Honda sh125 mode rear indicator bulbs
Ian Mountain
PostPosted: 09:14 - 01 Jan 2015    Post subject: Honda sh125 mode rear indicator bulbs Reply with quote
Hallo have bought a new Honda mode moped and cannot see how to access the rear indicator bulbs to change them
barrkel
PostPosted: 20:21 - 01 Jan 2015    Post subject: Reply with quote
You have a scooter, not a moped. Mopeds are no more than 49cc, no more than 50kph.
If it's anything like my SH300, there should be some small screws in the lens of the brake light, and one screw in each indicator lens. The brake light lens needs to be removed before the indicator lens can be removed. But only the lenses need to be removed to change the bulb.
If it's not like my SH300, and you need access to the inside of the fairing, you've got more work to do. You'd need to remove the seat bucket (typically 6 or so bolts in the plastic bucket / fuel tank cover underneath the seat), and possibly the grab rail (the bit the top-box attaches to, if you have one). That should give you enough access to the other side of the bulb reflectors.
Ian Mountain
PostPosted: 20:37 - 01 Jan 2015    Post subject: Reply with quote
Thanks I'll try tomorrow it's definitely not like the SH300 and I've had the rest of it off when I chopped the seat but I'll look again tomorrow.
Also 69 years old had licence 52 years more like Dem69 than L plate warrior (I know it was my fault for not filling out the form properly)
Ian Mountain
PostPosted: 12:34 - 03 Jan 2015    Post subject: Reply with quote
Had a good look at scooter today there are no screws holding the brake light lens on although I found a drawing on manualslib.com clearly showing that there was one. Have tried Honda dealer here in Greece who says that all the bodywork must be removed to change rear indicator bulbs and he was the Honda specialist.
I can only assume that this was a later mod and keep trying to find it documented somewhere.
Ian
The last post was made 11 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 38.62 Kb
