cg125 1997 help please
dw-autos
PostPosted: 20:25 - 04 Jan 2015    Post subject: cg125 1997 help please Reply with quote
Hi all ,
Im new to motorcycles but carry out most of my own work on my cars
I am sick of my 5 mile 1hour commute due to traffic so i have bought a cg125
its 1997 has a circle headlight and lolypop indicators from what images iv seen it a cg125w says honda cdi on the engine case
it has mot till march
any how i have not rode it yet waiting till mid week when my helmet and bikegear comes
seem to fire immediately first kick , engine sounds well
couple of probs id like some help with tho
i have a hole in the exhaust , should i replace or repair
and i have no front lights working , indicators are all fine , and tail seems dim and flickering with engine revs
please advise
looking forward to speaking with you
going forward i am going to service and restore the bike and i like it so far
bradh511
PostPosted: 21:29 - 04 Jan 2015    Post subject: Reply with quote
I've had problems with ingtion barrel failing on honda causeing no lights what so ever check the bulbs. Is the battery anygood and test the yello wire from magneto this is the chargeing wire as I remember might also be worth test the rectfier ecy a power probe and multi meter are your freinds here
Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013 Smile
dw-autos
PostPosted: 16:48 - 05 Jan 2015    Post subject: Reply with quote
Hi can you take this back to basics for me electronics isn't my strong point but I d have a multimeter
Do I have removed the lense and both bulbs look ok
Where do I go from here
bradh511
PostPosted: 20:54 - 05 Jan 2015    Post subject: Reply with quote
If you remove the lense buy the 1 phillips if im correct and memory serves me right pull the head lamp forward and out to get to the back of the bulb un clip bulb check element as they do go fairly easy... With road condtions again do you have a good battery ? Lights will only work with engine running... On theq left had side of the engine cover that cover the fly wheel same side as gear shifter there shoul be a multi plug with several wires check the yellow wire is putting power out as this the chargeing feed for battery and for the lights if memory is correct need bike running to check
Brad
The last post was made 11 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 39.65 Kb
