exhaust manifold pipe glowing
hunterfett
PostPosted: 20:29 - 04 Jan 2015    Post subject: exhaust manifold pipe glowing Reply with quote
Hi just started my 1983 GS125 today and I've noticed after running for a short while on fast idle the exhaust downpipe from the head started glowing bright red. I'm new to the world of bikes but I have never noticed this before is this normal and if not does anyone know why this might start happening now I'm no mechanic so have not tampered with anything just a little confused any help greatly appreciated thanks Sad
cheers all
kestrel
PostPosted: 20:53 - 04 Jan 2015    Post subject: Reply with quote
If the bike is down on power as well then I'd take a guess at the exhaust valve not seating correctly, compression test would be the first move.
Isle of Man.........Road Racing Capital Of The World
hunterfett
PostPosted: 06:15 - 05 Jan 2015    Post subject: Reply with quote
Can this happen on its own because like I said before I haven't touched anything on it and I've never noticed it before
cheers all
PostPosted: 09:31 - 05 Jan 2015    Post subject: Reply with quote
Does happen. Especially if the bike has been fast idling and revving while stationary. More prone to it if there is flash rust over the surface of the header pipe and obviously more easy to see if it's dark.
So if it had been idling away stationary for a while with a slightly rusty pipe in the dark. Normal.
If it was after a run or only being run for a short time or obviously glowing red in daylight, I'd be more concerned.
In any case. Quick and easy to check the sparkplug electrode colour.
bikenut
PostPosted: 11:55 - 05 Jan 2015    Post subject: red hot Reply with quote
also check ign advance ( to rule that out ) .........
nuts about bikes
motad_uk
PostPosted: 16:26 - 05 Jan 2015    Post subject: Reply with quote
if its an aftermarket system with a single skinned downpipe and you are running the engine whilst stationary - the pipe will get very hot and glow (its got very hot gas inside it!)
exactly the same will happen with the original double skinned pipe- its just got a pipe on the outside stopping you seeing it
if it has suddenly started happening- get it checked out
but I suspect you have just noticed it and as soon as you start riding the air will cool the pipe (and don't think about checking it whilst riding- look where you are going instead)
[email protected] www.motad.co.uk
see us on Facebook at Motad Ltd
hunterfett
PostPosted: 13:04 - 06 Jan 2015    Post subject: Reply with quote
Yes I did notice it in the evening hadn't used it for a couple of days and battery was flat so bumped it and left it running for a bit with choke open to recharge the battery a bit. Rode it to work this morning and it wasn't glowing when I got there. Thanks for all the advice will keep an eye it she is an old girl after all (1989). pmsl I take it from that comment you have encountered people that would be stupid enough to ride along staring at their exhaust pipe. Lol
cheers all
Ed Case
PostPosted: 13:35 - 06 Jan 2015    Post subject: Reply with quote
Quite probably far to 'lean' a fuel/air mixture.
PostPosted: 14:18 - 06 Jan 2015    Post subject: Reply with quote
I suspect the exact opposite. He left it fast idling on the choke.
The last post was made 11 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 60.13 Kb
