Plugs or strings
funmonkee
PostPosted: 17:59 - 26 Dec 2014    Post subject: Plugs or strings Reply with quote
Plugs
https://www.ebay.co.uk/itm/STOP-n-GO-TIRE-REPAIR-REPLACEMENT-PLUGS-x-25-/111555649309?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item19f93c1f1d
or strings?
https://www.ebay.co.uk/itm/Safety-Car-Bike-Bicycle-Auto-Tubeless-Tire-Tyre-Puncture-Plug-Repair-Kit-Tool-HC-/251626967774?pt=LH_DefaultDomain_3&hash=item3a9622d2de
I use the plugs. But have some of those strings. Think I was given them by a 'helpful' mechanic said they were the best... The plugs have worked for me and I've got the small tool-bag with all the plugs, tools and compressed air. I was under the impression the strings are 'more' temporary ??
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
Fladdem
PostPosted: 18:02 - 26 Dec 2014    Post subject: Reply with quote
Strings are more temporary, I think plugs are a better solution for a puncture. Although, at work we use those strips and about 99.9% of the time, it's a good fix.
Vracktal
I was under the impression plugs were more temporary as they were just held in by friction against the hole they were filling and the inertia of the tyre spinning, and strings lasted longer because they were held in with the gluing agent...?
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
Nash GT
PostPosted: 18:43 - 26 Dec 2014    Post subject: Reply with quote
Seen the strings used many times with a fairly high success rate, no experience on the plugs, would be interested to know too.
Suzuki GSF600N
Islander
PostPosted: 19:06 - 26 Dec 2014    Post subject: Reply with quote
Sticky string has always worked for me. Thumbs Up
funmonkee
PostPosted: 19:18 - 26 Dec 2014    Post subject: Reply with quote
I've never used the string' always used the plugs and they work. But I have the strings now...
XBIKER
PostPosted: 19:55 - 26 Dec 2014    Post subject: Reply with quote
Once had a rear puncture repaired with a plug at a workshop which "let go" at 40 mph and that leaves a very big hole for fast deflation. Shocked
After that I was a bit wary of plug repairs but never came across the string.
Always carried a footpump as well as a few small fat, wide thread screws which proved brilliant as a stop gap puncture repair. Just screw it into the puncture hole, pump it up and as long as it's not a split it will hold the air in for ages. Best I managed was three weeks with a daily top up first thing until I was ready for a replacement tyre and the screw was still holding except the head had totally worn off.
Tried Tyreweld once but the tyre had run flat breaking the bead which meant the reflated tyre just spun around the rim using the tyreweld as a lubricant. Quite comical when you twist the throttle and everything works but you don't actually move.........
Doovy
PostPosted: 21:29 - 26 Dec 2014    Post subject: Reply with quote
Stop n Go plug kit as above.
PostPosted: 12:24 - 29 Dec 2014    Post subject: Reply with quote
A plug-n-go mushroom worked for me on a puncture that sticky string wouldn't seal.
I used vulcanising solution as well though.
evoboy
PostPosted: 14:36 - 29 Dec 2014    Post subject: Reply with quote
It was installed wrong then, or the tyre was defective.
I repaired a Dunlop Roadsmart with a proper plug repair ( remove tyre ). The tyre was 500miles old when it punctured. I did 3 trackdays and 7000miles on that tyre and it always held air.
I've had the recovery men put string repairs in tyres while on the go, but they always leak air.
I would use the plugs and vulcanising glue over the strings.
APT Motorcycles
Andy_Pagin
PostPosted: 18:48 - 29 Dec 2014    Post subject: Reply with quote
I've always used strings and they easily last the life of the tyre.
BanditsHigh
Worse than a woman
PostPosted: 21:55 - 29 Dec 2014    Post subject: Reply with quote
Strings are a get you home ... mushrooms are the proper way to repair a tyre and they are glued in!
Do my own and never had an issue.
The last post was made 11 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 75.97 Kb
