Brake discs?
BenR
PostPosted: 17:07 - 07 Dec 2014    Post subject: Brake discs? Reply with quote
Hi all at the moment I'm looking for a new set of brake discs for my wolf project. Below are a couple of links for some that are in my watch list.
https://www.ebay.co.uk/itm/301370988095?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
https://www.ebay.co.uk/itm/180842253885?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Has anybody used these before? They're unbranded & from Hong Kong but they look like Kagizume discs (which are Chinese) which I haven't heard of any horror stories about. Inb4 "you've answered your own question" any advice much appreciated ta!
PostPosted: 17:21 - 07 Dec 2014    Post subject: Re: Brake discs? Reply with quote
That's because everyone who's ever used them is now dead Shifty
BenR
PostPosted: 18:01 - 07 Dec 2014    Post subject: Reply with quote
Any evidence to back that up?
iooi
PostPosted: 18:10 - 07 Dec 2014    Post subject: Reply with quote
Well given no one has come back and said no........ Shocked
PostPosted: 18:11 - 07 Dec 2014    Post subject: Reply with quote
I consider that conclusive proof.
Case closed.
Snorty
PostPosted: 18:26 - 07 Dec 2014    Post subject: Reply with quote
I've heard bad things about them being made of sub-standard metal and thus being prone to warping.
This, I heard online.
I have two friends who bought Chinese discs and they claim they're fine.
I wouldn't buy Chinese discs, however. I'm a believer in "it's cheap for a reason". I do realise sometimes it's just high mark-up though.
BenR
PostPosted: 18:34 - 07 Dec 2014    Post subject: Reply with quote
Aye ordinarily I'd agree but the bike's only a 125 would they get hot enough to warp?
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
iooi
PostPosted: 19:20 - 07 Dec 2014    Post subject: Reply with quote
You have a lot to learn then.....
Less surface area = higher temps.
BenR
PostPosted: 20:05 - 07 Dec 2014    Post subject: Reply with quote
Yes you do you obviously didn't read the ads. This 125 has the same front disc as a GSXR750WN, RGV250, GSXR400, Bandit & pretty much every other sports/sport touring bike Suzuki made in the 90s. But here's the thing it only weighs 115kgs (obviously more with me on it) would the discs still get that hot? A new one from Suzuki is around £180 & from EBC £160. Thanks for all the input so far. Thumbs Up
talkToTheHat
PostPosted: 20:36 - 07 Dec 2014    Post subject: Reply with quote
E(kinetic)= 1/2 * mass * velocity ²
Weight of a bike is not as significant as the velocity at high speed, 60mph is about 26 metres/second so v² is 676, so with bike plus rider at 200kg that's 135kJ of heat to dissipate. 270kJ for a fat rider on a big tourer or two up (400kg). This is about the same as braking the 200 kg bike from 80mph. (36.7m/s to 3sf)
Go figure how this applies to the heat put through a brake disk in each of your applications. The 125 probably has a braking system that can deal with significantly more frequent braking from terminal velocity than the gxsr750.
Note however that a brake rubbing at 60 mph might fuck up the disks on either bike.
Note further that sintered pads transfer much more heat to the caliper and thus brake fluid than organic, carbon ceramic or racing carbon brakes, so in some circumstances heat is transferred differently.
Bandit. does. everything.
lihp
PostPosted: 21:25 - 07 Dec 2014    Post subject: Reply with quote
But mass and weight aren't the same thing Wink
Snod Blatter
PostPosted: 00:31 - 08 Dec 2014    Post subject: Reply with quote
I had a pair of earlier non-wavy Kagizumes on a TRX850, they performed perfectly until I asked them to commute for a couple of months of winter when they started to warp. I laid the bike up after that and used something else to get to work, then came back to the TRX in April/May time to find the discs had warped more than I remembered. It turned out that the semi floating bobbins were full of corrosion and it was impossible to clean out, so they were scrap.
As an aside they were also significantly heavier than the OE Yamaha discs I replaced them with, so while not outright dangerous they don't have anything going for them other than price. Wear after around 7K miles with sintered pads was also non-existent but it doesn't matter when the bike is trying to throw the MOT guy onto the floor as he tries to test the front brakes on the rollers..!
iooi
PostPosted: 10:05 - 08 Dec 2014    Post subject: Reply with quote
Where does it say fits the 750..
Yes it mentions 750 at the side. But that's a different sale.....
> From the auctions.... Rolling Eyes
Front
Compatible for Suzuki:
RG 125F GAMMA 1992-2011
VZ800 MARAUDER Boulevard M50 1996-2004
Rear
SUZUKI RG125 FU-N Wolf Rear 92-94
SUZUKI RG125 FU-N,P,R Gamma Rear 92-96
SUZUKI GSX-R250 C-J,K Rear 87-88
SUZUKI GSX-R400 R-L,M,N,P,S Rear 90-95
SUZUKI RGV GAMMA M (VJ22B/F611) 250CC 1991-1996
And that is what they say.. Not Suzuki.
Clearly you have made you own mind up already. So please get some and then let us know how they fair Thumbs Up Karma
Remember there are 2 vital parts that ensure your safety.... Tyres & brakes.
Soory make that 3....
The throttle to brain interface Laughing
UrbanRacer
PostPosted: 10:10 - 08 Dec 2014    Post subject: Reply with quote
There are no reports because people that buy them don't want to hear "I told you so"
talkToTheHat
PostPosted: 14:44 - 08 Dec 2014    Post subject: Reply with quote
[quote="lilihpBut mass and weight aren't the same thing Wink[/quote]
Nope. But as weight was discussed it was worthy of a mention. Furthermore in earth gravity at non relativistic speed we don't have to worry too much, although the bike that weighs more will exert more force on the road through the tyres and thus the friction would be proportionally higher. There is a limit of about 1.1g to the possible braking deceleration in both cases though. And yes it's above 1g because tyres do amazing chemistry things with the road. Most riders will not be able to consistently sustain such braking deceleration.
There is a gap of 1 year, 91 days between these two posts...
Tiger900
PostPosted: 00:18 - 09 Mar 2016    Post subject: Kagizume Discs the good, the bad and the very ugly Reply with quote
Two years ago I purchased two wavy rotors from Ebay for the front and a plain disc for the rear both were Kagizume make as the Triumph ones were silly priced (£750 for 3).
*** The Good ***
They are really cheap and looked good for a week. They brake and stop you fine and passed an MOT.
*** The Bad ***
They were advertised as stainless but after two weeks rusted quickly so looked like they were years old.
Within two Months the front discs warped slightly but they actually worn flat again after 6 Months of use. The rear disc bolts had to be filed shorter as the disc was slightly loose due to slight spec difference in thickness. I used Hammorite black on the rusty part of the disc.
*** The Ugly ***
My rear disc snapped last week in one place and cracked at the opposite side and had a 4mm gap once I took the bolts out. Luckily it did not fall in half.
The disc has not had much wear.
It looks like the disc was permanently stressed in manufacture causing it to be a time bomb. It is so stressed that I cannot manually close the 4mm gap again with brute force.
Bottom line I will never buy Kagizume discs again. Mine was dangerous and very poor quality.
ZX-7R This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 10 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 101.62 Kb
