SV650 2003 faulty speedo
DrDubiel
PostPosted: 14:02 - 22 Dec 2014    Post subject: SV650 2003 faulty speedo Reply with quote
Hi everyone,
I got 2003 SV 650 with digital speedometer. I went for a trip across UK last weekend and 30 mile after I set off my speedo started to behave dodgy. I was riding at constant 70 MPH and it was showing 57-62-78-49-56..., looked like random numbers changing every 0.5s. It was showing normal, stable values under 30mph, but few miles further only thing I could see was 0 and nothing changed since then. Does this symptom indicate any specific failure, of is it gonna be a trial and error now ?
ThankS!
PostPosted: 19:40 - 22 Dec 2014    Post subject: Reply with quote
Take off the sprocket cover and look to see if the castle nut is missing off the end of the output shaft. Might even be a hole in the cover.
evoboy
PostPosted: 21:45 - 22 Dec 2014    Post subject: Reply with quote
The speedo drive in the front wheel will no doubt have broken.
It happens when people take the wheel out and dont replace the drive properly as the gearing is plastic.
APT Motorcycles
PostPosted: 21:50 - 22 Dec 2014    Post subject: Reply with quote
Cable speedo on a 2003 bike? That's surprising, I assumed they would be using the electronic system by then.
evoboy
PostPosted: 22:02 - 22 Dec 2014    Post subject: Reply with quote
It is digital.
It uses a drive the same as cable, but uses wires instead of the cable.
Strange.
APT Motorcycles
Supermoto_Fan
PostPosted: 00:27 - 23 Dec 2014    Post subject: Reply with quote
It will be the speedo drive
I've broken 2 in as many years, cheap brittle plastic locating tabs, when these break off it causes the sensor to spin and not sets properly giving varied readings or nothing at all.
Good news is it only costs £20 for the part, bad news is there is not much you can do about it.
The last post was made 11 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 48.48 Kb
