Restrictor kits
RickHolt
PostPosted: 11:23 - 25 Jan 2005    Post subject: Restrictor kits Reply with quote
Does anyone know where I could get a restrictor kit from other than FI. I really don't want to pay 150 quid for the washers. Are there any sites that people sell them second hand that I might have missed?
It's the 03-EX500A-K25 kit for a GPZ500 i'm after.
paulodd
PostPosted: 12:03 - 25 Jan 2005    Post subject: Reply with quote
Give ebay ago. Try and find someone selling the bike that may have the restrictor you want. Then email them and see if the bike is restricted or if they have a restrictor. If they have one seperate then try and put across the message that they can't be used again so that you can possibly get them free, even though they can be re-used.
Paul
Paul
1999 Yamaha R6
www.coventrybikers.co.uk / www.norfolkriders.co.uk
Laura
Playboy Bunny
PostPosted: 12:07 - 25 Jan 2005    Post subject: Reply with quote
Or take it to a normal dyno place and ask them to restrict it without using f1
Good girls ride motorcycles bad girls thrash them.
instigator
PostPosted: 14:09 - 25 Jan 2005    Post subject: Reply with quote
Would the restrictors for the gpz500 be the same as the er5? I know they're based around the same engine.
If so, I may be able to get some spares, if another er5 owner gives me them (shes got to get back to me)
loply
PostPosted: 14:58 - 25 Jan 2005    Post subject: Reply with quote
As mentioned in my thread recently, just use electricians tape wrapped around the carb mouth (if you know how to get to the carb).
Find someone with a GPZ500 who can give you an idea of the size.
Yamaha SZR660 Caution to the wind, the throttle pinned!
RickHolt
PostPosted: 18:56 - 25 Jan 2005    Post subject: Reply with quote
Didn't know they could do that Laura. Any idea as to how much it would cost? How would they restrict it?
Loply didn't people say that was a bad idea?
I thought maybe it could take the same restrictor kit as the ER5. As you say, it's the same engine pretty much. Not sure though.
kasandrich
PostPosted: 19:08 - 25 Jan 2005    Post subject: Reply with quote
Some dealers with a Dyno will restrict it for you, by restricting the throttle movement, which assuming you have variable venturi carbs, does effectively exacly the same as the FI restrictors.
They hazard a guess how much to restrict it, then run it on the dyno, and adjust from there, the one I spoke to reckoned about £150, so not much difference to FI.
I reckon your best bet is a secondhand pair of restrictors, or you could make your own from the pattern I will email to you, the pattern I am emailing is for an ER5, you can check the part numbers for compatibility on FI's site.
Richard
CBR1000FM
kasandrich
PostPosted: 19:14 - 25 Jan 2005    Post subject: Reply with quote
I have realised I can add an attachment here, outside diameter should be 42mm, so that it just fits in the rubber section of the inlet mnifold, when the carbs are removed.
Richard
CBR1000FM
PostPosted: 20:22 - 25 Jan 2005    Post subject: Reply with quote
Just get it done with an FI restrictor kit. Either you'll never be asked for it in which case no problem, or if you are asked for it you can show them the FI International bit of paper and they'll be happy. Or you could start telling them the story of how you've restricted it yourself and show them a dyno printout, expect lengthy discussions to follow with plently of hassle. FI International kit = easy solution and simple as it is accepted when you're asked for proof.
cagiva gezzer
PostPosted: 21:26 - 25 Jan 2005    Post subject: Reply with quote
Dyno restriction cost my mate under £50 and he never had any hassle from anyone.
PostPosted: 21:47 - 25 Jan 2005    Post subject: Reply with quote
Unlucky. My restriction on my ZX6R which cost £0and I never got any hassle from anyone, far better than what I'd have got for £50 from some dyno shop.
The last post was made 21 years, 152 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.68 - MySQL Queries: 13 - Page Size: 67.25 Kb
