Help with speedfight
Nooney165
PostPosted: 22:57 - 24 Dec 2014    Post subject: Help with speedfight Reply with quote
I have a peugeot speedfight and it's starting to winde me up any help would be ace Right problem I have is when I bought it is was runnin fine and then after a day it started going dead sluggish and spluttering I got told clean my carb so I took it to a friend he cleaned the carb but still the same I got told it could be my tickover screw tried that nothing then a shop said its my piston there's no compression I have had a new piston kit fitted and it wants to start but won't tryed petty down the head and petty in the air filter hole noting changed plug was getting a good spark and compression is good there's fresh petty and it's going though to the carb any ideas people help would be great thanks
Nooney165
PostPosted: 20:57 - 25 Dec 2014    Post subject: Reply with quote
come on people any help
Doovy
PostPosted: 00:49 - 26 Dec 2014    Post subject: Reply with quote
You do realise it has been Christmas and you can't write in basic sentence structure, yes?
Chuffin Nora
PostPosted: 01:43 - 26 Dec 2014    Post subject: Reply with quote
Huh!
Sentence structure, is it? Now we're talking!
The Speedfight, while itself unable to write, at least knows how to periodically come to a full stop.
Nooney165 -- a battle of wills occurring between you and your mode of conveyance, namely a Speed--fight, it's surely suffering an identity crisis!
Might it not be better to seek guidance thus?:
https://www.scootershack.co.uk
Well, that's my two frankincense-worth!
Gerrit?
There's a fine line between integrity
Nooney165 This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Doovy
PostPosted: 20:45 - 28 Dec 2014    Post subject: Reply with quote
Welcome to BCF.
evoboy
PostPosted: 23:18 - 28 Dec 2014    Post subject: Reply with quote
Nooney165 wrote:
fuck me we have key board worriors get a life ye dick head
Annnnnnd any help you might of got has now gone out the window....
APT Motorcycles
andyscooter
PostPosted: 08:21 - 29 Dec 2014    Post subject: Reply with quote
hello
and good bye Laughing Laughing
Taught2BCauti...
PostPosted: 10:04 - 29 Dec 2014    Post subject: Reply with quote
For any 'Engine won't start' problem, you need to know the basics:
1. You need the correct air/fuel mixture.
2. You need good compression.
3. You need a decent spark to ignite the mixture.
4. The spark needs to happen at the right time.
1. Make sure the carburettor is clean, has a supply of fresh fuel (is that what 'petty' is?), there are no restrictions to the air supply, and no restrictions to the exhaust flow.
2. If you don't have access to a compression tester, try rotating the engine by hand from the flywheel. You probably won't be able to do a full cycle with good compression.
3. Remove the spark plug and check the gap with a 'feeler gauge'. 25 thou is a good gap to start with. Whilst the plug is out, re-fit the HT lead and rest the threaded part of the plug against the cylinder head. Turn the engine over with the ignition on, and check for the presence of a spark.
4. If the flywheel or ignition pickup has been disturbed during the piston replacement, check that the stator and rotor have been re-fitted correctly - so the spark will occur when the piston is somewhere near the top of the stroke. Make sure the woodruff key is still present.
Not everyone on BCF has English as their first language - you will get a much better response to your questions if they are easier to read.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
The last post was made 11 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 64.33 Kb
