Moly oil?
FlightRisk
PostPosted: 02:01 - 21 Dec 2014    Post subject: Moly oil? Reply with quote
When I was checking my valve clearances the other week I had the cams out to measure the shims. Haynes manual says something about lubing the cams with a mixture of high moly content lube & motor oil.
Now I needed the bike so I just filled a syringe with motor oil, liberally squirted every bearing surface and put it back together.
Parts have arrived so I now need to go back in there and install my new shims etc.
There's the big tub of Moly/Lithium grease in Halfords but it doesn't specify what % content it is, I suspect not much.
Should I track down some kind of special moly lube or did I do the right thing with the syringe of motor oil?
Honda CB500S
Fisty
PostPosted: 08:35 - 21 Dec 2014    Post subject: Reply with quote
Ive only ever rebuilt engines using new oil as lube, never used moly grease.
Fatter and faster than Fret
Triton Thrasher
PostPosted: 10:29 - 21 Dec 2014    Post subject: Reply with quote
Use assembly lube.
This sort of thing.
https://www.ebay.co.uk/itm/Millers-Oils-Competition-Assembly-Lube-Cam-Lubrication-30ml-tube-/181137160040?pt=LH_DefaultDomain_3&hash=item2a2c9db768
Although you're probably ok with oil.
Rrrrrrrrrrrrrrrrrr
Taught2BCauti...
PostPosted: 11:55 - 21 Dec 2014    Post subject: Reply with quote
Don't use anything other than the correct engine oil on engines with a wet clutch.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Triton Thrasher
PostPosted: 13:52 - 21 Dec 2014    Post subject: Reply with quote
Using assembly lube on cams won't affect the clutch.
You don't use much- it's dear!
Rrrrrrrrrrrrrrrrrr
Copycat73
PostPosted: 18:49 - 21 Dec 2014    Post subject: Reply with quote
when I did my R1 valve clearances I made up some molly oil ... simply mixed the molybdenum disulphide grease with the engine oil till it was runny enough to apply wit a paint brush but sticky enough to stay put when applied.. you wont need much it was surprising how far a little went.
this stuff is as good as any... you already got the oil to mix wit it.
https://www.halfords.com/motoring/engine-oils-fluids/grease/comma-cv-lith-moly-grease-500g
PS.. this was done as part of a 24k service which included an oil & filter change as was due ... done immediately after the engine was first started after new shims were in place.
caveat emptor
The last post was made 11 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.77 - MySQL Queries: 13 - Page Size: 47.95 Kb
