GN 125 not getting above 30
Simba76
PostPosted: 09:01 - 21 Dec 2014    Post subject: GN 125 not getting above 30 Reply with quote
Hi, My first post so go easy.
Looks like there is a huge amount of knowledge on here so hopefully somebody will put me right.
I have a 2002 Suzuki GN 125 with 25,000 on it.
What sort of revs should the choke be adjusted to?
It starts out idling at about 2500 but after a few minutes, when I'm stopped at lights its up to 4000 or higher!
I am just learning the manual choke so it might be this.
The bike does not seem to get above 30 when I'm riding it, even with the taps fully open. Cold?
How long should it need warming up before riding?
Thank you in advance!
yen_powell
PostPosted: 10:24 - 21 Dec 2014    Post subject: Reply with quote
Start it, ride off straight away, turn the choke off when you're moving, if you've got your hand on the throttle you can keep it going with no choke until it's warm enough to tick over on its own.
Re the 30mph, that's not right. You are using the gears aren't you?
XT1200Z and a DR350 in bits
Teflon-Mike
tl;dr
PostPosted: 10:44 - 21 Dec 2014    Post subject: Reply with quote
If you have the choke on still, then it probably wont go over 30.
The choke, is a flap that covers the inlet to the carb to 'choke' the flow of air in to it, and richen the mixture for cold start.
The 'Throttle' is a 'gate' in the carb that restricts the flow of 'charge' (Air+Petrol) into the engine... so if you have the choke on, you can open the throttle as much as you like... it's like opening your front door and running into the closed porch door and wondering why you cant get out.
As for the revs? Choke doesn't 'set' idle revs. As said, it chokes air to the carb to richen mixture for cold starting when the fuel is less 'volatile' and harder to catch on fire.
Depends how cold it is how hard the engine is to start, and how 'low' it will idle on choke when it catches; then having started, as burning fuel starts to get metal warm, 'less' choke will be needed to keep it running, and the idle is likely to 'race' over normal tick-over as it gets warm enough to run without choke.
My bike, idles at about 1000 revs 'normally'.. no choke, a warm engine.
On a summers day, will tend to need a bit of choke to 'start' first thing fro cold. Soon as its caught, though, choke can go straight off, and I can ride off. Rest of the day, shouldn't need any choke to re-start.
On a cool spring morning; needs full choke to get it to catch; and I have to leave the choke on and the engine idling, about as log as it takes me to stick my hat and gloves on,open the gates, wheel it through, and shut the gates; by that time the idle, that was a bit 'lumpy' and low when I got it started, will have lifted and it'll be ticking over a little over higher than normal tick-over... but can knock the choke back to half and it comes down, and, ride at 'part throttle' half choke letting enough air to get the bike moving to the end of y street, where I can knock the choke off, the engine 'warmed'.
Were I to go out now and try start the bike? Well, its not VERY cold, but its getting there.. it's three layers of trousers whether..... would take full choke to get t to catch, and probably a few prods before it did; probably 'conk' on me while I was doing the gates and wheeling it out, and need a re-start to carry on warming while shut them behind me.. if not, tick-over would be rather low and lumpy.. then, gates done, might have to sit on the drive for a couple of minutes to let it get warm enough to knock the choke back a bit, before I could think of pulling off up the road, putting the motor 'on-load'
Which is all a bit more 'exaggerated' than you should expect with your bike, being a small singe; mines a four cylinder air-cooled 750, so there's a fair bit more metal to get heat into; but gives you an idea of the principle.
If the revs are leaping up that much 'on choke', then you are probably leaving to too long; and as said, if you try riding off with it full on, its like having a rag stuffed up the carb, its not going to be able to suck the air it needs to make power to go very quick.
So, use choke to get t started, knock it back as the revs start to ride to hold a comfy idle; give the thing a chance to get a bit of heat into it on choke before you start riding it; choke 'off' before you try giving it more than 1/4 throttle, all should be good.
Simba76
PostPosted: 12:59 - 21 Dec 2014    Post subject: Reply with quote
Cheers gents.
Explained very clearly for a novice. Very grateful indeed.
Take care. Have good Chrimbo!!
Simba76
PostPosted: 17:11 - 21 Dec 2014    Post subject: Reply with quote
Just been out for my first proper run. 35 minutes through the countryside. Got it up above 50 no probs. had a moment when I couldn't get 1st on a busy but slow round a bout. But that could have been just me!
Still sounds a little rough and spluttery.
What would adjusting the mixture screw do? I will check the carb collar for holes as well.
If you can keep your head while all around are loosing theirs....you're probably in some sort of Zombie movie!
-Current bike ......
Teflon-Mike
tl;dr
PostPosted: 13:34 - 22 Dec 2014    Post subject: Reply with quote
Clue in in the question....
Compared to....?
It's a little air-cooled one-lunger.. they always sound a little err, 'flatulent', it's the nature of the bike.. you have just had a 'good ride' after trying to make it go everywhere with the choke on... so I am guessing your references for comparison as to what it should or might sod and feel like are a little limited.... PLUS, if you have been runing it for prolonged periods with the choke on... you probably have a sooted up spark-plug..
Carefully, as the threads are prone to being crossed or stripped if you are clumsy or heavy handed; remove the spark-plug; clean it with a small wire brush and some sand-paper between the electrodes; check the gap-size ad set f neccesary, or for £3 or so.. must buy a new one... though still often useful to make sure the gaps the right size before fitting.... And tip, when you DO fit; DONT over tighten it. Figer tight + 1/4 turn is ALL they need.. ore and you can start pulling the threads up out of the cylinder head rather than pushing the plug further into it, and your next lesson will be about things called 'Heli-coils'!
Leave the carb alone, for now.. there's two adjuster screw, and easy to twiddle the wrong one is you don't know what you are doing.
idle speed screw; sets the stop pot for the throttle slide at its lowest point ad tip if you ever adjust that, is you open the throttle before you turn it, set it where yo think it should be then, close the throttle to come down and rest on it.. and let the revs 'settle' at the new position before making another adjust. Reason being the set-screw is at 90 degrees to the throttle slide and there is a tapered groove in the slide, so that the further 'in' the screw is, the higher up the slide 'stops'.. but very 'fine' taper, and if you wind the screw 'in' with the slide on it, you are as like to just push the slide sideways in it's hole, and make a bit of a dent in its ramp, making it 'sticky' and harder to adjust and get a good idle.
Mixture Screw... other wise known as the pilot-air-screw, usually opens and closes a port allowing air sucked through a fine gallery parallel to the main air passage in the carb, controlling the amount of air that is fed to the 'emulsion tubes', where petrol being sucked up the 'jets' gets 'frothed up' by it, for want of a better word, so it comes out as a fine mist when to gets sucked to the engine.. hence it adjusts the BASE ratio of fuel to air the carb makes.
Engine needs a 'correct' ratio of fuel to air... only there isn't any 'correct' ratio.. there's a 'range' of more or less suitable ones, that's actually quite broad; and a very large range of unsuitable ones either side.
Too much air and too little petrol = 'Weak' mixture. This is hard to light, and prone to 'pinking' which is burning too violently in the engine, making the engine run 'hot' and can damage the motor, which not burning all the fuel it could, wont make as much power.
Too much petrol for too little air = 'Rich' mixture... and is relatively 'safe'; if there isn't enough air, it wont all burn, which is why you get 'soot' from it, while again, not getting all the power you could, cos 'excess'petrol not beg fully burned is taking air from fuel that might be getting fully burned.
So twiddling with the mixture screw, lot of chance to get it 'wrong' for very small chance you'll make it 'better'.... A-N-D... if you think you need to twiddle with it.... likely there are an AWFUL lot of other things to fiddle with FIRST... its something you 'set' LAST after you have done a full service; making sure than air-filter s clean, the carb jets are clean, the float height is correct; the valve clearances are correct; the Cam-Chain-Tensioner adjusted; the spark-plug new or clean, the HT lead clean and good, and on a points ignition engine, (probably not applicable to you) points, new/clean gapped and timed, and the condenser new/good.
So back up... start with your spark-plug.... having been rung on choke, THAT is the most likely suspect for anything not quite right... and even if it ISN'T the culprit... its your first port of call, to find what may be.... look in the Work-shop manual, there is usually a nice photo-guide from Champion of NGK, showing a dozen photo's of spark-pulgs to compare to your's, that give 'hint' at what might be up with the engine, and what to do about it... of which, adjusting the mixture is only two pics... which conveniently tell you which way to adjust the mixture, IF needed.
So ALWAYS start by looking at the Spark-Plug FIRST... and heed warnig about not being ham-fisted taking it out or putting it back in!
Simba76
PostPosted: 19:47 - 23 Dec 2014    Post subject: Reply with quote
More wise words. Cheers
I have a mate of mine who used to repair bikes giving it the once over tonight.
He has already remarked it will need the tappetts adjusting which he will do.
As well as the fact the revs are not dropping as soon as you release the throttle. He thinks there could be an air leak in the carb seals which he will also check out.
talkToTheHat
PostPosted: 06:03 - 28 Dec 2014    Post subject: Reply with quote
i know the GZ's choke was a fast idle device rather than a real choke, does the GN have the same carb?
Engine/gearbox are related but not quite identical. Both of my GZ's were reluctant to find first gear, fresh oil significantly better than old sludge. Try to engage 1st before coming to a stop, or let the clutch out a bit in 2nd and inch the bike forward, pull it in and try again. Mine were awkward, and had the unnerving habit of displaying the neutral light when in gear and clutch in. Check your chain tension, gearbox is irritatingly sensitive, and if the GN is anything like the GZ keep an eye on the cush rubbers as the bike will eat them.
Bandit. does. everything.
The last post was made 11 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.6 - MySQL Queries: 13 - Page Size: 68.63 Kb
