JB WELD
Is JB Weld good ?
Yes, if done properly, it can last for years
35%
 35%  [ 5 ]
Yes, but only a temporary fix
28%
 28%  [ 4 ]
No, but I may have done it wrong
0%
 0%  [ 0 ]
No, it's nto a good solution at all.
35%
 35%  [ 5 ]
Total Votes : 14
veroom
PostPosted: 16:54 - 04 Jan 2015    Post subject: JB WELD Reply with quote
While I struggle to find a local TIG Welder which would be the best thing if it doesn't or can't warp the cylinder head, I am totally stuck on JB Weld.
I get it to some degree, in a standard environment, done properly, it can be bloody good stuff but for me, there may be a risk of damage to the cylinder head if I don't go the JB Weld route and have it welded. Granted, it's not exactly right next to the cylinder but a gamble by all accounts.
This is in relation to my other thread that exposed a problem with my NSR 125 exhaust port where the stud holds the downpipe. https://www.bikechatforums.com/viewtopic.php?t=297855
I have highlighted the damage, the alloy is cracked across the stud hole.
https://s22.postimg.org/q5kpf1apd/damage1.jpg
https://s22.postimg.org/sbf09je5t/damage.jpg
I can't afford to replace the head. I'm struggling to find a tig welder but the holiday hasn't helped I guess. I'm told it can be welded quite cheaply but getting that sorted seems tough right now.
I live in Oldbury nr Birmingham and this bike is my road to license and a big charity bike ride that is in planning stages later this year so any genuine help is inevitably for a good cause having raised over £3,000 and building a mountain bike worth £900 that is to be sold off for charity. (Terminally ill children)
Thanks in advance. I am a true novice here.
GSXR 600 - Got bike, must pass test, wish me luck.
PostPosted: 18:09 - 04 Jan 2015    Post subject: Reply with quote
No, it's not designed for cylinder heat and it'll really annoy the welder when the time comes to do it right.
Looking at your damage there seems to be a couple of failed attempts at repair.
Your 'cracks' look like hack-saw marks where someone has tried to put a cut across a broken stud to try to remove it with a screwdriver which almost never works and makes drilling the broken stud out ten times harder.
Then it looks like someone has tried to drill out the bolt and the drill has run off into the ally. In the pic it looks like you have the bottom of a half-drilled stud in the hole. Looks like they gave up on that to and resorted to tapping the shallow top half of the hole over-size.
If you remove the cylinder and post it to me I will repair it and send it right back FOC. You can be sure that the repair will be properly done and last the life of the bore. all it will cost you is one-way postage and a top-end gasket set.
Boxing
PostPosted: 18:20 - 04 Jan 2015    Post subject: Reply with quote
As above. Wouldn't even bother applying JB weld there. If you don't send it off to Pete, take it to an engineer, they'll be able to weld.
Aluminium is very tricky to weld onto, and it'll have to be very clean or it won't work.
Pete has offered a very nice gesture, and I'm guessing that'll be your cheapest option for the proper job. He rebuilt Paddy's RS125 engine a while back. Very Happy
veroom
PostPosted: 18:47 - 04 Jan 2015    Post subject: Reply with quote
ferkin feckin fookin hell pete, that's very kind of you mate.
I'll pm you in a bit to get the details. Really not sure I can thank you enough bud.
I was about to order some when I felt to post this instead. Granted, the JB is only 4.75 but that's not the point in this situation is it.
humbled sir, thank you.
I'm guessing JB is excellent for some solutions, just not things like this. Thanks to you too boxing, for the reply. I shall sort this out get it in the post tomorrow.
kestrel
PostPosted: 18:58 - 04 Jan 2015    Post subject: Reply with quote
We do a *lot* of alloy engine TIG repairs at work, especially in the racing season. We will not touch anything that has previously had a bodge repair attempted using either JB Weld or other compounds.
Pete has made a very generous offer and one that you would be well advised to accept.
Isle of Man.........Road Racing Capital Of The World
Boxing
PostPosted: 19:13 - 04 Jan 2015    Post subject: Reply with quote
Don't forget, genuine gaskets. Topend is four bolts. Use a ring spanner and not a wrench on them.
Look up the recommended torque pressure for the topend bolts for when it comes back also.
Now will be a good time to check your piston and any play in the conrod. Smile
Don't forget to put tissue around the bottom of the piston to stop spiders and dirt getting into the bottom end. Thumbs Up
veroom
PostPosted: 19:33 - 04 Jan 2015    Post subject: Reply with quote
Defo Kestrel, I just have to sort getting the cylinder off. Just pee'd the mrs off, moved the kitchen to bring the bike in (we have a long kitchen) so I can do it in the warm and dry.
Boxing, a little unsure of the gasket kit mate, got any tested sources for them ? I can see two of them on pjme
https://www.pjme.co.uk/acatalog/Honda_NSR_125R_Engine_Parts_Top_End.html
one is out of stock, nether say genuine.
Gonna have to find out the torque settings too, I have downloaded the manual.
Boxing
PostPosted: 20:00 - 04 Jan 2015    Post subject: Reply with quote
It depends if you're doing the head gasket as well. You shouldn't really need to removing the cylinder, just the base gasket to go between the cylinder and the bottom end.
Athena do good quality ones. At least from the ones I've tried for the Yamaha DTR.
It's how you apply it that'll tell you how good it is.
Be wary on taking the topend off in your kitchen with it being water cooled. Even if you drain the whole system, there'll still be them couple of drops in the pipe when you take it off. You should only need to remove the four bolts at the bottom of the cylinder. But you can take the head off as well it wouldn't hurt it, you'll just need a new head gasket. (Note: If you don't drain the system prior, it'll leak all the coolant inside it over your floor.)
I know this isn't your bike and your engine is still in the frame (still just as easy) but here's a video to lend you a helping hand. https://www.youtube.com/watch?v=6If62yhyfqc I personally won't remove the head, unless you find out the top end is on its way out and you need to send it off to PJME. Also, don't remove your piston or rings lol.
Edit: Forgot to add in, you'll want to take the four bolts off in a diagonal pattern. E.g left bottom, right top. Only for the first undo / "click"
The gasket on the PJME site this one:
Honda NSR125F NSR125R Genuine Cylinder Base Gasket
Honda NSR125R Genuine Base Gasket
Honda Part Number:12191-KY4-971
Price: £3.90 (£4.68 Including VAT at 20%)
Is the one you want. Very Happy
veroom
PostPosted: 21:54 - 04 Jan 2015    Post subject: Reply with quote
Yea, sounds about right Boxing. I couldn't order that one cause you have to spend £10 and since I don't need anything at this stage I eventually sourced this one
https://www.hondascooterspares.co.uk/product/honda/12191KY4971/gasket,cylinder?uID=0
Just under £6 free p&p
I did change my rad on my old rs turbo some years ago so I am somewhat used to playing around. That was needs must like this so I have a bit of confidence doing it.
Is there anything special coolant wise ?
No engine oil issues ?
Guessing I have to detach accelerator and choke etc from the carb right ?
Boxing
PostPosted: 00:26 - 05 Jan 2015    Post subject: Reply with quote
There should be a screw with a gold washer to drain the coolant. (You can drain it by removing one of the hoses just catch it with a bucket. I wouldn't re-use it after personally.) As for oil, it's only gearbox oil that'll affect the engine, you aren't touching the bottom end, so leave the oil as is. I don't know how Honda did the autolube systems on the NSR's? If you have to disconnect it, you'll HAVE to bleed the system when your cylinder comes back. I just run them with 125ML of 2 stroke per 5 litres of petrol and let the pump bleed itself as you ride.
Carb, literally just unbolt the little jubilee clip holding it on and pull it off. If there isn't enough play, remove the air box and then do it. Leave the throttle cable etc all left inside it and don't disconnect them. Put a carrier bag over your carb (to stop dirt getting in and causing you a headache of cleaning it in the future) and zip tie or tape it to the frame somewhere.
It might be worth while buying a Haynes Manual for your bike, it'll give you a lot of tips on how to maintain it, chain lubrication, gearbox oil changes etc and has the torque pressures for all the engine components. It'll tell you where all the draining bolts are too.
bladerunner
PostPosted: 15:03 - 06 Jan 2015    Post subject: Reply with quote
Just for info David silver spares are listing new genuine barrel and piston sets for £155. Is it worth spending the extra in the long run?
PostPosted: 22:39 - 06 Jan 2015    Post subject: Reply with quote
If that includes rings that's a really good deal I say. New-bike compression for £155 is not to be sniffed at.
bladerunner
PostPosted: 12:29 - 07 Jan 2015    Post subject: Reply with quote
The last post was made 11 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 15 - Page Size: 86.25 Kb
