| ProXimaCore |
 ProXimaCore Dougal
 Posted: 09:56 - 24 Jan 2005 Post subject: Rear brake repairing. Caliper and disc. |
I've decided that since the rear of my bike is in bits just now I'd fix the rear brakes. The pads are badly worn, so I've taken them out and got a new set to go in. The only thing is that one of the pistons is seized and doesn't push the pad. I've stripped the caliper into as many parts as possible and tried spraying WD-40 inside it. Then I even tried leaving the caliper to soak in engine degreaser overnight. Don't know if that would actually do any good or not though. But it's no different as far as I can see.
The 2nd thing is I'm trying to get my rear brake disk on and the very last allen bolt has worn itself into a circle and I can't get it off now. Does anyone have a suggestion for this?
Also the spare brake disc, I may or may not have touched it with my greasy hands and was worried that it'll be a bit slippery now since I've been using WD-40 and copper grease. If there is any on it then it'd only be a tiny bit. But I want to be sure it's clean. Is there any method I should use to clean the disc? ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| mr jamez |
 mr jamez World Chat Champion
 Posted: 11:42 - 24 Jan 2005 Post subject: |
If the piston is seized then you need to replace the seals and possibly the piston, though that should come up with a clean. Put the brake back together and pump the pistons out, replace seals and give everything a good wash with brake fluid. WD40 is bad for rubber and is not a good idea to use it round the seals, brake fluid will clean it up fine. You haven't sprayed WD40/engine degreaser inside the caliper have you?
As for the brake disc, I got grease on mine, gave it a good scrub with petrol then hot soapy water and it has done the trick as far as I can tell  |
| Kickstart |
 Kickstart The Oracle
 Posted: 14:15 - 24 Jan 2005 Post subject: |
As above. With luck the pistons will be fine.
However these calipers are known for seizing up, especially the pins that locate the pads. I suspect that they are also common to most Suzukis, and probably the same caliper on a Bandit.
WD40 has a reputation for affecting the rubber used in seals.
Just get a can of brake cleaner to clean the disks up (it is just a good degreasant).
| Scotsman37 |
 Scotsman37 World Chat Champion
| Kickstart |
| Scotsman37 |
The last post was made 21 years, 30 days ago. Instead of replying here, would creating a new thread be more useful? |
