screw in then i do same with the bleed screw by spark plug once its pissing out of there i nip it up and fill to max line.
I did start it up for 2 mins with no coolant in there other day dont know if that could damage the sensor ?
Reason i started it was fitted new 34mm carb flat side racing carb and italjet reed block and was just checking it ran ok
The last post was made 11 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 83.64 Kb
