1994 Cb500 small oil leak on startup after a COLD night
UncleFester
PostPosted: 15:36 - 30 Dec 2014    Post subject: 1994 Cb500 small oil leak on startup after a COLD night Reply with quote
On a cold start this morning, got an egg cups worth of fresh oil seeping out from the bottom of the bike. On close inspection, it's coming out between the filter housing and the engine casing - right at the very bottom. No leaks from anywhere else.
I presume this is just a poor seal between filter housing and block due to the very cold temps and that a new filter and gasket will cure the issue. Filter doesn't look like it's new so the gasket is possibly perished or perishing.
No leak once the bike is warm and on a warm start, no visible leak either.
2017 Z1000SX
evilzed
PostPosted: 21:24 - 30 Dec 2014    Post subject: Reply with quote
Interesting I had a leak recently occur on my 09 Hornet from between the oil filter and engine as well I torqued up the k&n filter and it still leaked(albeit less). Difference in my case was that it would leak consistently even when warm.
My best guess is maybe due to the engine expanding from the heat the seal may become better :S
I fixed the issue by just swapping out the filter no more leak what so ever after I think changing the O ring might do it as well although my K&N O ring looked to be in good condition. Also it might be worth tightening the filter a little more just in case it hasn't gotten a little loose.
UncleFester
PostPosted: 08:36 - 31 Dec 2014    Post subject: Reply with quote
That's todays job i think - filter and washer is < than tenner.
2017 Z1000SX
UncleFester
PostPosted: 17:08 - 24 Jan 2015    Post subject: Reply with quote
I has teh DUMB.
Loose coil on the right hand cylinder explains the lumpy running and remembering which direction the choke moves explains the duff starting. Not trying to start the bike with the fuel tap CLOSED also helps.
Anyhoo that's the oil changed, new filter on. Old filter had a duff seal.
Bike now running a treat.
2017 Z1000SX
The last post was made 11 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 40.33 Kb
