| moonzoomer |
 moonzoomer World Chat Champion
| andys675 |
 andys675 World Chat Champion
| binge |
 binge Emo Kiddy
| 1198 |
 1198 World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:12 - 23 Dec 2014 Post subject: |
Careful now. The Sukida is about as generic as they come, but the same engine code doesn't necessarily mean the same engine, or that everything will line up precisely. Make sure that the seller warrants that the barrel will fit your specific engine. ____________________ Biking is 1/20th as dangerous as horse riding.
| moonzoomer |
| 1198 |
| bradh511 |
 bradh511 Scooby Slapper
 Posted: 15:21 - 23 Dec 2014 Post subject: |
Ive fitted few of 150 kits depending on what model cg you had depended on the size of the crankcase opening. Brazil cg had the right opening .. My cg ended up with ar 125 back wheel and a normal front one and was pretty nippy hit indicated 80 mph lol with ar125 geanring ____________________ Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013  |
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:31 - 23 Dec 2014 Post subject: |
The OHV CG copy-engines can come as either 156FMI or 157FMI. All this means is that a given manufacturer has decided to round 56.5mm bore measurement up or down for their engine code.
You can get them with or without balancer shaft, with one or two exhaust ports, and just to make it more confusing, there's also a CB copy OHC engine which I've seen coded as a 157FMI when the CB bore was apparently 56mm.
And then there's the Suzuki based 125, which is usually (but not guaranteed to be) coded K157FMI.
Allah loves wondrous varieties. ____________________ Biking is 1/20th as dangerous as horse riding.
| moonzoomer |
 Posted: 00:23 - 24 Dec 2014 Post subject: |
I have 2 of the CG clones, one branded Sukida model SK125 -2 and a Superbyke model SB125, both are identical bar the Superbyke having 3 sets of footpegs and have the same manufacturers plate (Zeng Cheng Halli), the engines have slightly different finishes but other than that the bikes are identical right down to the rather well made rear carriers, the Suzida has 19k miles on the clock and really needs a rebore and piston (using oil) so I reckoned it would be just as handy and certainly no more expensive to change the barrel and piston due to the low cost but now I am thinking about the cylinder head as well, not sure if these model have a 150 head with a 125 barrel fitted for the UK market though I would doubt it due to the smaller bore. |
| pepperami |
 pepperami Super Spammer
 Posted: 10:00 - 24 Dec 2014 Post subject: |
Come back and tell us what you found and how you got on.
interested in this  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| humanbeing |
 humanbeing Nova Slayer
 Posted: 04:26 - 26 Dec 2014 Post subject: |
| moonzoomer |
The last post was made 11 years, 285 days ago. Instead of replying here, would creating a new thread be more useful? |
