Winter tart-up: Pitbike Supermoto
garth
PostPosted: 12:39 - 16 Dec 2014    Post subject: Winter tart-up: Pitbike Supermoto Reply with quote
This past year I've been participating in the matchams pit bike series, I managed to do five of the nine rounds, although one of those I had a big crash in the first race and didn't do the rest of the day. Race day is 2x15m warm ups, 3x10 lap heats and 1x12 lap final (the final is what counts for podium credits and trophies)
Out of those five rounds I picked up two third place trophies and won the class B championship (fastest fatty...!)
I'm 6'2" so probably not built for pit bikes but it's very enjoyable, and I'll be back next year. The bike needs a touch of work though.
Here's how it started the last round:
https://i1275.photobucket.com/albums/y459/nark_square/84C8A9C7-55F9-4E72-AB3A-0B8447A5664A_zpsowmdu8ts.jpg
https://i1275.photobucket.com/albums/y459/nark_square/82779E77-0783-43D6-B72E-33B798FF4F6D_zpssacsdd6y.jpg
And here's how it stands in the shed. I sort of abandoned it when I went to Africa. The handguards and front mudguard have been removed in this one.
https://i1275.photobucket.com/albums/y459/nark_square/8A28B477-FEC3-4516-B5C1-1B4F65C00984_zpsc0fhufpf.jpg
The thing that's been bugging me all year has been my straight line speed, I'm good enough on the brakes and corner entry, but others seem to pull a bike length on me down the straights, even if I'm on the throttle before them. I noticed the baffles in my C90 exhaust were rattling all over the place, and on closer inspection, the outlet pipe smaller than others. Turns out when I put this pipe on it was off my C50LAC and appears to be different.
https://i1275.photobucket.com/albums/y459/nark_square/770B1DFD-F4E1-45AE-8840-FD9DA3982BCC_zpsc5u6gwck.jpg
You can also see the rear tyre has had it, this was a supersoft MC31, in future I'll use a soft (as this was supposed to be - I got sent the wrong one and didn't check, I've a soft on the front)
I've also picked up a different header pipe, if you compare the two you can see the replacement is both a larger bore and free from welds which should help the gasflow.
https://i1275.photobucket.com/albums/y459/nark_square/IMG_14381_zpsd25fdf00.jpg
https://i1275.photobucket.com/albums/y459/nark_square/8371956B-BE25-4B79-ACF1-1EB204F886A3_zpsrmru4srk.jpg
https://i1275.photobucket.com/albums/y459/nark_square/IMG_14501_zpse3502edf.jpg
After a quick clean up and chopping both the silencer and the header to the correct length, I got my old man to weld them together.
https://i1275.photobucket.com/albums/y459/nark_square/IMG_14551_zps6f6a5615.jpg
https://i1275.photobucket.com/albums/y459/nark_square/C2C70F4E-CCE0-4BF4-9F69-1EC8351FB86F_zpsvjw2uq5y.jpg
I'm hoping this will help me down the straights!
Next job is fitting my replacement kickstart.
Old:
https://i1275.photobucket.com/albums/y459/nark_square/IMG_14401_zpsbfd18958.jpg
New:
https://i1275.photobucket.com/albums/y459/nark_square/IMG_14411_zps9d460441.jpg
You can probably also see how fucked my footpegs are. I'm going to try and figure out how to raise them to give me more ground clearance.
Bodywork off, new exhaust not yet on:
https://i1275.photobucket.com/albums/y459/nark_square/4EA5B59D-9404-44E8-8025-118BFE062942_zpsk3tionm2.jpg
More to come...
ride_to_die
PostPosted: 15:45 - 16 Dec 2014    Post subject: Reply with quote
Looks fun, how much does it cost to take part?
I'm not here for a long time, I'm here for a good time.
garth
PostPosted: 16:56 - 16 Dec 2014    Post subject: Reply with quote
£40 per race day, £25 1/2 day practice or £40 for a whole day. Thumbs Up
This is what it does to your boots!
https://i1275.photobucket.com/albums/y459/nark_square/IMG_14751_zps04934542.jpg
Oil line weeping, again. Will replace and get spares.
https://i1275.photobucket.com/albums/y459/nark_square/IMG_14821_zpsf01cd187.jpg
Stud snapped off in rear spindle, both sides.
https://i1275.photobucket.com/albums/y459/nark_square/IMG_14801_zpsba203ea2.jpg
And think I'll need a better catch tank rather than the yoghurt pot that's on it at the moment Laughing
https://i1275.photobucket.com/albums/y459/nark_square/IMG_14861_zpse4f06c37.jpg
On the flip side, exhaust cleaned up and fitted well, beefcake.
https://i1275.photobucket.com/albums/y459/nark_square/IMG_14811_zps268dbec0.jpg
And new air filter fitted.
https://i1275.photobucket.com/albums/y459/nark_square/IMG_14841_zps760f8069.jpg
Sneak peak of new colours, with skateboard wheels fitted as bobbins to the front axle.
https://i1275.photobucket.com/albums/y459/nark_square/IMG_14631_zps9bc31309.jpg
ride_to_die
PostPosted: 11:48 - 17 Dec 2014    Post subject: Reply with quote
'kin hell that's not bad considering the track time.
ride_to_die
Use of skateboard wheels is ingenious.
bikertomm
PostPosted: 13:55 - 17 Dec 2014    Post subject: Reply with quote
Brilliant, I would love to get into this at some point, bet that's great smiles per £.
PostPosted: 14:05 - 17 Dec 2014    Post subject: Reply with quote
I'm liking the professional touches such as the yoghurt pot. Thumbs Up
y u no bcf sticker?
Aff
PostPosted: 14:13 - 17 Dec 2014    Post subject: Reply with quote
Following with interest.
I will be getting my first taste of pitbike supermoto on Monday night (thanks G), then hopefully doing matchams next year if all goes to plan.
Electric Bike Project
garth
PostPosted: 17:08 - 17 Dec 2014    Post subject: Reply with quote
y u no bcf sticker?
You buy me one, I'll stick it on!
Nice one, I'll try do all next year, depends on a few things though.
Anywho, bodywork on.
https://i1275.photobucket.com/albums/y459/nark_square/IMG_14601_zpse6a86b2b.jpg
https://i1275.photobucket.com/albums/y459/nark_square/IMG_14621_zpse5d62914.jpg
And oil changed too.
Still to do:
Rear tyre / remove studs / fit bobbins.
Handguards.
Valve clearances.
Catch tanks.
Seat foam rear mudguard.
Footpegs - raising if possible and bobbins.
Possibly fork oil change.
Brake pads on the front.
-Monty-
PostPosted: 23:24 - 17 Dec 2014    Post subject: Reply with quote
Interesting stuff. Thanks to G, I also will be giving this a go on Monday. Can't imagine I'll be getting into the racing just yet due to costs and such but am keen on it at some point Thumbs Up
Present: [Kawasaki ZX7r][Suzuki DRZ 400s]
Past: [Honda PCX 125] [Yamaha RXS 100] [Honda CB 500] [Triumph Speed Four] [Honda ST1100 Pan European - Po-Po Edition]
binge
Emo Kiddy
PostPosted: 00:25 - 18 Dec 2014    Post subject: Reply with quote
Nice work dude!
I know matchams are very tight on their regulations.
Not sure if they've started allowing Z40 cams to be fitted like some of the other race series'.
Sneaky little mod is to fit the inlet valve out of a 125 big-valve engine, into the exhaust port of the 140.
Impossible to tell, but improves power quite noticeably. Twisted Evil
Valve goes straight in, but clearance is next to nothing to set-up is vital.
If you wanna get really nitty about it. Get the bike over to OORacing and have it set up on their dyno.
garth
PostPosted: 10:49 - 18 Dec 2014    Post subject: Reply with quote
Ah, not really interested in cheating to be honest, just want to be on a level playing field like everyone else!
Z40 cam is allowed and I have fitted along with springs, didn't make a lot of difference though.
The last post was made 11 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 81.63 Kb
